1952 Ford NAA 600 Tractor
/ 1952 Ford NAA 600 Tractor #1
terryc1917
1952 ford naa 600
How do I charge a 6 volt battery ? Is it reversed , positive to negative post and negative to to positive post ?
Thanks , Terry:confused2:
/ 1952 Ford NAA 600 Tractor #2
Are the terminals on the battery not marked? Seems like they should be! The best way to find out is to get a simple handheld test meter and test for polarity. You can get some really cheap ones at Harbor Freight, or usually the chain auto stores such as Advance Auto or Autozone have some. Radio Shack may have a cheap one too. Or you could borrow one from a friend.
Once you get the meter, put the red lead in the hole marked (+) pos. Plug the black lead in the hole marked (-) neg. (NOTE: there may be another set of holes to measure current with, you won't use them for this measurement (read the users manual if handy!)
Once you get the leads properly hooked up to the meter, set it to read DC volts, on a scale setting that is at least 10 VDC full scale. Put the red lead on one battery terminal, and the black lead on the other one. If the meter indicates a negative measurement (indicated by a (-) sign on digital meters or the needle trying to go the wrong way on analog meters), then reverse the leads (on the terminals, not the meter). You should now get a positive reading (indicated by (+) on a digital meter or the needle giving you an indication of how many volts it is measuring on an analog meter. At this point, the meter should indicate somewhere close to 6VDC on the battery.
Once you get a positive reading on the meter, then the red lead will be showing you the positive terminal of the battery, and the black lead will be showing you the negative terminal on the battery. But, this will be true only if you have the leads hooked up to the meter correctly!! That is very important!
I suggest once you get it figured out, mark the terminals clearly so you (or anyone who comes behind you) won't have to go through it again. Oh yeah, in case you didn't realize it, you need to disconnect the leads from the battery before charging it. That's always the smart/safe thing to do. You can leave them on, but if there is something wrong with the wiring/electronics that is shorting the battery to ground, you may not get it fully charged.
Good luck!
/ 1952 Ford NAA 600 Tractor #3
it may be a positive ground system, but battery still charges red to plus and black to minus. (unhook positive cable before charging)
/ 1952 Ford NAA 600 Tractor #5
Hi! Before check polarity with a good Voltmeter. I seen long time ago somebody discharge completely a battery with a seal beam until Zero charge and he recharge the battery with low rate battery charger at the good polarity for 24 hrs. This is no good for the battery.
Dont forget you must to polarize the generator to battery each time you remove a battery on generator system. Very important! Good luck! Oldmech
/ 1952 Ford NAA 600 Tractor #6
1952 was an 8n.. naa was 53/54 year model, and 600 series began for the 55 year models.
in any case.. all were 6v positive ground.
meaning the positive terminal of the battery was connected to chassie, and negative terminal of the battery was hooked to the starter solenoid 'hot' side.
assuming you have a oem genny, you can swap the battery terminals to correct it.. but then you need to polarize the gen.. the 8n is a circuit and polarizes jumping bat to arm momentarilly..
the NAA and 600 are B circuit and polarize by jumping field to bat momentarilly.
do not get these confused.. polarizing an 8n like a NAA eats a 40$ regulator.
hint.. 8n is a flathead.. NAA+ is OHV.
post a pic if you don't know what you have..
soundguy
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
2024 John Deere 6R 145 Tractor (A63111)
2024 John Deere 6R...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
