Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
   / Cutting / Groving / Siping R-4 for snow #141
Tires are a bit more messy in the mud. The new cuts fill with mud, and then when you drive down the road at speed, the mud comes out of the tires and makes a little mess. Minor, but just something I noticed!
   / Cutting / Groving / Siping R-4 for snow #142
In other words- no different than ANY tire!
I wonder, Deadman- or any of the others who followed this thread-does grooving the tires improve traction enough to negate the need for filling the tires?
For me, filling tires isn't just about traction, it's about stability. I will always fill my tires. That being said, when plowing snow my tractor is operating at 5100 pounds. The 400 pounds of fill in the rears is only 8% of that total so it's not the major contributer to traction for me.
   / Cutting / Groving / Siping R-4 for snow #144
Not to beat this topic to death, but wouldn't a rear weight- ballast box/55 gal drum/fat friend standing on the drawbar-add the weight WHEN NEEDED, and be removable when not (i.e. mowing the lawn)?
I'm still in awe over you guys' grooving/siping adventure!
I mow with the zero turn, not the tractor. Everything the tractor does, it does better with more weight. If you mow with your tractor then sure.
   / Cutting / Groving / Siping R-4 for snow #146
Update;
I got my #6 head/blades...I went over the center lugs with it. I think I am going to leave the outer lugs with the skinny groove (laziness maybe). Am I believer and recommend doing this? Yes...there is a noticeable gain on snow.:thumbsup:
Uploaded with ImageShack.us
I'll be interested to see which groove (skinny or fat) holds the snow better in the winter. Keep us posted on that. I'm betting on the skinny one if they are the same depth! :D
   / Cutting / Groving / Siping R-4 for snow #148
gladehound....hopefully that post will be about 8 to 9 months from now.:cool:
   / Cutting / Groving / Siping R-4 for snow #149
Well you are definitely on the right track. (no pun intended). A little trial and error and go a little at a time on each tire and you'll have it dialed in. Then you can write a manual for the rest of us.:thumbsup:
My skid loader tires are basically the same as R-4's and I knew how bad they were in the snow before I bought my tractors. I ordered both my bx2660, and my b3030 with turf tires and have no regrets. Their primary rolls are snow removal, and that they do very well.
   / Cutting / Groving / Siping R-4 for snow #150
Fastpauly: looks good. Is that a 2520? And, which cutter did you use?
ELECTRIC TRICYCLE IRET13 (A55745)
ELECTRIC TRICYCLE...
2008 INTERNATIONAL 9900I (INOPERABLE) (A55745)
2008 INTERNATIONAL...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A57024)
LIKE NEW 2023...
UNKNOWN  UTILITY TRAILER (A55745)
UNKNOWN UTILITY...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2014 Electric Cart (A53424)
2014 Electric Cart...
