Possible New Kioti Owner Here
   / Possible New Kioti Owner Here #1
Texas Kioti
Hockley, TX
2012 CK30HST
Hello all, I may be purchasing (he's practically giving it to me) a Kioti from my neighbor soon. This will be a project, but it will hopefully turn out just fine.
I need a little help as i don't have much info for now because I'm at work. :confused2:
He says it is a 1999 or 2000 model, 35hp 4x4 diesel. He bought it new but it has been sitting for a short period of time as he has a JD to work with as well.
It runs and drives fine according to him, and just needs a fresh battery for starting and running.
I'm working nights tonight, so I should have some research time ahead of me.
What possible model is this tractor so that I can start searching for the parts that he says I may need to get her fixed?
He said the PTO is broke because someone that borrowed it used a heavy duty shear pin, and also he thinks it needs a new hydraulic pump as the FEL will not operate at all.
I'm sure I will have many more questions in near future and look forward to the learning curve ahead. Right now I have a David Brown 996 up in the country, and I'm wanting to fix this one up for use around the house back in town.
OK, it looks like it could be a DK35, can anyone confirm this by the info I gave?
   / Possible New Kioti Owner Here #3
Sounds like a DK35 but could possibly also be a LK3054. Look online for pictures of each to confirm. The loader not working could also be something more simple like a bad valve in the loader control. You will definitely want to get a hydraulic pressure gauge to tie into the lines and check the pressure first.
Does it look like this: 2000 KIOTI DK35 Tractors - Less than 40 HP For Sale At TractorHouse.com
   / Possible New Kioti Owner Here #4
If the three point operates, it's not the hydraulic pump
Ok, it is smaller than I thought, but he is talking about selling it to me for $300 or so.
It is a LK3504 with a KL128 FEL. I doubt it is really 35HP, but now the research begins!
   / Possible New Kioti Owner Here #7
Are you sure it is no lk3054?
If so the hydraulic pumps were aluminum an had habit of failing that would be 400 or so if it is the pump after all
I own lk3054 and like very much
My loader is I believe 1231
Joel
   / Possible New Kioti Owner Here #8
$300 !!! heck it's worth that for parts
Good deal IMO.
   / Possible New Kioti Owner Here #9
There are a few LK3504s out there. Let me know if you want to double your money ;-)
   / Possible New Kioti Owner Here #10
$300! Yikes, are you sure? If so buy it regardless of what model it is. Holy moly, that is a deal and a half.
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
2018 Generac S/A Towable Light Tower (A55973)
2018 Generac S/A...
2018 New Holland C227 Compact Track Loader (A56435)
2018 New Holland...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
UNUSED FUTURE 32"...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2020 KENWORTH T680...
