Possible New Kioti Owner Here
/ Possible New Kioti Owner Here #1
Texas Kioti
Member
Hockley, TX
2012 CK30HST
Hello all, I may be purchasing (he's practically giving it to me) a Kioti from my neighbor soon. This will be a project, but it will hopefully turn out just fine.
I need a little help as i don't have much info for now because I'm at work. :confused2:
He says it is a 1999 or 2000 model, 35hp 4x4 diesel. He bought it new but it has been sitting for a short period of time as he has a JD to work with as well.
It runs and drives fine according to him, and just needs a fresh battery for starting and running.
I'm working nights tonight, so I should have some research time ahead of me.
What possible model is this tractor so that I can start searching for the parts that he says I may need to get her fixed?
He said the PTO is broke because someone that borrowed it used a heavy duty shear pin, and also he thinks it needs a new hydraulic pump as the FEL will not operate at all.
I'm sure I will have many more questions in near future and look forward to the learning curve ahead. Right now I have a David Brown 996 up in the country, and I'm wanting to fix this one up for use around the house back in town.
OK, it looks like it could be a DK35, can anyone confirm this by the info I gave?
/ Possible New Kioti Owner Here #3
Sounds like a DK35 but could possibly also be a LK3054. Look online for pictures of each to confirm. The loader not working could also be something more simple like a bad valve in the loader control. You will definitely want to get a hydraulic pressure gauge to tie into the lines and check the pressure first.
Does it look like this: 2000 KIOTI DK35 Tractors - Less than 40 HP For Sale At TractorHouse.com
/ Possible New Kioti Owner Here #4
If the three point operates, it's not the hydraulic pump
Ok, it is smaller than I thought, but he is talking about selling it to me for $300 or so.
It is a LK3504 with a KL128 FEL. I doubt it is really 35HP, but now the research begins!
/ Possible New Kioti Owner Here #7
Are you sure it is no lk3054?
If so the hydraulic pumps were aluminum an had habit of failing that would be 400 or so if it is the pump after all
I own lk3054 and like very much
My loader is I believe 1231
Joel
/ Possible New Kioti Owner Here #8
$300 !!! heck it's worth that for parts
Good deal IMO.
/ Possible New Kioti Owner Here #9
There are a few LK3504s out there. Let me know if you want to double your money ;-)
/ Possible New Kioti Owner Here #10
$300! Yikes, are you sure? If so buy it regardless of what model it is. Holy moly, that is a deal and a half.
Joel
Yes it is a LK3504 as I looked at it yesterday in person, and the price of that pump (if that is what is wrong) is better than I thought!
/ Possible New Kioti Owner Here #13
I WAS going to say that it sounded like potentially a lot of headaches and expense to get it fixed up, but for $300 I'd face the wrath of my wife to get it into my yard!
BOB
Ok, I have her home & pressure washed the whole tractor yesterday so the work will be cleaner, and she is now in my workshop.
I found a shop manual, but it hasn't arrived yet. Where should I start looking for this problem with the 3-point and the FEL not working? I was hoping that the hydraulic pump was external, but at a quick glance today it appears to be an internal one :mad:
Does anybosy have a link to the hydraulic pressure gauge that I need to test the system? Or if someone wants to rent me one, that would be nice and could be handled thru Paypal and the mail system.
I will obviously start with checking the transmission fluid level to make sure there is adequate fluid in there for the hydraulics. It would be nice if the problem was something as simple as that. It would be nice if it is the directional valve of the joystick controls for the FEL, but since the 3-point won't raise, I can probably rule out the joytstick controls.
/ Possible New Kioti Owner Here #16
Does that model have the little knob that adjusts the hydraulic flow rate? It would be funny if that knob was just cranked all the way closed.
BOB
/ Possible New Kioti Owner Here #17
Since the loader is not working, you really need to tie into the hydraulic system right at the pump to test the pressure. Most tractors have a "test port" on the pump to test and it should say in the manual if and where it is. Check with your local dealer or NAPA for a gauge, I rented one from NAPA for free with a $50 refundable deposit.
BOB
That knob on the Kioti's only adjust the speed of the 3pt hitch, it has nothing to do with the loader which is also not working in this case.
BOB
I know that knob, but have not tried it yet. I would be surprised if that's it, but hey.....
Thanks for that info dmace :thumbsup: hopefully I will get time to tinker with her this weekend. I really hope that shop manual arrives soon!
/ Possible New Kioti Owner Here #20
You may want to pull the filter element and see what it looks like. If something has contaminated the hydraulic system the suction filter will plug up very quickly and starve the pump giving you the symptoms you describe.
CATERPILLAR D6R XL CRAWLER DOZER (A65053)
CATERPILLAR D6R XL...
Eagle Weather Vane (A64557)
Eagle Weather Vane...
1999 Trailmaster Aluminum 407 T/A Chemical Tanker Trailer (A64194)
1999 Trailmaster...
(INOP) GRASSHOPPER FRONT DECK MOWER (A64278)
(INOP) GRASSHOPPER...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
2006 International 7600 T/A Flatbed Truck (A64194)
2006 International...
