Rotary Mower for CK20s
   / Rotary Mower for CK20s #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
Will a CK20s handle a 5' rough cut rotary mower or do I need to stick with a 4'. Will be used to cut pasture and around edges of large fields, probably nothing bigger than an inch sapling.
Thanks
RSKY
   / Rotary Mower for CK20s #2
Thanks
RSKY
We stock the 38, 42 and 48. The 48 will be a handful in tall growth. Ken Sweet
   / Rotary Mower for CK20s #3
I have a 4' woods cutter on mine, and my CK20 handles in just great. Never hit too many saplings over 1-2 inches, but it takes out scrub rose bushes 6' tall, and other weeds taller than me with no problem. Can't imagine it wouldn't handle one more extra foot, maybe not of the heaviest duty kind, though. Most likely the weight of the cutter is the deciding factor, not the power to cut things, though, since weight goes up quickly on bigger models.
   / Rotary Mower for CK20s #4
I have a 5 ft woods heritage mower that I cut 50 to 60 acres a year at various locations including a couple of 10 acre lots. If the going is real tough with the hydrostat you just ease up on the pedal.The 4 foot would work all the better but is a little narrower than the tires. Gary
   / Rotary Mower for CK20s #5
I have a 5 ft woods heritage mower on a ck20 that I cut 50 to 60 acres a year at various locations including a couple of 10 acre lots. If the going is real tough with the hydrostat you just ease up on the pedal.The 4 foot would work all the better but is a little narrower than the tires. Gary
   / Rotary Mower for CK20s #6
I have a 4 foot hog and I can take a 4 or 5" pine out no problem it is awesome in brush cause you can keep the rpm's up. for the feilds I use a 5 foot finish mower much cleaner job
   / Rotary Mower for CK20s #7
I used a 48 inch Bush Hog rotary cutter and a 60 inch RFM on mine. You could use a light duty 5ft hog but you'd be going real slow in thick grass. If I were to do it again I'd still get the 48 inch cutter if I were handling any brush clearing. If it is just for pasture mowing and you mow frequently, especially in the spring, then I think the CK20 would handle a 5ft light duty hog.
2016 Freightliner Derrick Digger Truck (A55973)
2016 Freightliner...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
Hays LT1 Tender (A56435)
Hays LT1 Tender...
