2320 drive line issue
/ 2320 drive line issue #1
gghb
jd 2320 48 cub mf2135
has anyone talked to jd to see if newer models had u joints in drive line that should be greased my manual shows none
thanks greg
/ 2320 drive line issue #3
I don't know what model yr mine is( I just it a little over a month ago) but I am guessing a '10? and it has grease zerks on the universals but is not listed in the O/M.
/ 2320 drive line issue #4
Hey Scrappy,
Did you receive an update to your owners manual about the greasing of the drive-line u-joints?
In this thread that just started, it was mentioned that an insert to the Operations Manual for new owners of 2320 was supposed to be provided. (Publication date: Dec 14, 2010)
88233-(|)-2320 - Driveshaft service schedule was not detailed in operator's manual - TractorByNet.com
/ 2320 drive line issue #5
Hey Scrappy,
I saw that thread just after I posted here and have already downloaded the bulletin.
iDrive TDS-2010H...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
Mini rock grapples (A61567)
Mini rock grapples...
2019 F150 (A61306)
2019 F150 (A61306)
INTERNATIONAL 4900 GRAIN TRUCK (A63291)
INTERNATIONAL 4900...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
