FLAIL Mower ID
/ FLAIL Mower ID #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Picked up a 6' flail mower off C-list this morning. Guy said he thinks its a Mott but was unsure.
There is no identification on it anywhere.
It needs a bearing replaced on the cutter shaft. In the last picture, it is the bearing under the pulley on the right. Doesnt look like it is going to be too challenging :thumbsup:
Also needs a tractor side PTO-shaft. It is missing because it was broke. But he gave me a complete second pto shaft off a bushhog or something. He has been using it with the flail but the side he has been hooking to the tractor is just a smooth bore hole (no splines) designed for a shear pin. His old 9n had a hole in the PTO he was just running a bolt throught it there:confused2:
So for sure, it needs a bearing and at least a yoke, possible the half on the tractor side for the PTO.
$150 brought it home. So how do you think I did?? And does anyone know a Make/model of the beast?
/ FLAIL Mower ID #2
Not sure on the model. For a buck and a half I would say it a great deal.
Bill
/ FLAIL Mower ID #3
Ah, its a Mott and it has 4 rows of grass slicers on D hangers; send the pictures to flailmaster and they will help you with parts .
Just be sure to order 2 bearings and seals for the rotor not one.
/ FLAIL Mower ID
Seals were not evident???
I got the main shaft out. And yes, 4 rows on D hangers.
But there was just a bearing on each end with a metal shield on the insides (no seal) and a cap pn the outside with grease fittings.
And yes, I will probabally replace BOTH bearings. Other than that, everything appears good:thumbsup:
/ FLAIL Mower ID
Just did some searching on flailmaster.com
This mower has 3-bolt bearing cages on the ends.
Similar to PN's M702408 and M702409
Mower Parts
But it appears they sell them as an ASSEMBLY for $100:confused2:
The bearings DO come out of the housings. The one housing is not in good shape, but I will either re-use it or make my own before I spend $100 on one.
And the bearings ARE different sizes as well. The DRIVE side bearing is a 62mm OD, 28.5mm ID, I cannot find any info for this?? The Non-drive side is a 62mm x 30mm bearing, which is a common 206/6206 bearing:thumbsup:
/ FLAIL Mower ID #6
Have you checked your local farm store for the bearings. The Farm and Fleet near me carries 3 bolt flange bearings similar to what you are looking for. That is where I got the rotor bearings for my lawn genie. They measured 1 15/16 id. The od really doesn't matter as long as the holes in the flange match up.
Bill
/ FLAIL Mower ID
Bill
No I havent checked them yet. But all we have is a TSC and they usually dont have much in the way of bearings.
Right now, I am having toruble finding the bearings online:confused:
It appears there are 3 peices that make up the bearing.
1. the housing itself like # 2 in this diagram at the bottom MONTAGE ENTERPRISES - MOTT FLAIL MOWER PARTS & BLADES, ALAMO FLAIL MOWER PARTS & BLADES (which could probabally be replaced)
2. The roller bearing itself (both sides need replaced)
3. The outer housing with the grease fitting similar to PN 700739 on this page http://flailmaster.com/products/products_search.aspx (which is broke on the pully side of this mower)
Flailmasters website shows the ENTIRE unit, for ~$100, but it looks like a 2 peice unit. Mine is a 3-peice. They will probabally work, but I dont want to spend that kind of money if I can just buy the bearings.
Which leads me to the next dilema. the NON-pully side bearing is just a 6206/206 bearing. 30mmID and 62mm OD.
BUT the pulley side has the same 62mm OD, but the shaft is 1-1/8":confused2: I cannot find this bearing ANYWHERE online. It's hard to believe alamo/mott us a 1-off odd sized bearing:confused2: I wished flailmaster listed the dimensions of the bearings on their website:mad: That way I could actually confirm what I have.
It just sucks because it is driving me nuts and there is nothing I can do until tomorrow when they are open and I can call them:confused2: I can make the inner housings for next to nothing. It is just a smooth more that the bearing presses into, it has a shoulder, and a 3-bolt thin flange. If bearings are a standard size, ~$10 each. But I need to see if I can find the outer housing somewhere. It looks like it was just cast iron and also has a 3-bolt flange. It's hard to describe, and none of the pics online look like they are exactally right. I will try to take some photos when I get home this evening.
/ FLAIL Mower ID #8
X2 Yeah, it is a Mott for sure. They are now sold by the Alamo Group. Yours is for mowing grass. It will work on hay, but you'll have to go a bit slower and it will not be as good with the woody stuff as the HD set up.
/ FLAIL Mower ID
That is the main reason I bought it is to cut grass. Mainly a little heavier stuff that bogs the RFM. I figure this will handle the 8"-12" stuff a little better than my RFM. I didnt buy it to replace my bushhog:thumbsup:
That is ofcourse if I keep it. I kinda have a habit of buying implements in need of repair/paint, then fixing them up, and usually have no trouble making a couple hundred more than I have invested on c-list. And most importantly, it gives me projects to do in the shop which I enjoy much more than just sitting around with nothing to do.
/ FLAIL Mower ID
Pictures of the bearing setup as promised.:thumbsup:
The first one is of the non-pulley side. It is just a standard 206/6206 bearing which I already have one. No problem.
Second is of the pulley side. I dont know if you can make it out, but the peice on the left is the housing. There isnt much lip left that the bearing seats into compared with the other side. But I can make this part for next to nothing:thumbsup:
The broken peice on the right is like the cap on the other side only it has a hole through it for the shaft to protrude for the pulley. Obviously needs replaced. But If too $$$ I can make this as well out of some 1/4" steel and a 90 degree grease fitting:thumbsup:
But the bearing is my issue now. The shaft is ~ 28.40mm diameter (just under 1-1/8"), and the housing bore is 62mm like the other side. All my searching I cannot seem to find a bearing this size.
Hopefully flailmaster will be able to come through with just a bearing. Because I am NOT going to spend $100 for the whole hub assembly. It is just puzzling why they used a b@$t@rd sized bearing:confused2: The bearing did NOT spin on the shaft and chew it up either if that is what you are thinking. The shaft is true and I even confirmed with the ID of the pulley:confused2:
Suggestions are always welcome
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
Location Info Please
2008 Scag STT52V-27CH 52in Zero Turn Mower (A59228)
2008 Scag...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
International...
2006 Godwin GHP45KW-RC45kW Towable Generator (A59228)
2006 Godwin...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
