Loader LA402 Loader
/ LA402 Loader #5
The manual lists the LA-402 weight as 617 lbs / 280 kg
It does not specify what is included in above weight.
In a separate spec. sheet it lists the bucket as 175lbs/ 79kg.
:laughing:sawdust beat me to it :laughing:
/ LA402 Loader #8
sawduster98 and easygo
Thanks so much for the info now I can calulate what weight of trailer I need to haul it
If the rear tires are loaded do not forget to add that too!!! The B-7800 has about 230lbs of beet-juice (rimguard) per rear tire.
A friend of mine almost ended up in a ditch trailering his L-4400. He added up tractor and loader weight but forgot about the loaded tires. Just the tractor and loader were around the limit for his pick-up and the additional 800-1000 lbs of liquid in the tires put it way over.
/ LA402 Loader #9
my float position does not stay in unless I hold it , is there a setting on the joy stick to cheeck?
/ LA402 Loader #10
On back side of valve there is a cap. Remove the cap. Screw inside has probably come loose. Be careful to catch all the parts if screw has come all the way off. Check all linkage to make sure no other screws have come loose.
Hydraulic rail grinder (A61307)
Hydraulic rail...
1100 GAL PLASTIC STORAGE CONTAINER (A63745)
1100 GAL PLASTIC...
STAINLESS STEEL BAKERS RACK (A63745)
STAINLESS STEEL...
LOT OF ANGLE IRON (A63745)
LOT OF ANGLE IRON...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
