3320 error code 5
/ 3320 error code 5 #1
tglass
3320 w/cab
this may have already been brung up before, but has anyone had this code come up before? It happens when I hit the cruise control, and after a while with it on, the hyd. (and hydrostatic)go into a very slow mode till the engine is shut off and restarted. As long as I don't hit the cruise it works fine.
/ 3320 error code 5 #2
Err 05 Brake and Cruise Set/Decel Switch. Cruise control Set/Decel switch depressed while brake is engaged. No cruise function. Release brake pedal; Contact your John Deere dealer.
Straight out of the manual. It sounds like an electrical problem, could there be a plug loose? My dad's 3720 has Err 15 and it was just a corroded wire.
/ 3320 error code 5
johndeere3720, kind of what I suspected. Now to find the faulty switch or connector. I'm sure it's located at an easy to locate and repair position. Thanks for the help.
/ 3320 error code 5 #4
If you have the serial number here is a link to the parts catalog which should have the right wiring diagram. :thumbsup: John Deere - Parts Catalog
/ 3320 error code 5 #5
The technical manual adds;
Release brake pedal. Adjust or
repair brake switch. Check 247 Pur
wire and connections for short or
open circuit.
Pemberton Inc 416469 Hydraulic Dual Cylinder Grapple Loader Bucket (A68183)
Pemberton Inc...
2022 CATERPILLAR 299D3 SKID STEER (A65056)
2022 CATERPILLAR...
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
PORTA POTTY (A67714)
2007 FORD F-450 SUPER DUTY BUCKET TRUCK (A67714)
2007 FORD F-450...
2017 Ford F-150 Crew Cab Pickup Truck (A68183)
2017 Ford F-150...
