John Deere 4105
/ John Deere 4105 #1
goochy
Got to put a few hrs on the 4105 ! WOW !! I LOVE IT !!! its great ! I pused down about 20 ft wide and 50 foot long , tree filled sandy area . Bushes , trees , the 4105 dug it out ! I also learned how to scoop and fill up holes !! My wife got to drive it alot , I would pick up the small roots and throw them in the bucket , then she would go dump it ! Fun day . I am off all week , so working JD HARD !!! The only problem is the yellow " fill knob' above center link , is leaking :confused:. I took it out and flipped O ring around and that made it worse. Buying new O ring Tues . Called dealer , he said its a vent and filler knob . So its ok to vent some ?????? I hope its not going to be a problem . I did cjeck fluids , 3 Xs with 3 being full , its on 2 x . I did work the FEL HARD for HRS !!! maybe I over worked it , and it pushed out some fuild out the VENT in the knob?
/ John Deere 4105 #2
Might have gotten overfilled. Just keep an eye on it. If I'm correct (about the overfill), once it pushes out any extra fluid, you won't see any more venting.
/ John Deere 4105
I replaced the O ring , and its leaking worse :(. Going to read book and learn how to check fluid on dip stick . Its leaking down both sides and drips on floor :(. I hope I do not have a problem , I hope its just over full ? I did work FEL VERY hard for hrs , I hope I did not mess something up ? Any thoughts ?
/ John Deere 4105 #4
Don't panic...this machine is new for you, so contact your dealer and see what he says...that's your first step.
You might have to drain some hydraulic fluid out (if it's overfilled), but wait and see what the dealer says first.
(EDITED) My guess is he'll take the tractor in and replace the hydraulic fluid and filter.
/ John Deere 4105 #5
Is it leaking around the dipstick or the fill cap? Keep in mind that hyd oil expands when it gets hot.
I found this service bulletin.
/ John Deere 4105
coming out of VENT that is made into cap . I just read on some other site , " If you LOWER FEL withOUT engine running it will force fluid out the vent " I have lowered the FEL and 3 pt hitch a few times with engine NOT running . I will never do that again . Going to check fluids on Wed , and clean up mess , then drive it , and see if it still leaks . Also going to call dealer that sold it to me , to see if he can give me in help . I am out of town , so can not just drop by dealer ( 5 mins from house ) . I also read that a air leak could force it to leak ? I have some work to do , so I have to use it !!!! I guess I'll keep using it and keep it full of fluid , and let it leak :(
/ John Deere 4105 #7
You may have been composing your reply while I was searching for service bulletins. Please see my previous post. It may give you some peace of mind.
/ John Deere 4105 #8
Good job!!!
Goochy, print out a copy of that bulletin...good possibility your dealer won't know a thing about it!
/ John Deere 4105 #10
Thanks for the pat on the back, Roy. I'll have to look up the specs on parts listed. I wonder how long the extension tube is? .......maybe tomorrow.
/ John Deere 4105
Dealer told me to STOP lowering the FEL and rear Lift , with engine OFF ., that should be my problem . I checked on parts on service notice , around $45-$50 should fix it . I might make my own :thumbsup:. All I need is a extension pipe , with a fiitting for the cap to screw on
/ John Deere 4105 #12
Let the dealer do it...or buy the factory parts.
One thing I am surprised about...this affects the 3x20 series, the 3203 as well as the 4105. Surprised this hasn't arisen before...especially with all the 3x20 series machines.
/ John Deere 4105
Fluid ok , I did NOT lower with engine off , cleaned up . Drove it for a couple hrs and leaked ALL over rear end out vent . John Deere will NOT replace parts . ( that was dealer out of town ) I am going to call my local dealer m that I bought it from , to see what he will do for me . I am still out of town , so can not take it to them . Not sure what to do , or what to look for ? Air leak ?
/ John Deere 4105 #14
The dealer representative you spoke with is a Douchebag. Tell your dealer to print off a copy of DTAC solution #80527. Watch him read it. Then, see if he has the nerve to deny responsibility. Do they expect you to believe that a puddle under a new machine is normal and acceptable?
/ John Deere 4105 #15
Or that not lowering the FEL or 3PH with the engine off is the solution...that is asinine.
/ John Deere 4105
Still LEAKING !!! :mad::mad: When I get home , I am going to talk to my dealer !! At the cabin , so almost 2 hrs from dealer .
WOW , I LOVE this tractor , I did 5 loads of dirt today !! Used FEL to move alot !!! Also used FEL to move crossties around . Had to set about 15 today ! Been working it HARD !! Its got some POWER !! Also set some crossties , to make a parking area . Just dug down with FEL m set tie , then filled up area with white rock !! Pics next week when I get home .
/ John Deere 4105
WOW !!! what a week !! home away from home ! Our cabin , its about 4 miles from lake !!!! put almost 20 hrs on JD last week !!! Made $170.00 in cash in less than 2 hrs . Also did alot of trading :D, dirt , gravel, and got grass cut , for doing dirt work for friends . I did have the BIG lot , it was rough!! Took 2 hrs to do it . Tractor and grader did GREAT !!!!!
Still leaking out vent !! :mad: I am home now , so I am going to call dealer Monday . Love the tractor , just hate the leak !!
/ John Deere 4105
Just ordered parts , $40.00 for kit :( , my local dealer did knock off about $10.00 compared to other dealers . I hope this fixes leak , I really love the 4105 !!
/ John Deere 4105 #19
They made you pay for it:confused::confused2:
I would be demanding the number to the regional rep.
/ John Deere 4105
I guess I should have bought NEW vs USED . $40.00 , I can live with that . Its a great tractor , so if thats all thats wrong with it I'll be happy !! 20 hrs so far !! :D
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TACTOR (A59912)
2019 INTERNATIONAL...
2008 VOLVO VNM 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2008 VOLVO VNM 6X4...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2016 Kia Forte Sedan (A61574)
2016 Kia Forte...
