Hydraulics Question(s)?
/ Hydraulics Question(s)? #1
hfdfailures
Kubota BX25
I just purchased a Kubota BX25 for doing small jobs around my yard. In my "feeling out" of the equipment, I have noticed that there appears to be a power deficiency in the backhoe implement. Hopefully, someone will shed some light on this for me.
When I am operating the backhoe, I notice that if I try to extend/retract the arm or swing the arm left/right (using the left handle), I seem to have the full power of the hydraulics. The same can be said when I try to curl the bucket or curl the arm (using the right handle). Full power and quick movement.
However, when I attempt to operate the backhoe with both handles, I end up noticing a severe "drop off" in the speed of the right handles operations. An perfect example:
I was digging a hole in the yard and was swinging the arm back and forth between the hole and the pile of dirt from the hole. I was trying to extend the arm and the bucket in one smooth motion, but was unable to do so. It seems as though the hydraulic power for both motions is not equally divided. Has anyone ever experienced this phenomena?
Is this something that I should be expecting given the small size of the tractor I am working with?
Is this a hydraulics deficiency? I have checked the fluid levels and it appears to be adequately filled. Perhaps there is something wrong with the cylinder? or the handle?
Any help with this would be greatly appreciated.
/ Hydraulics Question(s)? #2
The backhoe attachment is power by an open center constant flow system....pump is only about 6gpm...so you cant expect high speed on many cylinders at the same time....
You use control valve to build pressure by restricting the the open center, and diverting part of or full flow to cylinders....
If there is not enough pressure in the control valve, flow will go to cylinder with lowest load pressure first....like swing before lifting the boom...You have to compensate that manually with the control valve for the swing....swing have to go slower to make enough pressure to lift boom.....
Use foot throttle to increase rpm (pump flow) when you demand more flow for simultaneous operation of two or more cylinders.....
/ Hydraulics Question(s)? #3
Why should it be equally divided? Each spool is getting a certain amount, depending on lever movement. If you are feathering one lever and full lever on the other. If using half lever on one spool, and half lever on another spool. they should be about equal, depending on cyl size . A small bore cyl will be faster than a large cyl.
My Case BH has restrictors in some circuits to slow the action.
/ Hydraulics Question(s)? #4
Load pressure in cylinders is what prioritize where flow goes....port to a low load pressure cylinder needs more restriction, to make flow go to higher loaded cylinder....
btw .....who are you arguing with J_J?
It still depends on the load pressure....you have the feather spool that control the lower load pressure....thats why you use restrictors on the easier loaded cylinders...
At the same load force on a small and a large cylinder, the larger one will move faster if both spool valves are feathered the same "distance"...(of course they need to have identical fitting and hosing setup)...Why???
Because the smaller cylinder will induce a higher load pressure....
I am sure this is what you tried to say also, I just explain it another way....:thumbsup::D:laughing::cool:
/ Hydraulics Question(s)? #5
No argument, hfdfailures mentioned something about unequal. and therefore I mentioned the circumstance that would cause that. He may even have restrictors in his circuits.
Thanks for the assistance. I went and asked a mechanical engineer and he gave me an explanation concerning Pascal's Law. I think you both ended up explaining it in layman's terms so that I could understand it rather than trying to digest a lecture of fluid mechanics.
/ Hydraulics Question(s)? #7
Perhaps my common sense isn't working here, so maybe you can explain this. One log splitters with a 3 in cyl, and another with a 4 in cyl, both using the same pump size, and same valve, both levers are fully engaged, which one will have the fastest cycle time?
/ Hydraulics Question(s)? #8
J.J
are these cylinders tied common to the same pump and do they both have an equal load?
If the answer is yes to the above questions then the 4" cylinder will cycle quicker since it can do more work with less pressure.
Roy
/ Hydraulics Question(s)? #9
....an explanation concerning Pascal's Law. I think you both ended up explaining it in layman's terms so that I could understand it rather than trying to digest a lecture of fluid mechanics.
Your "mechanical engineer" proofed that he went through the basic hydraulic class, but he did not get into the "advanced" second stage....LOL...Hydraulics is a mechanical sub science, but takes some extra classes beyond basics to fully be able to explain everything...
When fluid is in motion, one have to pay attention about the Bernoulli's Principle, more than Pascal's Law
Pascals law only applies on confined fluids in NO motion/flow....as soon as fluid start to flow, the internal friction in fluid will come into play and cause what we call "pressure drop" or pressure differential....this pressure drop increases when velocity of fluid increases....
Note that velocity is not the same thing as flow.....velocity is a function of flow and the cross section area of the actual part of the valve/orifice/hose/tube etc...
Pressure is only equalized in the entire fluid confinement when flow is zero.
/ Hydraulics Question(s)? #10
Many times what we think is common sense is just personal sense....:laughing:...
common sense is the sense that the community, "common-unity", agree on....
"common sense" can be determined with a poll.
But since polls are not allowed at this forum or "community", it will make common sense that we can not use common sense here....
...makes common sense??:D
I think we could make a new thread about "common sense"...but it would probably not make sense....:D
/ Hydraulics Question(s)? #11
No foot throttle on the BX's. you need to turn around and move the throttle. BTW, the BX's say when you use hydraulics or pto, you need to be at rated pto speed, the BX's is 3200 rpms which is nearly WOT. I don't use the rated engine speed for the power. I drop it down and use whatever conditions is needed. However I'd say using it at a lower speed, I do notice the issues more that you are describing.
Yes this is to par with my BX24 as well. Nothing is wrong with the tractor, its the way its designed for a small sized tractor.
/ Hydraulics Question(s)? #12
I am glad you are having fun, as the above crap did not make any SENSE.
You did not explain which log splitter would have the fastest cycle time, with zero load. Each having the same type pump and flow and same type valve. Which cyl will cycle the fastest, the 3 in cyl with a 24 in stroke or the 4 in cyl with a 24 in stroke.
/ Hydraulics Question(s)? #13
I think Roy answered that so well, so I was sure it would make sense....
how ever, if these two difeerent sized cylinders are supplepied flow from the same pump, and feed parallel from the same wqork port, the one with the lowest load pressure will move first, and when it stalls, the one with higher load pressure will start moving. If we can ignore the minor impact from difference in mechanical friction, difference in cylinder size have no matter.
My example also applies if the two different cylinders are provided flow from two parallel spool valves that are metered identcally..
If the two different cyls are provided flow from two different but identical pumps, your "common sense" applies, the smaller will move faster as long as no flow is diverted in CV or PRV...
If two diff
/ Hydraulics Question(s)? #14
What a long winded way to say the oil will follow the path of least resistance ..LOL
The OP was asking why his hoe was slow when operating two functions at the same time. This is normal to have this speed drop, if your valve does not have regeneration, many small hoes do not use regenerative valves.
/ Hydraulics Question(s)? #15
Sure know what OP asked for, but another member "widened" the task....
In the quoted blue part below, he tried to explain his problem, the red part shows his five (5 ?-marks) different questions...
Regeneration is interesting.....just so with do not high-jack this thread, why don't you HydroTek, copy and past my questions below into a new thread, and lets talk regeneration there...:thumbsup:
I re-quote part of your post here...
...This is normal to have this speed drop, if your valve does not have regeneration, many small hoes do not use regenerative valves.
1> I assume the valves with regeneration you refer to, is the control valve, or??
2> So what big hoes use "regeneration valves"??
3> What kind of regeneration valves?
4> Used on which hydraulic actuators/functions?
/ Hydraulics Question(s)? #16
Are you and Akkamaan talking about "Series Center" valves (not tandem center) where the exhaust flow from an upstream valve spool is diverted internally to the next spool in-line to accomplish both circuits to operate at the same time..??
IIRC , I have this on my Kubota on the FEL controls to allow both lift & tilt to operate efficiently simultaneously and independently, when using the FEL control I can Lift & Tilt perfectly every time......
I don't remember if it's on the BH control valve (didn't get the schematics with it)
/ Hydraulics Question(s)? #17
Hi Bill!
I can see/read/hear many different definitions of tandem valve, parallel valve, open center valve...some do not even mention tandem valve as a type of valve...I think, not sure, that tandem valve is a term coming from the solenoid valve technology...anyway, it seems not be a strict standard of control valve terms that I can find....maybe someone else have a SAE standard document, or ISO standrad for valve symbols....:confused2:
I am assuming a regular multiple spool control valve, open center to tank in neutral, that have a parallel power core that diverts flow and pressure into each work port on all spools...like on this schematic...
This is how "all" boom and stick crane applications is served when they have a regular fixed displacement pump in an open center system...
A tandem valve setup, priorities upstream control valves over down streams ones, still pump flow goes through the open center in neutral....
Tandem valves do not allow simultaneous operation of cylinders since upstream valve cuts flow from a downstream valve
See page V7 on this Prince stack valve, it explains difference between parallel and tandem...
edit:
I have never seen an application where one cylinders exhaust/return flow, become power flow for a down stream cylinder, but I cant say it couldn't be one. That would connect the cylinders in series....would be interesting to see that schematic....
It have been seen on "synchronized" motors though...
/ Hydraulics Question(s)? #18
edit:
Actually they've been doing this in mobile hydraulics for years......the outside of the valves look the same, hard to tell tandem from series apart....
Here's a look at Gresen SP valves.....
....scan down to the SSK......these have been around for a long time........(notice they are "pressure additive"....sound familiar- ei: some of our PB discussions).......these special cores internally are available from many manufacturers.....
It allows for the exhaust from one spool to power the next spool that is used inline.......
/ Hydraulics Question(s)? #19
Having trouble with the link.....
  • Bul%20HY14-2715-B1%20SP%20SPK%20SSK.PDF
/ Hydraulics Question(s)? #20
Thanks Bill!
Yes, that would be considered a type of "regeneration", similar to having two single spool valves plumbed in series with out power beyond.
This SSK valve, can not be applicable on two functions that both require high pressure to operate, since load pressures will be additive to a pressure higher than PRV setting.
Also if one cylinders stalls, the other one stalls too.
I assume each function can be operated individually.
SSK is only available/possible in a two spool configuration.
How will the rest of the back hoe functions be operated?
Another CV off a second pump, or another CV power beyond?
Power beyond will limit the possibility of simultaneous operation of other functions....
This SSK valve must be designed for a special, but common, "low budget" application??!!
It is also not designed the same as a regular "tandem valve". Should we still call it a tandem valve?
I'd like to see a schematic on an entire back hoe system with that setup....
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A61165)
2015 Isuzu NPR-HD...
Case TV380 (A62177)
Case TV380 (A62177)
72in. Fork Extension (A61567)
72in. Fork...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2025 LandHonor MAP-16-24W Toro-CII Mounting Plate Skid Steer Attachment (A60353)
2025 LandHonor...
2012 Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61569)
2012 Chaparral...
