Any ideas for a fire pit??
/ Any ideas for a fire pit?? #1
HCJtractor
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I would like to build a nice fire pit to sit on my concrete patio. I saw some cool ones on welding forums. One used a large cast iron "bowl" from a quarry. Another used some sort of brake drum. I would like it to be big enough to hold 20" logs or so and deep enough to contain them. You know, something 5 or 6 people could sit around on those cool nights. Any ideas what I could find to use for the drum? Are any brake drums this big? I need to dig around at a scrap metal yard. (Creating this would help justify my welder purchase for my wife!)
/ Any ideas for a fire pit?? #2
Just make raised area with an edge using concrete blocks, the centre filled with sand and all topped of with concrete sidewalk blocks. Gives a nice flat area for elevated fire and to sit around. :thumbsup:
It's a little different concept but once you have a chance to see a raised fire hill in action on a nice summer evening you may change your mind.:):)
/ Any ideas for a fire pit?? #3
I've got a traditional cut stone ring style fire pit, but I'm getting ready to relocate it further away from the house. We haven't used it because every fire pit I've been around always had way too much smoke on one side or the other-usually the side I'm sitting on. So I'm thinking of constructing a metal cone with a chimney tall enough hoping to draw the smoke away and above folks standing around the fire pit regardless of the direction of the wind. Like you, it would give me a chance to practice my welding skills and impress my bride!
I'm thinking of having the cone be on metal poles (3 or 4) which would set on the inside of the rock ring, and possibly use expanded metal screen with a door section to load the wood.
Also would like to put a propane burner in the bottom with a quick connect hose and fitting to make it easy to start. From my fireplace experience, I think it would help the fire pit draw/draft better depending on the wind.
I'm interested in hearing what other TBN's are suggesting for your project.
GGB
/ Any ideas for a fire pit?? #6
HCJ Tractor:
What I use is a discarded pressure tank for a well system. Just go down to the local shop that provides well services, pumps etc. They will likely have a graveyard full of them. The old style ones have a metal base, the newer ones are now on a plastic base.
Buzz cut it off to the desired height, remove the rubber bladder, cut out the big bolt on the bottom, drill about six half inch holes around the edge near the bottom, install a grate (weld it in), cut down a portion of the top about six inches down and about 20 inches across to put in the wood while the top grate is on when cooking your steaks!!
They work great, they are free (with a bit of cutting) and with the metal stand are moveable when lit and it dosen't mark the grass. I even drilled two holes at the top on either side so I can move it with bale hooks when the wind changes!!
Fred
/ Any ideas for a fire pit?? #7
I like the chimney idea -- anything that reduces or redirects smoke is a great idea.
Sort of reminds me of those Mexican outdoor fireplaces, made of terra cotta.
I helped a friend install one a couple years ago -- his was a metal ring about 40" diameter, maybe 12" high just set in a pit in the earth. I dug a trench with the backhoe so he could put in a drain to lead rainwater out of the bottom of the pit.
/ Any ideas for a fire pit?? #9
They had those last year at Lowes
/ Any ideas for a fire pit?? #10
what ever way you set it up. make it easy to remove old ashes via old flat ended shovel. and dealing with water.
as far as something to place logs on. i would suggest some rebar. 3/8" to 1/2" for creating a grating, with some legs on it, those coals can get fairly hot. and with enough weight can bend or even warp many gratings.
i would suggest some way to allow air in, low on the side or in the bottom if unit is being held off the ground via some legs.
folks have made many 55 gallon steal drums into wood burners.
at another house, i put in a fire pit next to a lake. and ended up digging down i want to say almost 2 feet. put some rock in bottom, and then placed concrete 8x8x16 blocks into the ground. then used some concrete and stones to create a ring around it.
there was some water issues that had to be dealt with, and wanted a nice hard bottom that could be scraped with a shovel to clean out. and also wanted a sturdy side that could be stepped on. to clean it out.
the rocks in bottom and concrete blocks, were more like a DIY make shift french drain for the fire pit. to deal with water.
in my moms cabin, she has a old wood burner. that has 2 spots on top like hot metal plates. to cook on. works out pretty nice like a 2 burner stove.
/ Any ideas for a fire pit?? #11
Contact a telephone or electrical utility contractor crew foreman and inquire about used manhole rings. Yes they are heavy, but will last a long time. I know several guys who have them and have had no issues, other than manhandling them initially due to their weight. :)
/ Any ideas for a fire pit?? #12
I saw a couple of combine rims on Craigslist for $200 in Marshville, NC (Charlotte). They would make good ones.
/ Any ideas for a fire pit?? #13
I built a fire pit a few years and couldn't find anything big enough for what i wanted. I ended up having a friend who is a welder fabricate a 6' ID steel ring and layed the block around it. It worked our really well. I think I paid him around $125.
I had posted a thread on here a while back and showed the ring, a few steps in the process and the finished pit. We are happy with it.
/ Any ideas for a fire pit?? #14
Like Sandlot posted earlier use a discarted Washing machine drum, they work great.
Remember: Fear of the unknown is greater then fear of the event.
Norm David, 1973
Actually, I looked at those yesterday at a local pipe company. Those looked ideal, although heavy. I may try to find an old one or price a new one. I will also have to check out the washing machine drums and the combine rims. All good ideas. Yes I know I could buy one, but I really want an excuse to weld something!
/ Any ideas for a fire pit?? #16
I think most here are missing the part about.
The washing machine tubs work great for this and are portable.
/ Any ideas for a fire pit?? #17
If you want something bigger than the washing machine tub my brother got the tub out of a commercial clothes dryer to use for a fire pit. Bigger than the wash machine tub, stainless steel and hundreds of small perforations to let air in. I think he just set it on the ground but you could make a base and a chimney cone for it if you want to do a bit of welding.
/ Any ideas for a fire pit?? #18
I made a nice fire pit out of the end of a propane tank. Got it at the scrapyard, recut it to be more like a bowl. Welded pipe on the bottom. Looks like a goblet. I call it the Goblet of Fire. It's a big boy - 40 inches in diameter - only cost 27 dollars, 180 pounds. The smaller residential tanks are about 30 inches across and would make a nice smaller pit.
/ Any ideas for a fire pit?? #19
I made mine out of a 4' diameter tank end. A weld on dome.
I wrapped the rim with 3/4" black pipe and stood it on (3) 1 1/4" pipe legs about 1' long.
It looks like a 1950s UFO or something, but works vey well and will last a lifetime.
I C clamped the end of a length of 3/4 pipe to the rim of the bowl and then rolled it along to bend the pipe around the rim. As I got all the way around plus about a foot, I welded it on and sliced the ends to make a perfect circle.
I've spent a lot of evenings with friends, tilting a few and throwing an occasional chunk on the fire. I just haven't figured out a good way to make a screen cover.
/ Any ideas for a fire pit?? #20
This thread needs many photos, especially guys with the homemade pits. I'm very intrigued.
Kivel Quick Hitch Mini Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2152 (A65055)
2152 (A65055)
2495 (A65055)
2495 (A65055)
FORD 3 BOTTOM PLOW (A64278)
FORD 3 BOTTOM PLOW...
2023 Tesla Model 3 Sedan (A64557)
2023 Tesla Model 3...
