Ripper without box blade
/ Ripper without box blade #1
FredH
Ruch , Oregon
N.H. TC-30
This is a ripper I built after I tore apart a old double gang pull disk . We added the 3 point box frame to the front which sits on top the 6" x 2" x 1/4" channel of the main frame . Next , using my plasma cutter , I cut apart the back end were the gangs / bearing blocks were attached . Then it was just a matter of cutting 15 slots top and bottom into the 4" x 4" x 1/4" tube and welding it the the back of frame . Added the Pin plates on top the frame on both sides of the slots and made my own pins from round stock . Although there are 15 slots , I only pull 8 scarifier's at a time , they are 18" ones from Agri Supply . TC30 does all right with the 8 as long as I go side hill or down hill in the Clay soil we have here .
Ended up adding the two 3/4" braces from top of 3 point hitch down to the back of the main channel as that part had holes on the side from a couple of braces and started to crack .
Have primer on it , just waiting for it to warm up to add color . It has worked awesome though . Use to have to make multiple passes with my 6' KK disk for firebreaks around edge of property and down driveway . But with this , I make 1 pass with it and 1 with the disk . Have recovered many 10" to 20" rocks that the disk use to ride over and also pulled 6 sections of old 10" concrete culvert out .
Fred H.
/ Ripper without box blade #2
that is pretty cool!.. Good build.
Cool Yes , Good Build ???? Please notice the pictures are not TO Close !!!:D
Cannot let others see my welding or maybe my attempt's at welding .:D
Although so far it has stayed together even when pulling up that concrete culvert . My reason for going this route was I have a blade , so I seen no since in getting a box scraper just to use the scarifiers .
Being a truck owner / driver , I try to K.I.S.S. , ( Keep it Simple Stupid . Stupid meaning " Me" ) , thus I like to use my disk rather than my brush hog . Disking is a " No Brainer " type action , just don't run into anything with the tractor . While mowing requires a thought process , which I some times come up short on . Picture below is a section of the back skirt on my brush hog that I had to cut out and replace when my neighbor backed into a tree while mowing , ( Seriously , Was not me that time !! ) .
Thanks for the Compliment , Appreciate it .:)
Fred H.
/ Ripper without box blade #4
Fred H.
Fred Nice build, dont worry about how the weld looks,.. penetration is the important thing, when in doubt,..Turn up the heat,.. and pratice, Eric
/ Ripper without box blade #5
nice job! it looks solid!
a Q, it looks like you have a FEL on tractor. with all the welding that you did. why not pull the bucket off the front. and weld a frame up so the rippers could go on front of tractor?
or perhaps weld the rippers to top edge of bucket. so you could just curl entire bucket down. to a point were the rippers could dig into the ground?
i would assume the rippers and all the welding. was fun and cheaper vs getting say a grapple bucket for FEL. and just use the teeth on the grapple to tear up the dirt?
/ Ripper without box blade #6
Rippers like to be pulled, not pushed Boggen. Think of a trash can with wheels on a gravel driveway. Which is easier for you to move...pushing it or pulling it? Same concept.
Pushing on the loader frame with more force than it was designed for could tweak the arms.
/ Ripper without box blade #7
i just do not bite.
power trac, tractors come to mind. were all implements are on the front, same with skid steer implements.
use of tooth bars and teeth on buckets, to graple buckets, to forks on the FELs. and doing same thing. why would rippers/scarficers. make a difference?
if that was the thing, i surely would be seeing a lot more FEL twisting threads. and tractors over the years just on this farm let alone all the other farmers around me, would be replacing loader arms all the time.
/ Ripper without box blade #9
I like that. I wanted a ripper like that and looked at a LandPride unit. They wanted over $800 for it so I decided I could live without it. I have been thinking of building one. Looking at yours increased my enthusiasem. Nice job :thumbsup:
/ Ripper without box blade #10
Nice job on the build! :thumbsup: I had wanted a ripper for a while and it ended up turning into an invention. :D Jakes Implements - Home
/ Ripper without box blade #11
It will be eually handy in finding phone lines to lol. Its amazing on how much a scarifier will make the ground work faster. One job I was an operator on we had a little 943 Cat track loader It was a good machine but I was set diggin a sun baked red clay haul road out. It ad been used over a year to run 30 ton offroad trucks on. I had to dig it from the top down. The toothed bucket would dig it but not great. I put the scarifiers down and made about 5 passes then could dip it out with the bucket.
Used the same kind on a smalled Kubota tractor the other day and it was a big help.
/ Ripper without box blade #12
I really like using my ripper in gardens before I till them. It really helps get the tiller dig deeper and fluff the soil better. I need to re-build my home-made ripper more like the OP. I didn't put enough re-inforcement in it and it resembles a pretzel now.
/ Ripper without box blade #13
Please see interspersed comments.
i just do not bite.
I don't know enough about niche market tractors like Power-Tracks to comment. Most skidsteers I see in use around here have buckets for digging/loading, or forks for lifting. I don't see any of them doing deep scarifier work.
FEL bucket teeth generally dig in and curl back to break up the dirt. One generally doesn't travel very far forward at any one time with this operation. Those who use forks in a similar manner are generally grubbing something out of the ground (e.g. stump or rock). Grapples are meant to grab things (e.g. brush, above ground rocks & stumps, etc), and I can't picture most people using them for ground engaging work.
Scarifiers are generally meant to break up the soil via continuous pulling through the dirt, not intermittently like a FEL toothbar equipped bucket.
Look at a backhoe, the hoe pulls to excavate, not pushes. Look at a woodworker's spokeshave knife, it is pulled...not pushed. The same for utility knives...and so on.
I suspect that's because not many people are using their loaders with ripper teeth on them.
I know I would enjoy seeing such a device being used successfully without damaging the FEL. A lot of making something like that even remotely possible is going to be the scarifier tooth's geometry being adapted for a pushing operation instead of a pulling one.
Well as per my first post about K.I.S.S. and about removing FEL . We have had our tractor for 9+ years and although it is a quick release FEL , I have never tried . Why ??? Cause more than likely , I would be posting pictures here asking for help on how to put it back on .:laughing:
All the steel was used / recycled from local scrap yard , except for a little of the basic structure that had been the original pull disk .
Phones lines ??? Give me a shovel , a man powered post hole digger , our back hoe , etc...... , and I can find our local phone companies line . I have cut ours several times in the driveway , have found but not cut in field putting in a post and cut about a foot out of neighbors while redoing my corner posts of field fence . Average depth is like 18" . It was all contracted out to a private company so since it usually is never the required depth , ( 36" ??? ) , it is always repaired for free .
As stated by others , ripping it first , then second passing with 3 point kk disk really works up nice so it saves time .
Thanks all for the comments , I appreciate it and also really like reading others ideas or projects .
Take Care ,
Fred H.
/ Ripper without box blade #15
FredH:
You're lucky to have your Telco bury their lines that deep. On the residential lots where I live, it's anywhere from 2" - 6" depending on how quickly Jose wants to get it done with the cable pulling machine so he can get his cerveza. The same goes for Comcrap's CATV lines.
Pictures after adding color and of some items I have pulled out with it .
Ironically , Rustoleum blue is pretty close to New Holland Blue .
Fred H.
/ Ripper without box blade #17
Fred H.
Not to sidetrack your ripper post, but I was wondering, if you really do try to K.I.S.S, then why didn't you just take a piece of solid steel or railroad track or some other piece to act as an anvil and use a hammer to pound the gashed hole back into place, and then run a single bead down the hole? Seems like a lot easier than removing and replacing a piece the size that you cut out.
Or maybe you just wanted to practice your welding skills on the larger piece????
David from jax
/ Ripper without box blade #19
Where can I get a good deal on scarifiers. A local tractor dealer he has them for 53 or 58 dollars. 2' long by 3/4" by 2.5 " . I'm from easter canada.
/ Ripper without box blade #20
Did you ever consider getting some 3/4 x 2 1/2" or 3" flatbar from a local steel supplier.
I used 1 3/8" diameter stressproof when I made mine, The roots and rocks I pulled are unreal, the only limitation I've come up with so far is horsepower and the occasional lack of traction, some pics:
