New F-150 Motor Lineup
   / New F-150 Motor Lineup #81
Dargo, post a pic of the Biscayne... I drove one as a kid and it had the 6 cyl/3 sp... good basic transportation.
   / New F-150 Motor Lineup #82
I now know 2 guys with the 5.0 motor and its nice.
Honestly, the more and more I see/read about this 5.0l V8 the more I like it. Yes, I did just say I like a Ford motor. :D
I'll give it 3 years to prove reliable in a truck but if it does then Ford certainly has a winner. A clean simple NA V8 with that kind of power and economy is great!
   / New F-150 Motor Lineup #83
I have the 235ci 6 cyl on the shelf in my barn with only 40k original miles on it. The car came from New Mexico and never had any rust. I looked for 15 years in the midwest for one that hadn't had rust repaired and there weren't any. My first car was a '62 Biscayne with zero options; no oil filter, no radio, no heater and no seatbelts. Still, it ran forever with that old inline 6 and the 3 on the tree.
   / New F-150 Motor Lineup #84
Beautiful car! :thumbsup:
   / New F-150 Motor Lineup #85
I'm not a dyno expert but why does the V6 data not even start until after 2k rpm's? There should've been some data collected below 2k just like the 5.0.
Did they use the same transmission? Is the converter in the V6 have a higher stall?
   / New F-150 Motor Lineup #86
Thank you sir. I can honestly say it involved a LOT of blood, sweat, tears and, of course, money. :D I don't understand why my rear tires don't last long. I had a nationally known drag racing chassis builder setup my 'stealth' 4 link rear suspension. No wheel hop and it launches straight (5500 stall Frank Lupo converter), but the D3 compound street tires just don't last.
   / New F-150 Motor Lineup #87
The dyno runs are typically done from a rolling start in a gear as close to 1:1 as possible and not from a stand still. The 5.0l most likely has lower gearing which is why it shows lower rpm's on the dyno vs the V6. They most likely made both runs from about the same speed to full throttle redline.
   / New F-150 Motor Lineup #88
I just got a 2011 F150 with the 5.0 and it is quite a smooth engine. Before I made my decision I drove the 5.0 and the 3.5 echo-boost in 3.55 and 3.73 gear ratio combo's. I liked the "tip in" feel and the growl of the 5.0 and 3.73 combo a lot better then the 3.5EB.
   / New F-150 Motor Lineup #89
If I was to buy a new 1/2 ton i would go with the 5.0 for sure. The v6 sounded like a real winner when people were talking about 25 mpg highway.
I hope it will be a good engine but I bet the 5.0 easily outsells it down the road.
Maybe the tuners can do something for it to get closer to the 25 mpg. The factory tuning does leave a little on the table just to cover a wide spectrum of variables. Good tuners can make a difference.
   / New F-150 Motor Lineup #90
Most people are buying it for the power after test driving it and comparing it against the Ford 5.0 and the other brands. I think it's one of those decisions where there is no wrong answer, and either one has some advantages. The 3.5 is more of a stealth engine that quietly powers though the work, while the 5.0 is a "look at me my engine is bigger than yours" engine with it's great sound.
2013 John Deere 824K (A51039)
2013 John Deere...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
Deere 9965 Cotton Picker (A51039)
Deere 9965 Cotton...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
