Spreading bentonite
/ Spreading bentonite #1
The Dougster
Gold Member
Lampasas, Tx
Kubota L2800
As a result of a stock tank that doesn't hold water... leaking to the formation, I recently bought 3 tons of granular bentonite to spread in the bottom of my stock tank... a mega job... I unloaded (dumped) the bentonite in the bottom of the tank and then spread it as evenly as possible using my FEL... afterwards, I used my disc plow to work it into the soil.
While doing all this, I thought there must be a better way and suddenly it occurred to me. This suggestion is for those who have the same problem. If I had to do it again, I'd load the bentonite into a PTO powered fertilizer spreader and use that system to distribute the bentonite. Bentonite is expensive, mine cost $235 per bag ( 1 1/2 tons each)... Using my suggestion, I could have saved money on bentonite.
Hope this suggestion is useful to someone.
/ Spreading bentonite #2
Bentonite,I haven't used any of it, but considered it for our farm. 1 1/2 tons, how many cubic feet is the bag? We have a shallow pond , that failed there. I take it you used it like you would use soil-cement? That is till it in for about 4 inches all along the bottom areas? I did seal one crack in the stone with regular portland and the level raised 6 inches above the patch. The other pond is completely dry..Jy.
/ Spreading bentonite #3
Is this a permanent solution to a leaking pond? Is there any literature that explains how and when this is best used?
/ Spreading bentonite #4
virtually all "leaking pond" problems are solved with bentonite or a similar expanding clay.
/ Spreading bentonite #5
Doug, how big is your stock tank? Did you select 3 tons based on a calculation or just a SWAG? At the cost you stated, I might just do that on my ponds I'm building as insurance against leaks. I'm thinking that for my 3/4 acre of water surface, the 3 tons might be about right. I might go to 4-1/2 just to be on the safe side. $235 per bag is expensive, but no more than a load of good clean washed gravel. After spending thousands to get a pond/tank dug, a few hundred dollars is not going to look like much extra. If it makes the pond hold water, it's a bargain.
/ Spreading bentonite #6
Hey Jim, Have you thought about a liner? I don't know what the current cost is right now, but one of the Golf courses I go to in AZLE, put one in a probably 10 acre holding pond! been over 10 years. Seems to last quite awhile.
/ Spreading bentonite #7
Dennis, I have not considered a liner and can't imagine how I would put that down by myself. I can spread bentonite, but me and poly don't seem to get along too well.:confused2: I figure by the time I paid for a crew to help me, the liner wouldn't save any money over the bentonite. Something about a liner makes me think of oil field salt water evaporation pond, and that just turns me off. Bentonite clay just seems like a perfect "natural" solution.:)
/ Spreading bentonite #8
they make a liner called Akwaseal (sp) that is a liner with bentonite in between the plastic. Seams are welded with loose bentonite. worked on a 7 acre pond. :thumbsup:
/ Spreading bentonite #9
True Jim, They do seem to take some of the aesthetics (sp) away, but they sure hold water.
/ Spreading bentonite #10
Seems so strange, as soon as we dig a hole in the ground anywhere here it fills up with water, even in the heat of summer!
/ Spreading bentonite #12
How did it turn out?
IMO, the method you used is the most efficient, effective approach for most of us. Fert. spreader might be ok but doubt it would help that much. The key to success, IMO, is to get a thick application over the suspect area and disc it in good and pack it by running back and forth over it with heavy equipment.
Very low probability of success with just spreading it on the surface of a full pond, very low.
Of course I used a disc to work the bentonite into the soil after spreading it.. sheesh!
I bought two bags ( 1 1/2 tons each) because that's all I could haul safely with my trailer... Let me be clear.. I spread it using the FEL... this idea of using a fertilizer spreader was an afterthought... this happens to me a lot.
I feel certain that by using a spreader, I could get better distribution using half as much bentonite, thus reducing my cost ... my stock tank is about an acre in size. The folks at Texas Sodium Bentonite were quite helpful...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
2018 International LT Automatic Day Cab (A62613)
2018 International...
Amadas SPC-6 (A64119)
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
