Testdrive : DK55 high range engine lacking power?
/ Testdrive : DK55 high range engine lacking power? #1
NorthernChilli
Quebec, Canada
NH TD80D, Ford 1320
I went to test drive a DK55 yesterday. I was impressed by many bells and whistles that are standard on the DK 55 (auto-lev loader, 12/12 trans with a creeper slow low-1 speed without having to pay for a creeper box, cat 2/1 3pH, full equip cab with radio, short turning radius)
But... While trying it in high gear on paved road, I found it very hard to shift from high 2 to high 3. For that to succeed, I had to be at full speed in H2 and switch as fast as possible in H3. Failure to do so and fast enough would result in the engine not able to catch up and slowly reving down because of a lack of power, ultimately to choke and die.
On that test drive, shifting from H3 to H4 successfully was impossible for me even being at full speed 2800RPM and shifting as fast as possible... Guess it has to do with the turbo not catching up for the required effort. And that is without anything in the loader and without the loaded tires...
So, what's your take on this. Am I just a very crappy shifter or is it an issue with the DK55 ?
Thanks Phil
/ Testdrive : DK55 high range engine lacking power? #2
I have road tested a DK55 in 2009, and had trouble shifting the gears through the gears. The saleman told me it was because the machine was new, not broken in:confused: Anyways i decided to purchase a Dk45SE with the cab. When i purchased my CK30 2010 with the 8x8, you could hear the gears grind a little while shifting or shuttling. Again i was told the machine was new and stiff. Well he was right, after 30-40hr smooth and easy shifting and shuttle.:thumbsup:
/ Testdrive : DK55 high range engine lacking power? #3
That seems odd. I have a DK45S Cab and shifts very easy. One of the easiest shifting tractors I have owned. That includes a Deere Quad Range and a IH T/A power shift. I just clutch and shift. I have never noticed a loss of power either. I have went highway with a NH 315 baler in tow and pulled fulll loads of hay it was fine. This may be a dumb question but maybe the brakes were set?
/ Testdrive : DK55 high range engine lacking power? #4
I have a DK50c 894 hours and I notice some engine lag when going from high 3 to high 4. I do not have as much of an issue with it now have not had it long though bought it this year and have put 60 hours on it myself. I think the dealer is part right about the engine and I think maybe the other is operator, only because it took me a little getting use too shifting mine. I have operated quite a few different tractors but the kioti took a little time getting use too. Very happy with my tractor though. Hope this helps also if you are still consedering buying it test drive it again for a while let it get good and warmed up and spend some time getting use to it.. Good Luck
Well, the action of shifting is easy, it's the engine behaviour after having shifted that I dont like. Reving at 2600+ RPM in H3 then shifting, and upon releasing the clutch, the RPM falls to about 1000 and slowly decrease without any way of getting it to catch up and accelerate. The same kind of behaviour a car would do shifting directly from 1st to 5th speed (and even then, I tried it on my car and the engine was still able to catch up and accelerate in 5th)
Pretty sure the brake was not on, on a new unit, it would have been obvious while taxiiing at low RPM :)
Phil
/ Testdrive : DK55 high range engine lacking power? #6
I agree with you the DK45S really shifts like a dream:D I really like the feel and emplacement of the shuttle and shifter, wonder why Kioti doesn't make them anymore:confused: I'm looking to upgrade my standard CK30, but i don't really know with what, guess i'll be road testeing tractors again.:laughing:
/ Testdrive : DK55 high range engine lacking power? #7
Phil
Something doesn't sound right with your unit:confused2: The DK55 my father and i road tested, we found ,1 the gears grinding occasionally when shifting(unit not broken in), 2 the tractor needed a super high range, we did shift all the way to H4 and though we were in mid-range. 3 The saleman indicated to us that for our use this wasn't the tractor we needed. Good luck
/ Testdrive : DK55 high range engine lacking power? #8
We have a DK55 Demo unit that gets road driven fairly often. What you described is somewhat common until the tractor warms up to operating temperature and the turbo starts to respond properly. Once the tractor is warm, it easily catches up shifting in high range at about 2200 - 2400 rpm. It needs the engine speed for the turbo/fuel mixture to be right.
We have done a lot of field work with the DK55 and have found it to have good power in the field in high range. Pulls a 10' gang disc in H2 easily. We even ran a 9' discbine with it. Probably not something we would do on a regular basis, but the tractor ran it.
The trick with the DK55 is to let the tractor use the turbo properly. Makes a big difference.
I just noticed something. Where is the air pre-cleaner bowl gone on the 55. It is shown on the kioti website, but the picture of the cabbed tractor in the brochure doesn't have it and I don't remember seeing it on the one I testdrove.
Phil
/ Testdrive : DK55 high range engine lacking power? #10
I've got an 08' dk55 and I drive it quite a bit on the road in between the driveways I snowblow and I don't have any problem in high range and I usually run about 2000rpm's. I always throttle down when I shift like you would in a truck, not sure if you're supposed to but it seems like it would be easier on the clutch. I usually have the hand throttle set at about 1500rpm's and use the foot throttle to override that after I shift. I live in central New Hampshire and there are very few hills I can't pull in 4H. And the shifting did get smoother with use.
Scott
I did go back to retest it saturday morning and this time I managed to get it in H4. Maybe I was letting the engine reving down too much and it wasn't able to catch up. Indeed, it was when I left my foot on the gas pedal, reving the engine around 1500-2000 while shifting that it worked, wheras before I tried to shift it mostly releasing the gas.
Leaning closer and closer from triggering a deal on this one.
Phil
/ Testdrive : DK55 high range engine lacking power? #12
Phil
I have an 06 DK55C ad have never had any trouble with the use of 4High. I often use it down the roads at the ranch . I also shift it much like a truck 4 speed. These turbo small displacement engines are somewhat sensitive to the rpm range. If you let it drop too much you lose power to some extent. However I have never felt it to be underpowered.
/ Testdrive : DK55 high range engine lacking power? #13
I haven't had any issues running and shifting thru the gears with mine although I do treat it gingerly. 300 he's apron.
/ Testdrive : DK55 high range engine lacking power? #14
I've got an '06' dk55c and I drive it on the road now and again - paved and not. I don't set the throttle when shifting. I start out in high range and use the foot throttle and clutch... like my f150 truck, kind of. It does well this way. Once I get to the speed I want or can handle for the road condition - WEAR YOUR SEATBELT! - then I'll use the throttle control.
Once your tossed into the ceiling once ... you'll not do that again!
I will say it's shifting better now then when new. I've got 400+ hours now.
Good luck!
/ Testdrive : DK55 high range engine lacking power? #15
Phil
Phil,
Did you get a price quote on it yet?
The initial quote was 38500$ for cab dk55 and loader (cash price) and 11000 for my trade-in. I shopped a little around and found another place who quoted 35500 cash but was too small a shop to take back my trade-in.
In the meantime, I stopped at a New Holland dealer on the way to get fertilizer and the guy said "Wait, I think I got just what you want". He had a cab TD80D with a new loader, only 260 hours, and the overall condition of the tractor (rust, cleanlyness, hoses, appearence and all) was equivalent or even better than the new ones on the lot. He quoted 36000 for the tractor (72 HP, so stronger and heavier than the DK55, and no sales taxes since it's over 60hp PTO) and offered 14 000 for the trade in. That's a difference of 5500$ (9000$ considering taxes) less bucks for a bigger and real utility class tractor.
When I tried to negotiate, the first kioti one didn't want to budge neither on the 38500 nor the 11000 (he offered 11 436 to round the price, what a joke), even knowing that there was another kioti willing to sell at 35 500 and knowing NH offered 14 000 for my trade in. So I closed on the TD80D and after about 15 hours of work since getting it about a month ago, I'm very pleased with it.
Both gave me the same quote on the attachements though (except the plow):
Walco/agric AFMJ70 tiller 3170$
Walco/Faza F-500 solid Fertiliser spreader : 475$
Used kverneland 3 bottom plow (square beam) : 1800$ (no taxes for 3 bottoms or more... :eek: )
Walco 8' chain harrow 460$
Cotech Alo compatible quick attach Pallet forks 1200$
There, it's about all the info I got.
Phil
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59908)
2006 CHEVROLET...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
