What would you change?
/ What would you change? #1
Johndeere3720
Padawan Tractor Learner, Advertiser
NW Oregon
Bobcat T650, MT55, E42R, E10, John Deere 4410, 4200, x500
What would you change if you were the one behind the design of your tractor? There are a lot of simple things that i can think about but i can say that i wish my YM169D had a 3rd range in the tranny, a reverser and a little bigger engine.
/ What would you change? #2
Over build them like they used to do. Kind of new old iron.
/ What would you change? #3
I wish my manual tranny had synchros. I have to shift it just right to avoid grinding. And a bit more power in the bucket would be nice too, but not necessary.
/ What would you change? #4
A tool box a cup holder a place to store my chain an inline coolant heater a cab with heat and ac
A little more speed for over the road transport
A radio
More lights fo night work
/ What would you change? #6
I'll name a few:
3 range tranny,
Faster speed in high range,
3-point that is easier to install after removing BH.
and a bunch of little things...for example: The pin that secures the FEL parking stand is a real pain to remove...:mad:
/ What would you change? #8
Shorten the distance from the bucket hinge pin to the front axle by 15+%. This would make the tractor/loader more compact.The tractor would be easier to maneuver in tight areas like indoors or in the woods. Also the lift capacity would increase without changing the load/moment:confused2: on the front axle.
R-1 tires for the 3540 that are proportional in size to the tractor. 11.2 rears/7.2 fronts are the correct size for a 25hp., not 35hp.
/ What would you change? #9
Separate the 3pt hitch and the MMM so one can work without the other moving also.
/ What would you change? #10
Insulated cup holder that allows my drink to stay vertical regardless of the angle the tractor is at.
More lift capacity with the FEL and better digging force with the BH.
Tilt Wheel
3-point hitch that does not have to be removed when the sub-frame BH is on.
Our tractor already has 3 range tranny.
/ What would you change? #11
i would make 2 small changes to any new tractor built.1.is a 20 gal fuel tank on all tractors over 50hp.2.is a bigger floorboard,im fairly big 5`11 225lbs an my belly hitts the steering wheel as i get on an off the tractor.an the deck isnt big enough to turn around on to get on an off of the tractor.
/ What would you change? #12
I guess an 18 hp with a shorter wheel base is out of the question?
/ What would you change? #13
My MF-1260 has a 4 range tranny with synchro (16 gears forward and 16 in reverse) so no complaints there. At 40 HP, its a good compromise between power/lift, size and fuel economy. I wish it had rear hydraulic remotes. Oh, and a place for a tool box.
/ What would you change? #14
here about 2wks ago i went to look at a 24hp hst lawnmower.an let me tell you is was real tight as i was getting on an off,an my belly was hitting the steering wheel as i sat in the seat.
/ What would you change? #15
1) I would give the FEL more lift capacity, up to around 1500lbs or so.
2) Make the tractor heavier.
3) Add a tool box.
4) Add a fire extinguisher.
5) Better seat suspension.
/ What would you change? #16
Greater range of seat adjustments. Farther forward and down so the kid can run it and higher up and farther back for me. High volume hydraulic connections on the loader for FEL mounted front attachments. More power, more traction, greater hydraulic capacity, larger fuel tank and 100% greater fuel economy.
/ What would you change? #17
I do a lot of bush hog work, some of it is fairly over-grown at times, I would like to have a skid plate under the front to protect the bottom of the radiator,to keep shrapnel from getting up in that area
/ What would you change? #18
A get off the tractor button. I would love a switch that would secure the tractor with one button. How many times have you wanted to hop off, but you have to step on the brakes, lock the parking brake, put the tractor in neutral, throttle down, get off grab the one thing and then reverse the whole process.
I have been doing a lot of underbrush clearing lately and I have a lot of wild grape vines growing in the woods. These are not the edible type of grapes but instead just long 1 to 2 inch thick vines that can be 100 feet long and need to be cut up because otherwise then tangle up and just pull everything out of the bucket as you try to back up.
I would love this for my zero turn mower too so I could quickly hop off, grab that one piece of trash and get back on.
/ What would you change? #19
personally i use the fel as the parking brake.i just let the loader down an get off the tractor.
/ What would you change? #20
More mounting points and surfaces for accessories like a tool box, auxiliary lights, chain boxes, etc. - and an easy change 3-pt, hydraulic top link, and rear remote as standard equipment.
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2014 Wanco FD-304 Folding Solar Towable Arrow Board (A61572)
2014 Wanco FD-304...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
Mini rock grapples (A61567)
Mini rock grapples...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRACTOR (A59911)
2014 FREIGHTLINER...
2016 Deere 180G (A60462)
2016 Deere 180G...
