dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,622
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
You could give them some buffer space and make a cage around them with chicken wire, perhaps, so it doesn't plug up with a couple leaves. Might look redneck though.
You could bury them under rip rap, but then clean out would require moving rocks all the time.
You could just screen the ends and check and clean often.
Dig a dry well and put rocks in it, make a shroud over it with chicken wire so the water drains into the rocks and you only need to pull the cage to clean out.
Set a basket into the ground, like a sprinkler valve tub, dig drywell with rocks below it, let drain into the basket through cutouts in the side. Then pop the basket lid to get access for clean out.
Mostly I think you just need some buffer space so it doesn't plug too fast, but maintenance will be required in any case.
BTW - on the other end of this -
If you are going to go to the trouble to do this, on the upstream end, I'd put cleanouts in them right now. Why not save the hassle while you are doing it now?
