KB 2365 Sub Frame
/ KB 2365 Sub Frame #1
gilbertmsg
Gold Member
Disputanta, VA
2007 Kioti CK20
Going to look at KB 2365 today, it is attached to a CK 25. Can I use his sub frame to attach to my CK 20 or will this require a additional purchase for my tractor?
Thanks!!
Eddie
/ KB 2365 Sub Frame #2
KB 2365 Sub Frame
Thanks!!
Eddie
With the KB2465, the subframes are different sizes as are the two tractors vary also The part numbers for both tractors using that hoe show a different part number for the subframe. Perhaps someone can advise you for the kb 2300 series specifically.
I'll bet a good welder could fabricate any differences.
rimshot
/ KB 2365 Sub Frame
That's what I'm thinking, checked with Kioti dealer near Richmond, VA and CK 20 subframe is between $500 - $600.
Eddie
/ KB 2365 Sub Frame #4
If the BH comes with the subframe you might want to just have a local welder look at it to see if it can be adapted for less than the price of a new one. An experienced dealer could probably tell you.
/ KB 2365 Sub Frame #5
No it will not work.
/ KB 2365 Sub Frame #7
Your other post had the bh price at $2,000. Even adding 500 for the subframe still might not be bad if the bh is in good condition. I bought a KB2375 back in 2005 for $5,500 and as others have mentioned, new is about $1,000 per foot. Maybe Wallace has a frame laying around that would work for you.
/ KB 2365 Sub Frame #8
I have tons of frames laying around...I just need to find out what i can get rid of one for.
/ KB 2365 Sub Frame
Well, the guy did not call me back on Saturday. Hope he calls today as I think $2000 is a good deal even if I have to buy a new subframe. Can not afford a new one. Thanks for your replys.
Eddie
/ KB 2365 Sub Frame #10
Do you have anything I can use to attach a small (5') backhoe to a Kioti CK20s frame ( in addition to the 3pt hitches) to take some of the stress off the machine? Backoe operated off PTO and has it's own hydralic pump etc.
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
New/Unused Landhonor Quick Attach Receiver Hitch (A61166)
New/Unused...
2016 Ford Expedition 4x4 SUV (A61569)
2016 Ford...
New/Unused 2in Ratchet Strap (A61166)
New/Unused 2in...
2021 Bobcat T770 Compact Track Loader (A61166)
2021 Bobcat T770...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
