Deere 4720 capabilities
/ Deere 4720 capabilities #1
Tritonman
Gold Member
I am dealing on a 4720 and am curiousm about the limits you guys have pushed it to. I am talking about how wide of disc etc how big of mower
I habe a four row planter i want to pull with it that recommends 50 pto hp so i will be pushing it there
I have a 3320 cab for sale if anyone is interested
/ Deere 4720 capabilities #4
The smallest Hp 5000 series will probably be less money than the 4720. You'd get a bigger frame, more weight, and about the same power. Look at it quick, it could be an eye-opener. Apparently you don't plan to mow your lawn with it, so get the Ag tires. The R4's are not good for ground-engaging work such as discing.
/ Deere 4720 capabilities #5
For what you want to do I'd be looking at the 5000 and 6000 series tractors -- heavier and more hp depending on model.
/ Deere 4720 capabilities #6
I have a 4320 with R4's. I pull a fairly heavy 8ft. Priefert 24x20 disk, and it does well. However, in soft dirt with the disks burried, it's about all the tractor wants without beginning to struggle. I also use a MX-6 rotary cutter. In 90% of situations, it handles the MX-6 with ease (although it can make the front end a little light). I would love to pull a 10ft rotary cutter, but I think 40hp at the pto is pushing things a little. Your 4720 should handle a 10ft pull behind rotary cutter fairly efficiently unless you are in real heavy grass. I also think the R4's will limit your abilities vs R1 tires. I can't advise about planters because I have never pulled one.
Its a 2008 450 hrs cab radio five hydraulics top n tilt rear lights 60 in belly mower and choice of ag tires or turf cx loader pallet forks. 24 thousand in north dakota hood guard on it also. Basically perfect
/ Deere 4720 capabilities #9
i know someone who lost a 5000 series tractor to a fire and replaced it with a 4720. He was disappointed with it and now wants a bigger tractor.
/ Deere 4720 capabilities #10
What size 5000 series tractor, and what tasks was he expecting the 4720 to perform? The larger 5000 series are definitely in a different league than the 4720. However, the smaller 5000's, although much heavier and better for ag applications, will have similar HP.
/ Deere 4720 capabilities #11
What size 5000 series tractor? The larger 5000 series are definitely in a different league than the 4720. However, the smaller 5000's, although much heavier and better for ag applications, will have similar HP.
I think he had something like a 5325, it was an odd model number. But i would look into the 5000 series, especially if you plan to do some pretty heavy work, the 5000 series will be more up to the challenge. :)
/ Deere 4720 capabilities #12
The 4720 has similar HP to a 5325, but the 5325 is approximately 1 ton heavier!! That, combined with R1 tires vs R4 tires on most 4720's, the 5325 will DRASTICALLY outwork the 4720 with ground engaging tasks and handling heavier attachments.
I pulled the four row planter with my 3320 for a trial, knowing that it would not have the oomph needed and it would pull it just fine. When I turned the PTO pump on though, it was not enough.
/ Deere 4720 capabilities #14
i would have to say although never driven a 5000 series, they hydro on a 4720 makes it a very handy tractor that would be hard to beat. the 4x20's are very user friendly. you can size a mower and disc to fit and you would have a great package, it'll pull that planter no problem. i think a newer 4720 is about twice the hp as a 3320...
I know the 4720 will pull it fine. The get to be heavy all loaded down with fertilizer and no till. Most of my planting is on flat land
/ Deere 4720 capabilities #16
I agree that a 5000 series may be a better choice for you, for a couple of reasons. The larger frame size is more appropriate for 4 row equipment. Higher weight will provide more tractive force for ground engaging tools. It is very likely that in an ag situation the advantages of the compact tractor are not needed. Larger tractors such as the 5000 and 6000 series tractors are more appealing when their primary use is on one property or adjacent farm properties. These are still medium sized tractors that are heavy enough to get some work done.
Where the compact 110tlb and 4520 I have come in handy are moving between sites several times a week, close quarters work where larger machines are hard to fit and additionally need to be agile. The 4720 with ehydro is easier to jockey around than a 5000 series.
I would choose a tractor large enough to handle the highest load implement anticipated.
/ Deere 4720 capabilities #17
Very good info and advice - IMO.
radman1 has a number of posts here on TBN regarding his experiences with his cabbed 60hp, 4520 and a MX-8 rotary cutter. Long and short - he was somewhat disappointed with the 4520's capability to handle the MX-8 in heavy material.
Of course, everything depends upon the work YOU have planned. Number of acres, type of work - just mowing brush and planting a few food plots - or more extensive Ag projects like full-blown hay production and row crop production.
If that's the ultimate direction you're headed - you'll be money ahead - to move up to a 5000-6000 machine.
A fully optioned 4720; wheel weights, cab, etc. etc. is only around $10K less than a fully tricked out, top-of-the-line; 5075M with cab, etc.
I know... I just bought a 5075M.
Best of luck with your decision.
AKfish
/ Deere 4720 capabilities #18
I have pulled a 10 ft wheel disk and a 10 ft field cultivator with a 4700 and it handled it fine. I would think it would handle your planter you are talking about. I am planning on buying a 4 row in the future and using it behind the 4700. I attached a pic of the disk and tractor
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2022 John Deere RD40F Draper Head (A63111)
2022 John Deere...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
