Tire slow leak
/ Tire slow leak #1
amorey
Kubota BX24
I,ve got a small tear in my front tire of my BX 24, the tire is fairly new so I don't want to replace it. Should I go with a tube or is there a repair kit I could use? The tire goes flat in about 7days.
Thanks
/ Tire slow leak #2
On the inside of the tire, put a patch, then a new tube, and your ready to go.
/ Tire slow leak #3
If its a tubeless tire like mine is, I use a can of fix a flat. Then fill the tire to full air pressure. It lasts a long time and is water soluble for easy cleanup when it does require a tire dismount to permanently patch and fix or replace the tire.
/ Tire slow leak #4
I bought new 6 ply tires a few years ago. One got a slow leak last year...I found a cut in the sidewall, not through to the cords but when sprayed with soapy water little bubbles appeared. Air found it's way through the plies. I put a tube in it.
John
/ Tire slow leak #5
If patch would be easy than yes,but I would also tube it..double protection,for it always seems blow out happens the farthest point.
/ Tire slow leak #6
Thanks
On my l245 I got a tear where a branch tried to tear a hole in the side wall. I put a tube in it and it is still running great after years of service!:)
/ Tire slow leak #7
A few weeks ago TSC had big cans of Slime instant tire repair on sale for $5. I bought a can and used it to repair (6) leaking small tires Saturday: (1) on my logsplitter, (3) fronts on (2) different riding lawn mowers, and (2) on a small generator. I think most of these were rim leaks but at least one, on a mower, was a similar side-wall leak. All those repairs took me a total of 1/2 hour and it appears they are all holding. It all depends on how much you value your time and money I suppose when it comes to how you go about the repair. A tube and patch may be a better long-term solution but would undoubtably take a lot more time and money. I would go for the fix in a can first.
/ Tire slow leak
Tire slime fixed it, also put some shoe goo over the gash, the stuff is amazing the heal rubber on rubber, dries hard too.
/ Tire slow leak #9
best way to fix it with out a new tire is patch the inside of the tire and tube it. next best thing if its in the tread is a tire plug, slim and fix a flat are hit and miss when i have used them.
/ Tire slow leak #10
yep.. I only like slime and fix a flatr for porous rubber.. not actual holes.
soundguy
Giyi BF47 Quick Attach Hay Spear (A60463)
Giyi BF47 Quick...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2019 Caterpillar 259D (A60462)
2019 Caterpillar...
Case 950 8 Row Air Planter (A61307)
Case 950 8 Row Air...
2014 Chevrolet Silverado 3500 Crew Cab Utility Flatbed Truck (A60352)
2014 Chevrolet...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
