applying roundup to deer plot
/ applying roundup to deer plot #1
merrickvilleguy
Gold Member
So here's the deal ... I ploughed under a fallow field last fall, and left it in furrough. I am looking to plant (broadcast/disk) soybean.
So I know I have to disk it level before planting, but, when should I apply roundup? Never used it before. The seed I have is roundup ready.
Should I disk it level, wait till the weeds come up, then spray, then plant? Or should I disk it level, plant, wait for weeds to come up then spray ?
/ applying roundup to deer plot #3
I would kill everything with off brand glyphosate before planting. Then plant your seeds. The literature should tell you when you can use it after the seeds sprout. I have planted within hours of spraying glyphosate.
/ applying roundup to deer plot #4
Roundup ie glyphosate, generally kills off all plants, Roundup ready means that they are resisant to the effects of glyphosate. You can use it to kill off any weeds growing in the plot before planting then use Roundup to control weeds in the plot after the soybeans reach certain stage of growth. Check with you seed supplier for the exact details.
/ applying roundup to deer plot #5
Roundup kills virtually all living plants. Don't spray it on any plant you don't want to kill. However, once it hits the ground, it's gone. Weeds can sprout as soon as the Roundup dries and will not be affected by the Roundup.
One exception is that you can spray Roundup on weeds at the bases of trees. Roundup will not affect the tree trunk. However, if you spray the tree leaves, you may kill the tree.
Personally, I love Roundup (and the generic knockoffs) and use a lot of the stuff.
In the Deep South most landowners regard it as a necessity. I don't waste Roundup on cool season weeds which usually don't amount to much. I wait until the daily high temperatures are in the mid 90's F and the warm season weeds sprout. The remaining cool season weeds will die on their own and the Roundup can deal with the much tougher warm season weeds.
/ applying roundup to deer plot #6
For food plots I disc it, spray it and then plant corn and soybean. The weeds are usually unable to get a foothold before the bean and corn take over. As others have said your seed supplier should have pretty specific instructions. JMHO
/ applying roundup to deer plot #7
I don't think you understand the concept of round-up ready seeds. That means you can spray the plot after the soybeans have come up and not hurt them. You most assuredly paid extra for the RU ready seeds so you might as well spray after the plantss are up. I have sprayed over the top of round-up ready corn plants for years with great success. RU ready seeds have eliminated the need for higher priced over the top chemicals that were only specific to certain weeds anyway. It can be nerve racking to spray RU directly on a crop you planted, but trust that the RU will not hurt RU ready plants.
I understand that, my concern was that the weeds already in the soil that are getting disked in prior to seeding will over grow the soy ?
I usually just plow/disk the crap out of things and then plant ... so this is kinda new to me (using chemicals to kill weeds)
/ applying roundup to deer plot #9
As I said in the previous post I find that planting corn with the beans and spraying before planting tends to keep the weeds from growing. Others I know just plant, wait for the weeds and spray -- this approach might be cheaper in that I might have to do it twice and they might not but so far we have only sprayed once in either case. I suppose you could use the spray later approach only if you get too many weeds and you already have the RU ready seed. This year I plan to plant ordinary corn and beans in a plot just to see if I really need the added expense of RU and RU ready seed.
/ applying roundup to deer plot #10
Disk, plant and when the weeds come out... spray with Roundup. Disking is the poor man's way of killing weeds so if you have extra money, feel free to spray before you disk to kill them twice...
If you are doing no-till, use roundup before planting as a burn down and give the seedlings less competition once they sprout. :2cents:
/ applying roundup to deer plot #11
if it's just small weeds when you're ready to disk, you'll be fine. If they're so large that you can't get them chopped up and tilled under with the disk, you'd better off to spray, let things die, then disk.
I'm assuming though that you'll be able to disk things just fine. In general, starting with a clean seedbed, plant, then be prepared to spray within 21 days after. By that time you'll have a good portion of the weeds up, and if sprayed around that time, should be able to get crop canopy before more come. Somewhat depends on how nasty the area was before. May have to spray 2x over the top of the beans. Glyphosate is a contact herbicide though. If it doesn't contact a weed, it won't accomplish anything.
Ya there arent many weeds right yet ... the field was ploughed in the fall so its all pretty rough, have to disk it level at some point prior to planting, which should kill what comes up in the furroughs
The seed guy suggested the same deal, disk it level, spread seed (i don't have a planter so I'm just using a spreader), disk it easy and spray after a couple weeks when ya have growth.
/ applying roundup to deer plot #13
That makes sense. Disking now will kill allot of weeds that are growing, but it will also allow some seeds to germinate that may have been deep. I have read that some seeds can last for over 20 years in the ground until the right conditions are met.
FWIW, I bought some roundup at wally world Friday, while reading the label , it states, "Do not apply in the drip line of wanted trees" or something to that effect.
/ applying roundup to deer plot #14
I put beans in every year. Spraying before does nothing. RoundUp is a "kill on contact" type of herbicude so you need to spray the actual weed and not the ground.
I would disk up the plowed field. Plant and then spray in about 4 weeks. Others use a 4" reference point. If the weeds get to be 4" high, it's time to spray. Good luck.
/ applying roundup to deer plot #15
What he said. You may need to spray a 2nd time if the beans don't canopy before the next round of weeds come up. They recommend you use a quart to the acre but I have gotten by with smaller weeds at a rate of 20 ounces to the acre. I plant several acres of roundup ready soybeans every year.
/ applying roundup to deer plot #16
Neighbor is a full time farmer and he plants Round-Up Ready soy beans and corn. He sprays the beans when the weeds start coming up about 6" over the beans. He only sprays once a season.
/ applying roundup to deer plot #17
With roundup beans 2-3 applications is often neccessary for complete control , Depends what you expect !
/ applying roundup to deer plot #19
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
Wolverine Quick Attach Dozer Blade (A66285)
Wolverine Quick...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2009 EZ-GO GAS GOLF CART (A63276)
2009 EZ-GO GAS...
(12) sets of Yetter trash wheels, Coal Valley, IL (A65640)
(12) sets of...
