jinma 224 ground / gage problems.
/ jinma 224 ground / gage problems. #1
TSMART
central florida
jinma jm 224
No gages. Same thing happened last year, so, to find bad ground, I plugged and unplugged all the harness conectors, cleaned with CRC. (after removing insturment cluster panel). That fixed it. Now the problem is back. No gages. Indicator light in dash works (for lights), but no gages. So I did a repeat. Removed the cluster. Unplugged, cleaned, replugged all harness connectors. Pulled all fuses and they are good. None are original cheapies anyway, But no help this time. Ammeter works but thats it. No temp, oil, or RPMs. What's my next step? Thanks.
/ jinma 224 ground / gage problems. #2
I would start by running a seperate ground from the battery - terminal to a gauges ground lug. Do this just as a test to see if it in fact is a bad ground. Seems to me it has to be since all stopped working at the same time.
Chris
If that works, and I don't find the bad ground, could I just use a permanent ground from the neg battery to the cluster? Just wire it?
I made a wire with 2 alligator clips. I ran it from neg battery post and touched just about everything, couldnt get it to work. OK, Then I unplugged the harness connector directly behind the cluster, cleaned, and got the gages back...now only one smalll problem, the battery indicator light is lit. Did I do this while messing with the connector??? New battery and I am not having probs with starting or anything power related.
/ jinma 224 ground / gage problems. #6
If you have one of the newer dash clusters, that light is just an indicator light that your key is turned on (top right on the cluster). A reminder to turn it off and not drain your battery through accessory uses as the pic shows.
Dave
/ jinma 224 ground / gage problems. #7
The red indicator light technically tells you that field current is flowing to the alternator via the voltage regulator, so if you leave it on long enough without the engine running you'll get a dead battery, and possibly toast your alternator.
But as TTTTTT said: "A reminder to turn it off and not drain your battery...".
/ jinma 224 ground / gage problems. #8
You're over-analyzing Bob. In most cases this one is a simple "voltage present" indicator - a bonafide idiot light. Reason being, several years ago many Chinese tractor owners were also first time diesel owners. The fact that the engine is killed with a pull cable caused many of them to forget to turn off the keyswitch once the engine stopped running. Result - dead battery next time they went to start the tractor. Dealers/sellers hit the Chinese with so much feedback on this that in addition to a low voltage/alternator indicator, they added a "HEY YOU LEFT THE KEY ON" light into some clusters as well. I suspect TSMART has one of those clusters.
//greg//
/ jinma 224 ground / gage problems. #9
Greg, the point is moot. But you can trace the wiring if you like to be sure.
Yes, I get accused of over-analyzing :laughing:, it's part of my day job. :licking:
To be clear, tilll now, you turn on the key switch, the battery light comes on, just like in a car. But when the engine kicks over and runs, the battery indicator light SHOULD go out. Till now, thats what it did. It doesn't now..... It stays lit till I actually shut down. And thats the question.
/ jinma 224 ground / gage problems. #11
I am not positive on your tractor but on a car this in an indication of either a bad regulator, alternator, or a short in the light wire itself. When the tractor is running you should see 14-15 volts at the battery. Less than that and it is not charging, more and the regulator is not controlling causing a risk of a boiled battery and is hard on the tractor electrical system.
Just my 0.02
Cleat
/ jinma 224 ground / gage problems. #12
No it shouldn't. These are not cars, they are Chinese tractors with diesel engines and with less sophisticated wiring.
That's what it is supposed to do. Key off - light off.
12345
/ jinma 224 ground / gage problems. #13
From the original problems you had, anything that you thought was working right probably wasn't anyway. Now that things are right when you fixed it up, you assume all the electrical is working corectly. In the case of the newer dash models that is working correctly having that dash light stay on as a warning. Check with one of the dealers such as Chip, Ron, or Tommy, I think you will find this is the case. Any reference to a car or trucks systems doesn't really apply. If you want pull the dash out, follow the wire or remove the contact for the light and see what you get.
Dave
/ jinma 224 ground / gage problems. #14
I think its working fine now. Mine turns the light on as soon as the key switch is on and stays on with motor running or not until the key is shut off.
Chris
OK, I just wanted to be sure. I will take that light on as the new norm and now assume something was not right for the last 484 hours of operation.
Thanks for all the input, folks.
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
2012 HINO 268A 4X2  26FT NON CDL BOX TRUCK (A59906)
2012 HINO 268A 4X2...
2016 Toyota Tacoma Pickup Truck (A61568)
2016 Toyota Tacoma...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2017 ADDCO ROAD SIGN DH100-ALS (A60736)
2017 ADDCO ROAD...
