making brackets and installing quick attach loader mounted snowblower
   / making brackets and installing quick attach loader mounted snowblower #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
Not sure if anyone is even interested in this thread, but i have been pulling out the hair thats remaining in my head to try and make some removable brackets for threading the twin 3/4" supply hydraulic hoses to my "quick attach" brand loader mounted snowblower.
The manual just says to zip tie them to loader arm...but i don't think so. i really want the paint to remain for a few years at least.
I pondered long and hard and i think i came up with a good overall plan....ill see if it survives next winters snows.
I drew up and plasma cut some 1/4" stock for support plates and found several places on the loader to install them. I had to thread some 3/8" round rod and heat bend the support brackets. I tried some pre-made round ones, but there was way too much slop in the hoses.
The unit has an electrical driven hand control for chute rotation and deflection. The electric current runs a servo that forces hydraulic fluid to move/deflect the snow. pretty clever design really. Operates very fast.
Routing the hoses around the rear tires and still allowing for rear tire chains was also a chore. i hope this takes care of it. Ive tested it thru full range of motion, and the hoses never touch anything......
the snowblower reaches high enough to snowblow my roof :laughing: :laughing: :laughing:
   / making brackets and installing quick attach loader mounted snowblower #2
Wow, quite a set up, nice install ! How wide is that blower ? Looks pretty spendy but should keep your neck from getting sore !
78" wide. ya, after 14 years of driving backwards...enough was enough.
   / making brackets and installing quick attach loader mounted snowblower #4
You are going to get spoiled ! There are times the front calls to me but I would feel naked without a bucket up front ! Most of my snow removal is by pickup and 8' blade tractor and blower if it gets ahead of me .
   / making brackets and installing quick attach loader mounted snowblower #5
Can't wait till next winter for some video of it in action. :thumbsup:
   / making brackets and installing quick attach loader mounted snowblower #6
Wow, that's first class.....Now the wait for summer to be over and back to snow time for the trials.......:thumbsup:
   / making brackets and installing quick attach loader mounted snowblower #7
Boy, you know you're getting old when you get tired of driving backwards!!
And now, you've got a cab too!!!
Actually, that is a very impressive job you did hooking up that front blower!!!!
I expect there'll be a lot of TBNers following suit
Thank you.....i tell you, its taken quite abit of work to design a way to do it. I just couldnt do the zip tie thing.
My back has taken a beating over the years...i just couldnt do it anymore
all the brackets are removable, including the inside control. All will be powder coated this week.
   / making brackets and installing quick attach loader mounted snowblower #10
So, the PTO drives a hydraulic pump which, in turn drives the blower. And the controller clamps to the loader joystick?
That's a very nice rig!!!
How much PTO HP is required for the PTO pump?
And, if you don't mind me asking, how much did this rig cost you?
BTW, the link in your first post doesn't work...I assume it's supposed to be a link to another thread.
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2020 DRAGON ESP...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
