Slopes and tractor tilt
   / Slopes and tractor tilt #131
More importantly, it moves it to the rear.
I think the most important point about FELs that most people miss is not how high or low it moves the cg - it's how far forward it moves the cg. Remember - you're driving a triangle. Your 3 points are the two rear tires and your front axle pivot. Putting that FEL on - and even worse, adding weight in the bucket - moves the cg forward towards the narrow "tippy" part of the triangle. Adding a rear mower moves it back towards the wider, stable part of the tractor.
If you mention "center of gravity" and "front end loader" in the same sentence, you should also mention "forward." If you're only talking about "higher" or "lower", you're missing the biggest reason* that a FEL makes a tractor more likely to roll.
It's a nice day - time to get outside and get a few sidehill pictures.
* I'm assuming that the operator is carrying the bucket low to the ground. Obviously, raising the bucket raises the CG significantly.
Yahh but...
If you are including "triangle" you should include "rectangle", for when the bucket is EMERGENCY dropped (-:
Now, if you have several hundred pounds on the 3pt and it is LOW to the ground, but things are still getting tippy - you gotta SERIOUS PROBLEM happening.
I still want that 4 point landing and to get it I will take the pivoting front axle out of the equation.
   / Slopes and tractor tilt #132
Yahh but...
There's only so much you can do...and you already wrote two of them (bucket low and moving slow).
If your tractor has a ROPS, keep that seatbelt nice and tight and keep off that slope if it's the least bit wet.
That's about it, really...
Spyderlk wrote to have the tail wheel just skimming. I prefer to have it solidly on the ground and bearing part of the cutter's weight.
No matter what you do or how tight you adjust the anti-sway links, you'll still have some lateral movement of the cutter moving the rear of the tractor about. That's not theory and in all likelihood, you've already experienced that sway.
Going slow reduces the effect of the cutter sway. Worst thing I could imagine is getting into a "tail wagging the dog" situation.
Fortunately, the area I brush cut is very moderately sloped, but is very uneven (ruts and rises). I could definitely feel the effect the cutter was having on the rear of the tractor even with the tailwheel bearing some of the weight.
As far as the slopes North Country and I have written about...mine's on finished lawn and I'll have an RFM on the 3PH. As you know, RFM's aren't near as long as a cutter, so any sway is reduced (shorter "lever") plus there are 4 wheels on the ground rather then one.
BTW, this was brought up on an earlier post...if you haven't viewed those rollover vids in the Safety forum, they're definitely worth viewing:
http://www.tractorbynet.com/forums/safety/116448-tractor-rollover-demo-pictures-videos.html
(Edit: Unfortunately, it appear those videos are no longer linked. Shame...they were quite enlightening.)
   / Slopes and tractor tilt #133
Yahh but...
Of course. I think one of the earlier questions was about putting the FEL on when mowing - I thought they were talking about a MMM. Adding a FEL to a tractor with a MMM is adding instability.
   / Slopes and tractor tilt #134
Pictures! I tried to hold the camera level, but you can see by the tree trunks in the background I tended to tilt it to make the slope look *less* than actual.
#1 is a 12 degree slope I have to drive any time I want to use the tractor.
#2 is an 18 degree slope. This is about where I start to "feel it" in the seat. I cross this regularly, but really get puckered with any load.
#3 is crossing a root I hate. I go over this very slowly with any load. The front axle is on the root and is pivoted away from it.
#4 is crossing the same root - the rear axle is on the root, and the front axle is pivoted the opposite direction.
Unless the ground is uneven, it doesn't look to me like the front axle pivots.
   / Slopes and tractor tilt #135
North Country, how'd you make out with your pics?
Mine (taken with my cell phone) aren't viewable..too much contrast.
The 4400 is still outside as I have another task tomorrow so I'll try with my digital cam. A beautiful sunny day for mowing, but works against me for taking pictures under the tractor. I took the pics mid afternoon. A morning shot might work (I won't be shooting into the sun).
Anyway, the front axle stops are indented sections of the frame rails (don't try to visualize it...).
Although I could see a noticable angle between the front axle and frame rails, the front axle did not pivot to it's limits (that's the rear axle rigidity coming in to play). Not enough of a slope on my property, or at least where I'm willing to go...to get it to it's limits.
(EDITED: You must have been adding your pics as I was typing my post)
The sentence I bolded is most pertinent. My 4400 did lean...however, my ground is uneven. To me, that should be part of the test since flat ground isn't too common unless it's a golf course green.
Mine, on the slope, appears to be most comparable to your 4th pic (but no root...just the ground). I also notice that the 4400 is quite a bit taller then your 2305...more weight higher up. I also have my loader installed (sans bucket).
Anyway, my (crappy) pics were showing the axle position to the frame rails (basically, under the tractor). I'll take pictures similar to yours (from the front).
   / Slopes and tractor tilt #136
I do like the 2305 for the low profile. It's quite a bit more stable than the others in the 2x20 series, and that's the primary reason it was my choice. The 3x20 and 4x00 were just too big for me. I have a fair amount of acreage but not much of it is maintained.
Uneven ground will make the front axle pivot. It's what it's there for. I tried to find some even ground for the non-pivoting front axle pics.
There's one other way you can get a pivoting front axle on even ground - look at the pics of these tires. Not too hard to guess which is uphill and which is downhill. This was on a 20 degree slope. The uphill tire barely has any tread grip at all.
On a related note, I was at a garden center watching a young guy load bulk compost into my truck the other day. He was using a older 4WD with a 1/2 yard FEL and NO rear ballast. What was amazing is that all the deep tracks in the muck were FRONT tire tracks - the rears were barely touching the ground at all. That's a rollover waiting to happen!
   / Slopes and tractor tilt #137
OK, speaking from experience, which I will relate below, I will always have the FEL attached and don't hesitate to put stuff in it that I need to relocate.
Was planting native grass seeds on a dirt tank, going up and down the slope (not sideways) and turning around on the top of the tank to head back down. FEL inches off the ground(maybe 3 inches), loaded with about 300 lbs of rock.
A moment of inattention and I found myself doing a U turn a moment too late on the top of the dirt tank.... right front wheel went just a tad further down the opposite slope than on previous turns and in a flash the left rear loaded wheel was off the ground. I dropped the FEL further and stopped to survey the situation.
Turns out that the FEL was dug into the ground (the round part, not the teeth) and because of this it actually PREVENTED my rolling over. It provided a point of ground contact further in front of the tractor than the front wheel and with some DOWN FORCE. Thus, it PREVENTED the rear wheel from rising further, thus dramatically raising the COG and preventing allowing/initiating roll over.
Think about it.. for a rear wheel to rise, the tractor footprint rectangle must dip down on the opposing corner. A FEL out there extends that rectangle footprint beyond the front wheel. If close to the ground and dropped/driven into the ground when a roll starts, then it MUST assist in preventing the further rear tire elevation.
I was in 4wd low range, thus going very slow and momentum was not an issue, just balance.
I got out of it by strapping the tractor to my F350 to prevent actual roll over, getting additional help (my son), then SLOWLY turning front wheels downhill while AT THE SAME TIME keeping FEL in strong ground contact with hydraulic down force to maintain some modicum of stability. Ground was loose, thus slid under the FEL just enough...didn't "catch"....I also left the Brillion grass seeder pin hitch attached to the tractor...providing backdrag and some down force on the tow hitch.
Net, my experience leads me to conclude that in my case, with my tractor, in this instance, with me driving and taking the actions described, THE FEL PREVENTED A ROLL OVER.
I will tell you that I had to struggle mightily to dismount the tractor on the uphill side when the tractor was stopped. I have a cab. I truly don't believe there is any way I could have bailed out uphill from a moving non cab tractor. I would consider that move to be a suicide mission in the case I described.
Yes, my experience goes counter to what many have posted here. All I can tell you is that in my case, I WOULD have rolled over except for the FEL and the way I applied it when things went downhill (literally) very fast! Trust me, you DON'T have 1 to 2 actual seconds to take action. True time frame is about .5 second.
With my first hand experience, I will continue to keep FEL on and extremely low whenever I am on uncertain ground. You may decide that you wish to take a different approach.
Stay safe out there!
   / Slopes and tractor tilt #139
The 2305 also appears to have a wider (front axle) track relative to the height of the tractor's hood, although that might just be perspective (you apparently crouched down in front of the tractor).
My 4400's front axle track doesn't appear to be as wide (relative to the top of the hood).
   / Slopes and tractor tilt #140
The FEL both caused you to start the roll and stopped it once it started. 300lbs of rock in the bucket moves the cg way out towards the skinny end of the triangle.
403 (A52706)
403 (A52706)
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
2018 PETERBILT 579 DAY CAB (A57880)
2018 PETERBILT 579...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
