Feguson TO30
/ Feguson TO30 #41
yep.. deciding factor is what it does with him manually controlling the intake / exhaust valve linkage.
soundguy
/ Feguson TO30
Had a buddy of mine give me a shop manual this afternoon. Plan is to print off the last couple of posts on this site, sit down with the tractor and have a serious talk!
One other note, I talked to the guy that I bought it from off of craigslist and he indicated to me that the lift worked great until we had that snap of REALLY cold weather here in central Oklahoma, low teens to be exact. He was plowing snow with the box blade when the lift quite working. Would that give me any clues?? The inside of the compartment is really clean! It appears that it has been really taken good care of!
I will let you know what I find out. Thank you for the help!!
/ Feguson TO30 #43
if water had been allowed to freeze in it it could have cracked the pump.. not sure that's possible while it's running.. too much friction and the oil would be warm.
If the control valve is moving full range.. my next guess is a relief issue, and / or a plugged exhaust valve.
next would be bad pump pistons and chambers.. IE.. wore out..e tc.
soundguy
/ Feguson TO30
I have been looking through the shop manual and I am not seeing anything about an exhaust valve. Is it part of the pump? Is it call something else? How bout the linkage? Is it called something else?
/ Feguson TO30 #45
of course it's part of the pump :)
the pump is it's own self contained unit with a control linkage in the front. it has an intake and oil exhaust port as well as a pressureized output in the corner of the base plate.
the shop manual SHOULD have a fluid circuit diagram and a exploded view of the lift parts as well as the pump. the parts manual sure has the exploded diagram etc.
soundguy
/ Feguson TO30 #46
If there was water in the oil and it got below freezing, it's possible for the waterto freeze and cause a problem. But you would generally see some leakag e coming out of cracks, etc. But if the tractor was working when the lift failed I doubt it had anything to do with freezing. If you do the tests I've outlined and the pump checks out, then your linkage is the problem. If the pump doesn't lift with the valve manually placed in the lift position, then its pump/control valve problem.
/ Feguson TO30 #47
The exhaust port is opened and closed by the control valve as is the lift port. It internal to the pump.
The linkage consists of the external control spring and it's associated internal fork which is almost horizontal and is pinned to the vertical control fork There is a spring that attaches to the vertical control fork and the lift cylinder. The vertical control fork is hinged about a third of the way from the top. The lower end of the control fork has sockets and these sockets should be on the arms of the "T" of the control valve stem. I hope that gives you an idea of what you should be seeing.
/ Feguson TO30
Today's observations...........if we are talking about the same thing, I believe that it is a linkage issue. Had the tractor running with the PTO engaged, and again, no visible leaks.........I did notice though that the control fork would NOT move with the PTO engaged. It did move freely without the PTO engaged. Wht do you think??
/ Feguson TO30 #49
The linkage should be unaffected by pto operation.
I presume you checked the front vertical pipe that supplies the lift cylinder and it had no leaks. Did you do the checks I asked you to do? What were the results?
/ Feguson TO30 #50
yep.. we need to know what happens when the control valve is manually manipulated... move back, then start up.. observe.. etc..
soundguy
/ Feguson TO30
Sorry to not explain a little better............did all the checks Jerry suggested. No visible leaks at the lift, pump, or stand pipe.
Can't explain it, but when the PTO is engaged, the control fork will not move either manually or by the control lever. Like something is bound up in this area.............
/ Feguson TO30 #52
move it then engage the pto.. just for kicks.
if pressure is binding it.. I'm thinking the valving is plugged up or stuck in it's bushing..
/ Feguson TO30 #53
Did the lift raise when you pushed the control vave forward then started up the tractor and engaged the pto?
/ Feguson TO30
The lift did not raise........if you will recall back to the beginning, this chat started because when the PTO was engaged, the lift came up all by itself regardless of the position of the control lever...........I did notice though that where the control valve hooks to the 'T' it is bent upward.....is this normal or should it be straight? This may be preventing the control valve from funtioning properly.........
/ Feguson TO30 #55
The control valve stem should be straight, not bent. Sounds like you have a damaged control valve. Where you able to push the control valve forward and have the lift raise when you started the tractor with the pto engaged?
Does it look like someone tried to remove the lift cover? The control fork and the control spring fork both basically move fore and aft( the conrol fork actually pivots so there is some vertical movement but the valve stem also pivots so it won't bend the stem.) The way the linkage is designed there is no way for the control valve stem to be pulled upward except by pulling the lift cover up. People often try to remove the lift cover without following the shop manual instructions.
/ Feguson TO30 #56
i agree.. some one likely tried to remov ehte lift cover without seperating the ford from the valve.. and bent it. it may be binding.
I too would like to know, if manually moved into positin then started with pto engagfed, if the lift comes up.
soundguy
/ Feguson TO30
Yes, the lift did work correctly when the control valve was manually moved into position. I have already ordered a new control valve and I think that while I am in there, I am going to replace the relief valve as well along with some gaskets. Once all is put back together, I will let you know the final outcome. Thanks for the help guys!!
/ Feguson TO30 #58
take the pump apart and clean it.. migth be full of grit sticking the valve.
/ Feguson TO30 #59
Your did the right thing in ordering the control valve. It sounds like the pump is OK. Good luck on the rest of the job. You will have to pull the pump to replace the control valve.
/ Feguson TO30
Final chapter.........to make a long story short, when pulling the pump to replace the damaged control valve and install a new relief for good measure, something just did not look right with the control arm. Not sure what the correct terms are, but on the control arm pivots at two points on each side of the drive shaft. Like I said, something did not look right so I went to shop manual and sure enough, the control arm had been reinstalled (by someone other than me) backwards. There are two stops that need to go on the back side of the control linkage, not the front as is indicated in the shop manual. Got her buttoned back up, filled with fluid, attached the box blade...................good power!!!! I feel like I can lift the Empire State Building!! Thank you for all of your suggestions and advice. Happy tractoring!
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
1143 (A63745)
1143 (A63745)
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
2022 EZ-GO ELITE...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
