Bent a link yesterday
/ Bent a link yesterday #1
Wacky
West Virginia
2010 GC2610
I was using my GC yesterday to help a neighbor roll some round bales yesterday.
It was VERY muddy I had the BB mounted, to level out mom's drive after several storms washed all the gravel to the bottom of her drive. Then I saw the neighbor trying to move 5 round bales onto his trailer by hand:confused2:. I went over to help used the FEL to push them around to the trailer and thought to use the BB for the last one.:ashamed: I should have known, the tractor spun so I turned around and used the FEL and when I got home lowered everything and went in to eat supper. Went out to load the GC on my trailer and heard a pop when I raised the BB. Got off to look and :ashamed:....saw that the left link arm that attaches to the rockshaft arm to the lower link is bent and caused the right lower link to catch the PTO guard and bent it slightly. Nothing else appears to be bent, the BB still sets level and is evenly spaced behind the rear tires. Won't pushing anything w/that again. Anything else I should look for to be damaged? I think that the tires being filled with mud helped to minimize traction on the pavement to lessen the damage. Am going to try and remove the link to straighten after I clean all the muck from the machine.
/ Bent a link yesterday #2
Do you have this kind of luck with everything, or just tractors?
/ Bent a link yesterday #3
Wacky, did you check the housing for cracks where the lower link fastens on?
James K0UA
/ Bent a link yesterday #4
Does the arm have an "s" bend in it to get width enough for attachments beyond the narrow rear end, or was it originally straight? My TZ25DA had those and they were bent many times while using a box drag to push.
Know anyone with a press? Easy fix, if so.
E
:laughing: Everything, I think my family is cursed!
James K0UA
From what I can tell that seems fine, wonder if the link is just soft enough to prevent any further damage?:confused:
It was straight, that seems to be exactly what mine did. Did you have any other damage other than bent links? I seem to remember my fathers old Ford 3000 had bent links also even the adjustable one which rendered it "unadjustable".
E
/ Bent a link yesterday #6
A pic would help to see the problem too. ;) We like pics.
I cold straightened the link, now I need to paint where the paint peeled off. Good as new!:dance1:
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2008 International 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2008 International...
Accu-Line 110V Tire Changer (A64556)
Accu-Line 110V...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
