Water temp gauge?
/ Water temp gauge? #21
Switch, swap.....that's what I meant!!! But what about possible damage to (already leaking) knuckles etc.?
No no no.
Move the right tire to the left side. And left to right.
The tread will then be going in the right direction.
And you won't have the additional stress of moving the tire's centerline out beyond the wheel bearings, which you would have if you turned each tire around without moving it to the opposite side of the tractor.
/ Water temp gauge? #22
Did you have any thread-type issues? Or are these plug & play? Can you provide a link to where they can be bought?
no plug and play. the second set i bought came with the brass adaptors and fitted perfectly. the first set i had a temp sender adaptor made but the oil sender fitted straight in. it was hard up against the oil filter so i added a 90 degree bend to it and all fixed.the water is M16 x 1.5 and the oil is 1/8 npt
/ Water temp gauge?
No no no.
But......to switch the tires from one side to the other, so that the treads are facing in the right direction, results in the stance being considerably widened, thus putting stress on the knuckles.....right?
Anyhoo, that IS what I meant by swapping the tires!! :) :) :)
And another thing!!! The tractor is running in the 170s after working her. That seems too dang high. I guess all that's left to do would be a radiator flush, a new water pump, or a new radiator. Am I missing anything? :)
/ Water temp gauge? #24
I don't think 170s is to high. Sounds like cooling is doing a fine job.
/ Water temp gauge?
Maybe I'm being too nervous.....I recall someone quoting the engine temp specs between 150-170 as operating temp. I wish I could find out definitively, and stop worrying!!!!
/ Water temp gauge? #26
The thermostat doesn't open on a YM226 until 160 degrees. This is per manual, not my opinion. The warning light comes on from 224 to 235 degrees Fahrenheit. This also is from manual. Not saying I never give bad information but am highly confident your 170 degrees is not to hot.:thumbsup:
/ Water temp gauge? #27
Sorry if I misread the issue and my comments are confusing. In the prior post I thought one objective was to correct tread that is presently pointed in the wrong direction - as well as widen the stance. If this is not the case .... then my comment wasn't relevant.
At any rate it isn't recommended to get the centerline of the tire out beyond the wheel bearings.
/ Water temp gauge?
Don't think my engine has a thermostat. I've read about the warning light temp being boiling. In my experience, once a diesel gets to 200 degrees, you have problems. I once ran a 43' Viking w/Detroit diesels. The DD people told the owner that the engines should not run any hotter than 170.
I had the head gasket blow, and now I'm committed to keeping the engine healthy. Maybe even a little over-zealous!!
/ Water temp gauge? #29
Wasn't really meaning your model had a thermostat, just showing what similiar tractor with thermostat opened at. I respect your opinion and it is sure your tractor and what ever makes you comfortable is ok with me. You may have to install 2 radiators to make it run down below 170 in hot weather with a load. Just joking. Good luck to you!:thumbsup:
/ Water temp gauge?
Two radiators!! Why didnt I think of that?!?!
Anyone (who has a temp gauge) want to weigh in with the temp their engine runs at?
/ Water temp gauge? #31
i will chime in but you will have to convert it from celcius:D pottering around on a 25c day it sits about 85c. working it hard at 25c day or warmer it can rise to about 110c. no matter how warm the day has been or hard i work it i have never seen it go over 110c. i now also think it runs cooler since i replaced the crap coolant that was in it for good quality mix myself stuff rather than the pre mixed junk.:thumbsup:
/ Water temp gauge? #32
25c = 77f
85c = 185f
110c = 230f
/ Water temp gauge? #35
Mine runs 160 f max when its been working awhile but it stays way below that normally it takes quite awhile to get up to temp.
Its got a thermostat I dont remember what temp it is though but it keeps a steady 160 so that must be it.
/ Water temp gauge?
Which model do you have?
/ Water temp gauge?
From the Hoye website: "Your tractor should run at 150 to 180 degrees. The light normally comes on at 220 degrees F"
I'm thinking my machine should not be in the 170s in late April on a fifty degree day, not working her too hard. What happens when it's in the 90's??
/ Water temp gauge? #38
Just got my temperature gauge installed on my YM1700 and did a short test. Air temperature was cool outside (~60 degrees) and I was running a 5' finish mower. It got up to 190 F. I think that's not bad given that this model does not have a water pump, just water convection.
/ Water temp gauge? #39
YM3810D.
I tilled a 5/8 acre garden last nite and worked my tractor about as hard as it can be worked for a solid hour and my temp got up into the 180-190 range after about 40 minutes so I guess thats normal I am not going to worry, this is the hardest its worked since I did the head gasket and valve job etc. fwtw
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
2020 FREIGHTLINER M2 106 WATER TRUCK (A67714)
2020 FREIGHTLINER...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2023 Wallenstein BXTR6438 Towable Woodchipper (A66734)
2023 Wallenstein...
