New Tractor Tool Box
/ New Tractor Tool Box #1
rocknrod
Gold Member
Hico, TX
LS Tractor, Model R4010
I have lost a couple of pins out here and broke a couple of sheer pins as well.
So I went on e-bay and bought a blue tool box a few weeks ago.
Removed the bracket that holds the slow moving vehicle triangle.
Bent it up about 15 degrees in a vice and reinstalled it.
Held up the new box, used a angled scribe for the bolt holes.
Drilled it, put some steel plate inside as well for support.
Installed it.
I put the triangle bracket on the outside and it works great.
I even got some wire and crimps for smaller pins to keep it closed.
Now I have the tools with me and the various pins including sheer pins and don't have to come in to fix it. :thumbsup:
I think I bought it from this guy:
http://cgi.ebay.com/Ford-Tractor-30...005?pt=LH_DefaultDomain_0&hash=item230f56fb35
You have to be very careful not to get it too much in the center of the tractor - or you will have trouble with the 3 point top link.
/ New Tractor Tool Box #2
Very nice. I've been looking for a place to mount an ammo can for that kind of thing. May have to see if I can get one of those instead. Looks like it matches the LS blue too. I've never seen a NH and LS close enough together to realize the shades of blue are the same.
Very nice. I've been looking for a place to mount an ammo can for that kind of thing. ...
I tried a ammo can on the front between the uprights of the brushgaurd, but the lid wouldnt open. The rear would work for an ammo can also.
... Looks like it matches the LS blue too. I've never seen a NH and LS close enough together to realize the shades of blue are the same.
I wouldn't go that far. The tool box is not a perfect match. Is it painted correctly? Who really knows :D
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2023 Deere 317G (A60462)
2023 Deere 317G...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
