Rim Guard Ballast
/ Rim Guard Ballast #2
Any thoughts on the product- Rim Guard- used to load tires?
Thanks
It has weight, though not quite as much as calcium chloride, is non corrosive (guarding your rims), is biodegradable according to the guy at the tire shop.
Cost's about the same. Most of the expense in adding ballast is not the product itself, but in the labor involved in getting it into or out of your tires. They charge in both directions plus a disposal fee.
Dennis
/ Rim Guard Ballast #3
Dennis
CaCl is a lot cheaper per pound, but there is the corrosion issue.
Of course, there have been a lot of tractors with CaCl in the tires for decades with no rust through.
Main thing, Jim...get those tires filled!
/ Rim Guard Ballast #6
Cast weights you never loose no matter how many times you have flat tires!!!!
Fluid in tires does hurt traction when compared to liquid filled tires in ag work.. It takes about 3/4's the weight of cast to equal the same in liquid.
Just an option!
Calcium is about 1/2 to 2/3rds the price of rim gaurd.
/ Rim Guard Ballast #7
Just an option!
Hi Art...
jjmjones got the rimgard as a freebie from the dealer, so he's good to go.
Art, you might want to review what you wrote(bolded font). I think you said the same thing twice.
/ Rim Guard Ballast #9
I just bought a new tractor and will definitely go with Rim Guard. We are having trouble getting it were I live (Okanagan region of BC). My tractor should be here late next week and I will take delivery with no ballast. The tire dealer in Salmon Arm will have Rim Guard the next week and send a service truck to my place to install it onsite. That's an advantage of Rim Guard since they don't have to install tubes.
There is another product available Bio-Tire Ballast which is starting to compete with Rim Guard. That is also available in my area but the dealer is out of stock. In the US it is handled by some Les Schwab dealers.
I looked at two different dealers (Kubota and Kioti) and was surprised they were not aware of beet juice ballast. Both said they intend to recommend it.
I prefer beet juice to calcium for the peace of mind of not having an environmental problem in the event of a puncture.
I think beet juice will become more popular as awareness increases.
/ Rim Guard Ballast #10
/ Rim Guard Ballast #11
My tractor dealer quoted me about $300 to add tubes and CaCl. It was approximate because he takes the tires to a local tire shop to have tubes and CaCl installed before putting them on the tractor (the tires and rims are not already on the new tractor when it is shipped).
The firm quote which I have accepted for adding 70 gallons of Rim Guard onsite is $334 (@$3.50 per gallon) and includes an extra $30 to travel to my place.
The Rim Guard is coming from a different tire shop than the one my tractor dealer would have used for the CaCl. That tire shop uses Bio-Tire beet juice but is out of stock. But he had quoted a price of $3.00 per gallon which would have brought the price to under $300.
The high cost for CaCl is due to my having to add tubes.
Here is a link to an interesting article on tire ballast:
http:// Comparing Types of Liquid Tire Ballast | OrangeTractorTalks
/ Rim Guard Ballast #12
I just had Rim Guard install in my tractor. I didn't want nothing to do with CaCI. Salt will just rot my rims.
At $3.00 a gallon and the environment safe product was worth it to me. Beside the ride improve also.
/ Rim Guard Ballast #13
If you don't mind. How many gallons what size tires and how much total? I am thinking about it but I am cheep, so I am also thinking RV antifreeze but no matter what I am holding out for tubes in the tubeless tires. Most people say I don't need the tubes but as you said rusted out rimes, been there done that didn't like the taste so I err on the overkill side!
/ Rim Guard Ballast #14
You'll need tubes for calcium. Had Ca in my tires for 27 years and this was a tractor that did mostly logging so it ventured into some pretty rough terrain. The nice thing about calcium is that it is a do it yourself job at home should you spring a leak. Beet juice they seem to guard as if its a specialty item: Can only buy in large batches, need special stuff to pump it, only certain shops have it. Did I have any rim rot? Yes, after 27 years a small hole that I had rewelded when I changed out the tires and tubes.
/ Rim Guard Ballast #15
Farm_Tractor_Liquid_Tire_Ballast_1.jpgFarm_Tractor_Liquid_Tire_Ballast_2.jpgFarm_Tractor_Liquid_Tire_Ballast_3.jpg
/ Rim Guard Ballast #16
I don't remember the tire size on my 1025R, but took $86. at $3.00 a gallon so that should be 28 gallons plus labor and tax in N.Y. for a total of $110.
I always look at it like this. Do it right the first time and it will be the lowest price you will pay.
When you cheep out and have to redo it it can cost you double.
/ Rim Guard Ballast #17
i like tubes anyway.. loaded or not!
/ Rim Guard Ballast #18
Has anyone used windshield washer fluid for ballast? Several the dealers around here are using it. Are there any thoughts on using it?
/ Rim Guard Ballast #19
yep.... i've used it. I like eco af better though...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
207277 (A52708)
207277 (A52708)
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
(5) VARIOUS SIZED CATTLE PANELS (A63290)
(5) VARIOUS SIZED...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2010 John Deere 4830 Sprayer (A63109)
2010 John Deere...
