JD Gator DIY Dump
/ JD Gator DIY Dump #1
mvanhaerents
Member
S.E. Michigan
Deere 4410
I am thinking of adding a power dump to my JD Gator using an electric screw jack such as this one -> Bully 12 Volt Electric Car Jack - JEGS
I am planning on welding a round pipe to each end of the screw jack, and adding a shaft to each of the pipes, one attached to the gator and one to the bed. Does anyone have any advice on things that I may be missing?
/ JD Gator DIY Dump #2
Plenty of Gators use screw drive to lift the bed; a different style of screw drive, but still a screw drive. I'd be curious to know if it fits in the space and the cycle time on that thing. For example I wouldn't have the patience if it took 30 seconds to lift the bed.
Just my $.02
/ JD Gator DIY Dump #3
Here is a picture of the actuator in my Gator.
/ JD Gator DIY Dump #5
Is that the factory linear actuator or another one. Do you have any idea on the specs. for it?
Sorry, I should have wrote that it was the factory one...there is no label or specs on it-I just went and checked.
/ JD Gator DIY Dump #6
Installed one on friends Gator. Used linear actuator from the Surplus Center. Used factory holes at top (bed) reconfigured factory bottom mount. Good fit. About 2 hour job, including electrics install. Saved about 50% of the dealer installed lift.
/ JD Gator DIY Dump #7
What was the stroke length of the actuator you used?
Takeuchi TL8R2 (A64126)
Takeuchi TL8R2...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
Ford Tractor (A62613)
2025 28in Forks and Frame Mini Skid Steer Attachment (A61572)
2025 28in Forks...
MASSEY FERGUSON 2605 TRACTOR (A64276)
MASSEY FERGUSON...
