Backhoe thumb pins?
/ Backhoe thumb pins? #1
Johnny Glenn
Member
88 Ford 555B
Thanks for looking in - I've just finished fabricating a thumb for my backhoe but on the first try out - the 1 1/4 steel pins bent. Not sure what type of steel they are but certainly not strong enough. What type of steel should I look for? Thanks
/ Backhoe thumb pins? #2
I buy bent hydraulic rams at the scrap yard. If they had bad bores or something is wrong beyond repair Ill use the rods as pins. THe 1 1/4 pins on my 12500 pound excavators thumb are made from these and I have never bent one.
/ Backhoe thumb pins? #6
Johnny Glenn,
Can you show us a close up pic of your thumb assembly with cyl attached?
How far apart were the cyl support/mounting tabs, and how wide was the cyl ends. If you put a lot of pressure on the center of a long pin, you could expect it to bend under the right circumstance.
Did you have a clevis, cross tube, or swivel eye on the cyl end.
/ Backhoe thumb pins? #7
Shy of buying hardened 4140 steel material for pin stock, Taylortractornut is right on with the used hyd rods......you won't find any good steel at normal steel places....if you used hot rolled steel or cold rolled 1018 (better but not good enough) then it's not strong for pins....
the rods used for hyd use is pretty good stuff.....
also regarding the geometry...if the ears on your pin bosses are too far apart then the column strength will be compromised and pins will snap.....
Column strength is like comparing snapping a full length pencil in your hands vs snapping a short piece of the same pencil in your hands....
/ Backhoe thumb pins? #8
without pictures it's hard to imagine what you have. With that said a bent pin is better then something else breaking, allways have to look at the bright side:D
2020 Freightliner M2 106 Altec LR7-56 56ft Forestry Chipper Insulated Bucket Truck (A61573)
2020 Freightliner...
John Deere 4044R (A62177)
John Deere 4044R...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61574)
2018 Freightliner...
4' 3pt Disc Harrow (A64119)
4' 3pt Disc Harrow...
2022 Weber CR 5-II HD Reversible Plate Compactor (A61572)
2022 Weber CR 5-II...
3146 (A63117)
3146 (A63117)
