Pelton wheel project
/ Pelton wheel project #1
norbie454
Member
Oxford Hills Maine top-o-da hill
Kioti LK3054
Pelton wheel project to generate power from a stream. The elevation from the small rock dam to the camp is about 60 vertical feet. Should be enough to spin this baby pretty fast, hope to make enough power to run 6 60 watt light bulbs. I am planing to have 2 water jets at 90' apart. More photos to follow as I progress along.
/ Pelton wheel project #2
Have you done you homework to see the that Pelton is big enough diameter wise. Sometimes it is better to have an alt that is wound for low speeds.
/ Pelton wheel project #3
Are you going to be make 120VAC?
What is the volume of the stream?
Is the stream on private or public land because there can be enviromental issues, ie you might upset the mosquito pond down stream.
Craig Clayton
/ Pelton wheel project #5
A pelton wheel will not tolerate a lot of dirt and debris. It will pug the intake and nozzles. If you have 60 feet of fall and open wheel might be a better choice. I also have a stream that flows 40 cu ft a sec but no amount of fall. I did some very extensive research a few ago and I do have a weir in and a 25" dia penstock. As of yet I still have not come up with a way to protect the wires when ice chunks as big as a car come down thru there in the spring.
/ Pelton wheel project #6
This thread reminds me of an idea I heard of years ago where a fella had a stream on his property that had a good amount of fall but no place for any kind of dam to capture any amount of head. His solution was to lay 2 side by side 6 inch pvc or plastic pipes of some kind in the creek bed until he had the desired amount of fall. At the bottom he raised the end of the pipes with elbows into a short sluice box that supplied the water over a water wheel.
Oh my sounds like you have ICE BERGS, I am building this for my cousin he tells me that it will be pulled for the winters. He bought the wheel online he said he paid about $150 for it and the Alternator is new from NAPA. He is planning to place a few rocks to collect a small pool so the water will cover the pipe. The normal flow of water will go over the rocks so the stream flow will not be restricted. It is about a 60 foot drop at 100 feet pretty steep. No fish going up this stream close to the top of a mountain spring fed and rain water run off. Will post photos as I progress, have to purchase metal to complete the project.
/ Pelton wheel project #8
Please keep us informed, you have a very interesting project going. I am certainly interested in it.
/ Pelton wheel project #9
So are you thinking hydraulic..., pneumatic... or ballistic for the ice chunk disposal?
I had the time to make the nozzles today they are threaded to take the 3/8 NPT. The photos were hard to take to show the inside but the ID is tapered at 7 degrees down to .345 at the outlet. I used 1" treaded rod. I plan to have 2 nozzles directed as close to the wheel as I can without touching it. I will post more photos as I progress. I wish I was retired so I would have more time to play with this stuff. You know how it is? enjoy
Took the time to make the bushings that I will weld into the shield of the project. I have one photo assembled and one not so you can see the parts in detail. Will post more when I get the shield completed.
The shroud is now fabricated and ready for machining. I hope to have it assembled in the next week or so. It is made from 10 ga steel a little riggid but should make a good solid base for everything to be attached to.
Fear of the unknown, is greater then fear of the event.
Norm David
1972
/ Pelton wheel project #13
I'm lost here. What is the amp rating of that alternator? In order to get the max amps you will have to spin it at about 5-5500 rpm. With only thirty odd psi behind those nozzles I fear that you'll get not much from that rig.
/ Pelton wheel project #14
I bought some LED lights from Costco. I think they are 2 watts each. I replaced one 13 watt compact floresent bulb with 3x 2 watt bulbs. No need to produce 360 watts to run six lights these days. You could have power to spare to run a small fridge. (I have a 65 watt 110V electric fridge. Approx 3 cubic feet.
Question: does any one know if an alternator needs to turn clockwise or counter clockwise or does it not matter?
thanks in advance
/ Pelton wheel project #16
i built a water wheel for my camp.Alternator would not work.If the batteries went down below 9.9 volts the alternator wouldn't generate power.Alternator needs power to generate power.easier to use a 12 volt or 24 volt motors.you can buy off ebay really cheap.Also an alternator needs lots of rpm's .DC motors generate power as soon as they are started up
Project almost complete just have to build the cover and connect the plumming
/ Pelton wheel project #19
Fascinating project! Thanks for taking the time to take the pictures for us to follow along. I hope that we get a follow-up as it gets installed. It sure sounds to me like someone has done a bit of figuring out on the numbers. Seening things as definite as a 7 degree taper and and 11/32" nozzle orifice in a replaceable nozzle tends to make my head swing around and ears go up.
Did you find out if you can run an automotive alternator backwards? I don't see any mechanical reason other than the built in fan might draw air through backwards...not much of a concern without a hot engine nearby. Electrically I'd have to look at the way the field coil is energized to know. There's a variety of ways to make a generator. Basically it's an electrical coil spun within a magnetic field coil. This field can be either a permanent magnet or a field generated by the alternator itself. Short tutorial: All rotating generating devices generate basically make Alternating Current. Generators use a mechancially-rectifying commutator to get DC by mechanically timing when to pick up the generated pulse, and alternators don't bother to time the pulse because they have rectifying diodes to change the DC to AC. Depending on the design of yours, there's a chance that turning it backwards would reverse the output polarity....which would be OK magnetically except that the diode bridge common to all alternators wouldn't work. So how did you decide which way to spin it?
We are lucky enough to live near a fast-running stream; it doesn't have much of a drop but it would be fun to do more with it. Either drive a small high pressure pump or generate some power.
rScotty
/ Pelton wheel project #20
How much volume, gallons per minute? Sounds like you have the potential to run more than a few lightbulbs. I've been into micro-hydro systems a while and would love to find some land with that stream on it.
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
John Deere 7230 (A62180)
John Deere 7230...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
