Superduty gooseneck question
/ Superduty gooseneck question #21
I bought a chassis/cab and added an aluminum flat bed with trap door and goose hitch below - would do it again - would do it again with a CHEVVY, though it is possible with a (removed).
It works out real good.
FULL WIDTH bed, none of that 4ft and an inch or two between wheel wells nonsense.
No tin box top rails to worry about scratching up with the goose trailer, etc.
GREAT thing about it is that it is only about 4 inches lower than a standard loading dock, so picking up FULL SIZED things at loading docks is easy.
Add stake sides if you want/need to.
Yeah, I'd do it again - Chev/GM again that is (-:
/ Superduty gooseneck question #22
I really looked at going flatbed, but you can't throw junk in the back, it wanders off on the first turn.
/ Superduty gooseneck question #23
what about stake pockets with small side baords that are easilly removed? that and some recessed d-rings and straps that live in a tool box could make for a dual purpose setup.
soundguy
/ Superduty gooseneck question #24
How is that a BAD thing ?
Junk is junk, right ?
/ Superduty gooseneck question #25
soundguy
Mine has stake pockets and a rub rail all the way around outside those.
I went to some length to make up stackable side boards out of 5/4 6 inch PT decking that I could slot in 1, 2 or 3 high according to whether I wanted HIGH for carrying a lot of stuff, medium for stuff with the trailer on, or low for just a few small items.
It worked, I wrecked a few, most stuff now gets held on with cargo straps or bungie cords.
I didn't find D-rings necessary, the stake pockets and rub rail make for good securing points.
Good enough for hauling things like my Harley Rake home, now THAT was a trip that I was pleased I had a 7ft + wide clear flat bed for.
/ Superduty gooseneck question #26
yep.. the rub ral does kind of make the d-rings a tad bit unecescary.
soudnguy
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
2023 Case TV450B (A62177)
2023 Case TV450B...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
2008 Bobcat T300 (A64126)
2008 Bobcat T300...
