BX2230 Ballast Box Weight?
/ BX2230 Ballast Box Weight? #1
andyrud
BX 2230
I am building a ballast box for my BX2230 with a FEL. Does anybody know how much weight I need to put in the ballast box?
Thanks in advance,
Andy
/ BX2230 Ballast Box Weight? #2
I have the factory box on my 1830 and my dealer told me it would weigh about 900-1000lbs when filled with the fine gravel I was using. If the one you are building is about the same size then that is what you will expect to have.
Regards
DGS
/ BX2230 Ballast Box Weight? #3
Regards
DGS
I thought the 3 point lift capacity for a BX machine was around 700 pounds??? The Kubota ballast box for my Grand L weighs 1250 pounds filled with concrete. Philip.
/ BX2230 Ballast Box Weight? #4
Regards
DGS
That's overkill for a BX. Should only need ~500lbs.
Specs on a new BX, the 3pt lift capacity is 670lbs.
/ BX2230 Ballast Box Weight? #6
My BX2230 manual states 300 pounds for the BX series. I think it was 500 pounds for the B series.
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
