X500 in f250
/ X500 in f250 #1
runnermikedmd
I'm picking up a used x500 with a 48inch deck. Anyone know if it will fit in the bed of a short bed f250? Thanks
/ X500 in f250 #2
:welcome: To TBN. Probably it will fit in pretty nicely. If not just have your truck bed open and have some rope or some chains so it wont come out.
/ X500 in f250 #3
I think a 48 inch deck is 52 inches wide, I don't think the space between the wheel wells is 52 inches???
/ X500 in f250 #4
+1 on Markcuda's reply - 4' plywood lays flat, but pretty close to the wheelwells. If it is too tight a fit, the deck removes fairly easy from these machines.
/ X500 in f250 #5
Yup, if you have a nice concrete surface, that deck can be off in 2 minutes:thumbsup:
Even on grass, it is very easy.
/ X500 in f250 #6
I've never measured, but that's probably exactly right. It is possible to barely squeeze our GT275 with a 48" deck between the wheel wells of our 2003 F350 srw long bed- there's usually a little rubbing, but it doesn't bother me because of the bedliner.
The X500 is substantially heavier and has a wider wheel base than the GT series. I also recommend removing the deck, safely getting the X500 into the bed, then finding a safe place to put the deck (even in the back seat if necessary ;)).
/ X500 in f250 #7
I just measured my 48 inch deck, the widest part was 51 inches.
/ X500 in f250 #8
Tried it! Won't work! You'd have to ramp up your bed floor so the deck could be over the wheel wells. Or take the deck off.
/ X500 in f250 #9
Bruce, I see you have a 54 inch deck in your signature.
Did you mean a 48 inch deck won't fit?
/ X500 in f250 #10
you should be able to drive it up till the deck hits
the wheel wells, and stop there, the rear wheels should
be right about on the hingepoint of the tailgate.
then tie it in and you should be good to go.
/ X500 in f250 #11
The cables that hold the tail gate, does any one get nervous driving a 6/700 pound plus mower on their tail gate?
/ X500 in f250
Sounds good. Thanks for the ideas. Looks like I will try to squeeze it in and if that fails just take the deck off. Thanks!
/ X500 in f250 #13
I used to load my old style 110? in a short bed Ford pickup years ago. Backed up to an embankment and dropped the tailgate. That was the easy way to load and unload. Today with trucks getting weaker and alot more expensive I recommend removing the tailgate and using some of the aluminum ramps made for this purpose. If the rear mower wheels won't fit that might be a problem.
/ X500 in f250 #14
That's how I'd do it to it. And after you secure the tractor secure the hood and anything else that the wind may take away in a flash.
/ X500 in f250
It was a tight fit but the deck slid between the wheelwells. It did rub the bed liner a bit but I was glad to be able to close the tailgtate. Thanks for all the ideas.
/ X500 in f250 #16
Good advise. It is kind of amazing how many L&G seats I see by the side of the road during mowing season.
Chris
/ X500 in f250 #17
Mark kind of a long story but when I got my X500 last fall my dealer was out of 54" decks and did not want to order one and he said take with the 48" and bring it back in the spring when all my new stock gets in and I'll switch it out for you. I did that two weeks ago and changed my sig.
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
Engine (A59228)
Engine (A59228)
2013 PETERBILT 365 (A65643)
2013 PETERBILT 365...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
