Belarus 250 no power
/ Belarus 250 no power #1
rickde
belarus 250as
Cranks great, but instead of feeling like a 30 hp its feels like a 5 hp. Has no pulling power at all.
/ Belarus 250 no power #4
Have you checked the decompressor? Small lever on the right side at your feet. pull it out for full compression.
Next thing I could think of is that you are not firing on both cyclinders, bleed the injectors.
How many hours? How long since the injectors have been cleaned?
Have you used iether to start the machine? The answers will help me figure out how to help you..
Thanks for the reply, I feel like a know what is wrong now. The injector pump actually has 2 pumps. One to feed to fuel into the main high pressure pump. The feed pump is working fine but the high pressure pump is not working. I can loosen the hose from the 2nd stage fuel filter to the back of the high pressure pump and turn the engine over and get all kind of fuel. If I loosen the pipes going to the ejectors I get very little fuel when I turn the engine over. It appears to me the tractor is running on the fuel feed pump and not the high pressure pump. This would explain why it is also hard to start. It has to turn over and over before it will finally start. Its getting just enough fuel to run the tractor. Also I have 2 of these tractors, one for spare parts. If I can't fix the high pressure pump I'm going to replace it with the one from my parts tractor. I just could not figure out what to change.
/ Belarus 250 no power #6
I would also look into the fuel filters, it does not take too much bad fuel for them to get plugged....good luck.:thumbsup:
I do need a 2nd stage fuel filter for sure. Now to just find one. My parts tractor has 2 filters on the second stage but the one I use has one bigger filter. Having a hard time finding one of these. Thanks
Has any body ever removed the fuel injection pump on Belarus 250as:laughing:. I have all the fuel lines disconnected and the 4 nuts holding it on off. It comes out about 1/2 inch then stops. Is there sometime on the inside holding it from coming out? As always I thought this was going to be easy.
/ Belarus 250 no power #10
Send Nike a private message maybe he can scan some stuff for you, I believe he has the manual. He also has rebuilt two diesel from scratch pretty much for fun:laughing: He is making hi old Belarus work pretty good for a fraction of what I paid for my new tractor, lol. He also says you can get most of the stuff online.
:thumbsup:
/ Belarus 250 no power #11
Hi rickde, I noticed your details are a little thin? It seems to be a community type thing to give a general local to where you are from, you don't have to but it lends to a community sort of feel on the forum.
Hope you get er done!
Bill
/ Belarus 250 no power #12
It is stopping because there is a gear on the other side of it.....You have to take the front housing off of the motor, and remove this gear. These gears are timed as well. you need to be aware of the timing of the motor. I will check the manual and get back to you. :cool:
I have a 250 AS, lots of fun, love it. :thumbsup:
/ Belarus 250 no power #13
You first must remove the tactometer sender, then the aluminium cover. This should get you to the gear clocking ring. TAKE PICTURES, and write down how it is clocked. Do not remove this gear until you are sure of the timing marks and how the go back. You could find yourself in a world of pain, if you do not. Once the timing gear is off the pump should just slip out.
There is a Belarus parts place in the U.S.
I get my parts on e-bay, never a problem and real fast.
You can adapt an aftermarket filter setup for the fuel supply after the course filter.
good luck, you can e-mail me direct if you need more info.....:thumbsup:
Nike
First thing is thanks for help and I mean thanks.
I am seeing what you are talking about with the gears. Just a maybe question. The bracket that the tract fits into, can I leave one side bolted together but loose then swing the bracket out out the way and remove the center nut then pull the injector pump out without taking the timing gear and ring completely apart. Are is this all going to fall apart when I pulled the pump out?
Rick:licking::licking:
/ Belarus 250 no power #15
Just a note, if your starter is slow, try one of the new geared starters. My son bought one for his and it is world of difference in cranking..Good luck on your replacement, and timing issues. Jy.
/ Belarus 250 no power #16
Nike
No biggy pulling the tac it will fit back in without complication and it does not have to be clocked...
There is already a mark on the gear that should line up with marks on the other gear it meshes into. once those marks are lined up you should be able to remove the pump assembly and not worry. I know you want to get it back up and going as fast as possible but ; slow down, take your time. Get a paint stick and mark it yourshelf if you do not want to rotate the engine, lable every thing and write it down. I do this even when I know what I am supose to do (My memory is not what it was :laughing:) I also take a lot of pictures, worth a thousand words I hear.
Before you pull the pump, check your lines. A little leak somewhere will cause the same lack of power. :thumbsup:
Nike
Since you have been so much help I would like to tell you what I think is happening. I removed the fuel lines going to the injectors at the pump. I turn the engine over and see nothing coming out of the pump and I mean nothing. I loosen the line coming into the pump from the 2nd stage filter. I turn the engine over and see all kinds of fuel coming to the pump. So at that point I am thinking how is this thing running at all. So with everything back and air pumped out with the hand pump it will start but has to turn over for awhile before it will start. Now here is the good stuff. I removed both the fuel feeds at the injectors. I turn the engine over and the fuel starts coming out of the upper line, the over flow line. I think the tractor is running off the fuel feed pump pushing fuel backwards thru the overflow lines. I know this sounds crazy but it is what I am seeing.
/ Belarus 250 no power #18
You seem to be on the right track in changing out the pump..... If I can be of future assistance you can send me a message thought e-mail.
The 250 is a great little tractor, we need to keep as many of them running as possible.
Does your 250 have a loader? I am looking to build one for mine but need help in finding out where it connects to the tractor at midpoint, photos would be helpful...
This maybe a second send. I was giving you a response and my PC went kind of crazy. No loader, but wish I did. If you ever need anything and can not find it. If,:laughing: it is on my spare tractor it is yours. Thanks again for the help.
Rick
/ Belarus 250 no power #20
let me know how you made out with the Pump, Did you get it running? I have the manuals and eventualy will upload them into the computer.
Thanks for the offer, I may need to take u up on it.
If I find plans for the loader I will pass them on...
