trans repair jinma 284
/ trans repair jinma 284 #1
garydalton
jinma 284
need info on trans repair no forward gear reverse ok suspect internal shift fork. disconnected cable( shifted trans control arm manually) still no forward gear
/ trans repair jinma 284 #2
I am assumeing you have shuttle shift?.
Check the roll pin under the right floor pan where the cable attaches to the side of the transmission to see if it has sheared off.
Ronald
/ trans repair jinma 284 #3
Service advice before 6am beats a manual ! :thumbsup:
Ronald
yes its shuttle shift the roll pin is fine I removed the cable the arm shifts but it only has reverse did not know if the shift cover can be removed with the shift armstill attached or if roll pin and arm must be removed and shaft stays in trans or can be removed all together
thanks Gary D.
/ trans repair jinma 284 #7
No problem, glad it helped.
Ronald
Ronald
I finally got the time to pull shift cover off for shuttle as suspected fork broken ,only # on fork looks like casting # ,
(k-20)
After tearing garage apart I located the parts list manual that came with the tractor looks like the fork # is 254.37.522 Is this something that is in stock or will it need to be ordered?? If I have time I will try to call on phone Gary D.
/ trans repair jinma 284 #9
That is the correct part number ...... In stock.
On a side note; You can purchase just the fork or the fork side plate assembly. SOME people have a hard time replaceing the fork due to the detent ball. You may want to take the fork off the shift rail (if you have not already) to check the condition of the detent ball and practice reassemble ?
Ronald
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
MINI FLAT BOTTOM GRAPPLE (A61572)
MINI FLAT BOTTOM...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2022 John Deere 5055E (A60462)
2022 John Deere...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
