3-Point Hitch Farmtrac 360DTC 3-POINT HITCH OPERATION
   / Farmtrac 360DTC 3-POINT HITCH OPERATION #1
GeorgeG
FarmTrac 360DTC
I have a Farmtrac 360DTC with backhoe and loader. I removed the backhoe to use the 3-point hitch. The lift arms are up and I cannot get them to move. I don't have an operator's manual. Can someone explain how to work the 3-point hitch, or any ideas why they won't go down??
Also, does anyone know what the two hydraulic control valves are for?
Thanks!
   / Farmtrac 360DTC 3-POINT HITCH OPERATION #2
Thanks!
Below the seat above the transmission hump there should be two turn knobs. One of those knobs is a lock valve that locks and controls the rate of drop on the three point. It is probably in the lock position. The other knob turns one of the auxilary corntrol valves into a single acting rather than dual acting.
The two hydraulic control valves are for auxilarry equipment like top and tilt cylinders. They are operated by the two levers on the right side above the diff lock.
VERMEER FEED ROLLER (A58214)
VERMEER FEED...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
2015 Chevrolet Silverado 3500 Knapheide Service Truck (A55973)
2015 Chevrolet...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A56435)
2019 Cadillac...
116 Gallon Poly Fuel Tank W/12V Pump (New/Unused) (A59225)
116 Gallon Poly...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
