FLAIL Mower ID
/ FLAIL Mower ID
If anyone is still folling me on this thread, I have a new question for ya'll.
Since I am going to just use a common 6206 and 6007 bearings, the inner part toward the cutter shaft that IS exposed, should I stick with the metal shield, or a rubber seal on the bearing?? I have both types.
/ FLAIL Mower ID #22
I would use the metal shield. If any thing gets wraped around the shaft I think the metal shield would be tougher.
Bill
/ FLAIL Mower ID #23
If an only if the clearances allow it use the "proper" lip seals facing the cutter shaft to seal the bearings and keep dirt and debris out.
Please check the rotor thouroughly for a part number plate welded to it to verify the rotor type.:thumbsup:
/ FLAIL Mower ID
:confused2::confused2::confused2::confused2:
There are no lip seals. Just a bearing on a shaft. I was asking as to which would be better, shielded bearing(ZZ) or rubber seal (RS)
And what are you talking about with the rotor???
/ FLAIL Mower ID #25
LD1,
I had a chance to purchase a flail mower in about the same shape. The shaft was actually fallen out because of the bearing coming apart. I could not locate a model on it or a brand etc. I passed at $100 because I was afraid I would just be stuck with it and no parts.
So I am reading your thread with intrest, but don't have any great knowledge to add. I am looking forward to a review!
/ FLAIL Mower ID
LD1,
Well, I got the bearings, and all the parts I need, but it will be awhile before I re-assemble.
I am going to tear it appart further, clean up, and re-paint the thing before she goes back together:thumbsup: Maybe a month or so before she's all done.
/ FLAIL Mower ID #27
The mower "rotor" is the shaft that has the 4 rows of grass slicer hangers and grass slicer knives.
On many large parts the ID tag is quite often welded to the part after the numbers for the part have been stamped upon it(the tag) .
Just be sure of the parts installation sequence as you may have been saddled with someone elses version of "Maintenance" and there is no point in "making a mistake twice".
/ FLAIL Mower ID
Flailmaster e-mailed me a parts diagram, as well as looking at replacement parts on various sites comfirms that there are NO seals. Just a bearing. The "seals/shields" I am refering to are the ones on the ball bearings themselves. And just wondering wether the rubber seal bearings OR the metal shield bearings are better for this application. Because I have them both:thumbsup:
/ FLAIL Mower ID #29
Flailmaster e-mailed me a parts diagram, as well as looking at replacement parts on various sites comfirms that there are NO seals. Just a bearing. The "seals/shields" I am refering to are the ones on the ball bearings themselves. And just wondering whether the rubber seal bearings OR the metal shield bearings are better for this application. Because I have them both:thumbsup:
As long as you dont blow the seals when greasing the bearings, the metal ones will be fine. you want very little new grease in the bearings 6-7 pumps at each mowing as they seal very well and you want to see very little new grease exit the bearings other wise the seal is blown totally.
/ FLAIL Mower ID
So thats 2 votes for metal and 0 for rubber so far:thumbsup:
/ FLAIL Mower ID #31
Ok, I have to ask, since I've recently acquired a 60" flail mower that is made by ?Agri-Tech? that is in similar shape. Well, actually it's not in as good of shape. I've been doing some welding on the body since mine apparently WAS used to replace a bush-hog. It has tears in the metal where there weren't even seems. Anyway, I'm needing to replace the bearings, and I wanted to ask, what is the best way to try balancing the drum if I make it that far, so that the thing doesn't rip itself apart from vibration?
I'm really not trying to hijack the thread, I just figure you are going to have to do the same thing and I would like to find out how you are going to go about it.
/ FLAIL Mower ID
If you are refering to the cutter bar that has all the knives and stuff attached....well I dont think they are balanced.
They probabally are to a degree when they are designed, with the placement of the knife hangers and stuff, but if the shaft isnt bent, and you arent missing any knives/hangers, then I wouldn't worry about it.
/ FLAIL Mower ID #33
EVERY flail mower rotor is balanced on a dynomometer set up ( I cannot guarantee the chinese made flailmowers are built with balanced rotors!!!!!!, or the other flailmowers offered by Northern Tool being made of a single hollow steel tube) to guarantee true running and avoid any possible chance of an explosion and parts separating from the massive centrifugal forces created by the rotors high speed of rotation while working.
No need to balance the rotor drum if everything is intact-
Meaning:
1. all knive hangers are intact
2. all grass slicer knive(s) paired and single knives attached to the end hangers for mowing overlap are mounted on the knive hangers.
All the knives and all the hangers MUST BE ATTACHED to ensure the rotor is
BALANCED at all times.
If knives are missing the corresponding knive set 180 degrees opposite and its hanger must be removed.
IF you have a 2 or three row knife rotor the corresponding broken knives must removed or replaced to maintain equal centrifugal force at all times.
I have added extensive material describing how to examine a rotor for true running in several posts here for everyone.
/ FLAIL Mower ID
Another update. I got an e-mail back from montague with a parts diagram:thumbsup:
It DOES appear to be an F6. Identical in every way to the pics they sent me. They even asked how many cutter stations it has, which is 92. The diagram of the F6 they sent confirms it. But they were still no help with the odd sized bearing. O'well, I've got it figured out now with using the 35mm ID 6007 bearing and the bushing.
/ FLAIL Mower ID #35
I have a theory...I think at one time the cuttershaft and pulley was replaced by one for a Mott72. The pulley for the 72 has an ID of 1-1/8", and the pulley end of the cuttershaft has a shoulder turned on it for this size. The bearings however are the same ID as the F6. Looks like someone had to replace the assembly when they couldn't get the original one for the F6, and then changed the bearing on the pulley side?
/ FLAIL Mower ID
Not sure I follow you here??
You say that the Mott72 has a pulley of 1.125 right?
But the bearing was STILL the same @ 30mm ID?? Like a stepped shaft that had a 30mm diameter for the bearing and steped down to 1-1/8 for the pulley???
If that is what you are saying, the bearing I took off was NOT 30mm. It had an ID of 28.4mm which is just under the 1-1/8 mark. No stepped shaft.
So unless someone "turned" that shoulder off and found this ODD sized bearing of 28.4mm x 62mm, I dont believe this to be the case. But I could be wrong.
Do you still believe it is a F6 or do you think it is a Mott 72 fine cut like flailmaster says?? I have nothing to compare it to. What is the difference between a F6 and a Mott 72????
/ FLAIL Mower ID #37
I agree with fluggie on this part as well- Its also possible the rotor was substituted when it was assembled at the Mott factory in Ohio. Part substitutions happen more than people realise...................... It wont damage the mower for sure.:thumbsup:
/ FLAIL Mower ID #38
The cuttershaft on the old F6 was straight on both ends, ie. no shoulder on the pulley side, and the OD of the pulleys was 8.5", and the bearings were 30mm ID.
The cuttershaft on the Mott 72 was stepped down on the pulley end...the pulley is 8"OD,
and 1 1/8" ID. The inner part of the shoulder is 30MM. where the bearing goes.
Both top and bottom pulleys should be the same OD, ie. on the F6 they are 8.5", and on the 72 they are 8".
It is definitely a model F6...the hitch, side drive, etc. are identical to the lists, and the 72 does not have the triangular grease covers.
David
/ FLAIL Mower ID
David
Boy, you have been extremely helpful:thumbsup:
When I get home tonight I will have to measure the pulleys.
Something just isnt makeing any sense here. Because there is NO step to the shaft. It is a straight shaft but it is the 1-1/8 (28.4mm) diameter:confused2:
Maybe at some point in time, someone "turned" that step off and managed to come up with a one-of-a-kind bearing that had a 1-1/8 ID and 62mm OD. I know there are quite a few metric 6200series bearings that DO have the imperial INCH sized inner race. I have seen them at TSC before. Like 203 bearings with a 5/8 ID and 204 bearings with 3/4" ID. I just cannot find a 206 with a 1-1/8 ID:confused2: But I guess someone did somewhere along the line.
Either way, The 6007 with a bushing should work just fine. Its just puzzling the heck out of me, thats all. I will measure the pulleys tonight. I am betting they are 8" and someone turned the step off. If they are 8.5" pulleys, then that will jsut confuse me even more:confused2:
/ FLAIL Mower ID
David
UPDATE
See if you can splain this to me:laughing:
Both pulleys are 8.5", but it still has the 1-1/8 bore (25.4MM):confused2:
EDIT: I also wanted to ask you (since you have been a great help already), There are two bolts that hold the mower "deck" and cutter bar to the 3PH assembly. These are slotted about 4" to allow the cutter to move closer to the tractor or farther away. Do you know what the purpose of doing this would be? I can see no benefit of a few inches closer or farther from the tires
2014 Isuzu NQR Crew Cab Landscape Dump Truck (A59230)
2014 Isuzu NQR...
2019 CAT 259D (A60462)
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A59230)
2008 Ford F-550...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
