CJ-4 oil no-no by Kubota
   / CJ-4 oil no-no by Kubota #21
One more thing when is it that all the engines are going to have to meet the new specs, and have particulate filters?
   / CJ-4 oil no-no by Kubota #22
This is another one of "those" threads. My L3400 manual says, "The CJ-4 engine oil is intended for DPF (Diesel Particulate Filter) type engines, and cannot be used on this tractor." What sucks about that is, every single diesel oil container I looked at today says CJ-4 in the API circle.
Here's what I find confusing: People on here will say that Kubota is just covering their rear-ends and since they make more than just tractors...and to just use CJ-4. My tractor-specific manual says not to use it.
Also confusing is, all the oil I saw today says it meets or exceeds CH-4 and CI-4, but in the little API circle it says CJ-4. The manual says use CF or better with a TBN of 10 minumum. Everything I saw fit this but the little label says CJ-4.
I saw a lot of (what I thought) was good diesel oil on sale but didn't buy any of it due to the API label. I'd ask you guys to kick me around and straighten up my confusion here, but I'll get 15 different answers and I'll probably still be confused afterwards....somebody who knows 100% for sure please tell me what I need to know here....
   / CJ-4 oil no-no by Kubota #23
Call or email Kubota. Get it straight from them.
   / CJ-4 oil no-no by Kubota #24
Spec. "ACEA C3", it means it is suitable for engines with a diesel particulate filter.
it's a low SAP(Low Sulphur and Phosphorous)oil reducing particulate build up in diesel particulate filters.
not all CJ4 HDEO's are low SAP oil's with C3 rating,many ARE NOT.
   / CJ-4 oil no-no by Kubota #25
Well now, I have two pails of CI-4 and have been trading it straight across for CJ, maybe I should be asking for a bonus.
I have found CI-4 oil at Walmart, also at the larger parts stores there own brands of oil. I would also call the local oil-fuel distributors you would have to buy cases or pails, but that is an alternative. As is calling the different tractor dealers, that would be the more expensive option I would say, but!
   / CJ-4 oil no-no by Kubota #26
Maybe everybody should do that, instead of posting things like this here! Funny thing is, I already got it straight from Kubota in printed form, in my manual. I could get Kubota-branded oil from the dealer, for 2x the cost, I suppose.
   / CJ-4 oil no-no by Kubota #27
If Kubota knew anything(they should) they should know not all HDEO's are ACEA C3 rated low SAP oils, and CJ4 can be used with out issues.
anyway this thread is long enough,good luck guy's
   / CJ-4 oil no-no by Kubota #28
You might be surprised how economical the Kubota oil really is. It surely isn't cheaper than most alternatives, but it's not that much more either. For the difference of a few dollars, I've been using their oil since I got my tractor, and will continue as long as it's under warranty. After that, who knows?
Sean
Kubota has been behind the times for years. The ACEA C3 spec is NON USA here so why should people in the USA care?
In my eyes use any diesel oil in then Kubota, to some extent (aka small units), and be happy.
   / CJ-4 oil no-no by Kubota #30
...Kubota has been behind the times for years.
...In my eyes use any diesel oil in then Kubota.
^^agreed...
...The ACEA C3 spec is NON USA here so why should people in the USA care?
^^ disagree...
It can be found at PepBoys and some Walmarts, Mobil,Delvac and Amsoil and any BMW/Mercedes dealer just to name a few...
EZ Go Golf Cart (A57453)
EZ Go Golf Cart...
Ford 3000 Tractor (A57453)
Ford 3000 Tractor...
BROCE BW260 SWEEPER (A60429)
BROCE BW260...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
2014 Ford F-550 (A55973)
2014 Ford F-550...
4800 PSI Hydraulic Hoses/CAT Hose (A57454)
4800 PSI Hydraulic...
