for sale, trencher
/ for sale, trencher #1
rmcconnell
PowerTrac PT422
I have a PT422 that I bought the trencher for. I did one project with it and it has just sat. Anybody interested in buying it? I bought and put the wider teeth on it. Location is Pittsburgh.
/ for sale, trencher #2
pictures, specs, price please
I'll have to get some pics together. For price I'll do 1/2 new. I believe that the retail is $1900 so $950.
/ for sale, trencher #6
Here is a picture. 6 in wide trencher, 8 GPM, 4 ft deep trench. You can swap the teeth around for a 4 in trench.
/ for sale, trencher #7
3 feet deep for t8 quick plate the 422 or 425
/ for sale, trencher #8
Did some one cut off 1 ft off that trencher? Yep, you are right. I thought they were all 4 ft.
My trencher is a 4 footer, and it is almost worn out, chains and sprockets. The repair is upwards of $650, so don't know if it is worth it. The hyd motor could be used for something. Just looked at the replacement trencher for the PT-1445, and it is $2600. I still have the wheeled trencher/stump cutter.
I wonder if the sprocket and chain can be reversed, then the links would be striking the other side of the sprocket, which has no wear. Then reset the blades to trench in the right direction. Has any one done this yet? I checked all the replacement chain and sprocket on the net, and no body admits to making the trencher for PT. It must be foreign made. Did someone say that PT makes all their stuff in house, or assembles it in house.
/ for sale, trencher #9
I have a 72 in hydraulic flail mower that I would like to do some barter/trading. New ones cost $4700.
/ for sale, trencher #10
Mine is a four footer too. I just rebuilt it for $120 in parts (from PT!). I had previously replaced a bunch of tines so this time around it was nose sprocket, bearing and bolt nut as well as tensioning bolts and misc. Hardest part was getting nose bolt loose.
/ for sale, trencher #11
rmcconnell,
I'm interested in the trencher. I sent you a private message.
Thanks.
2013 FREIGHTLINER CASCADIA (A63569)
2013 FREIGHTLINER...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
iDrive TDS-2010H...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
2025 Fendt 1167 Vario Tractor (A63111)
2025 Fendt 1167...
