Mowing Mowing with the 2520
/ Mowing with the 2520 #1
prosperity
North Central Pennsylvania
JD 2520
A quick bit of history first.....
I've had a small mowing business for over 15 years, but last year decided to slim it down to just a couple customers with larger acreages.
I always had a zero-turn mower - last one was a 757 and a mowing machine for sure. I sold it before last mowing season, bought a 62D mower for my 2520, and now just do those couple properties plus my own 3-4 acres. I have R4 tires on the 2520 with the rears loaded.
Quite a difference mowing with the 2520 vs. the 757 for sure, but I was expecting that.
Now as I am getting older and less limber it seems, after an hour or so on the 2520 I am just sore all over. Between the stiffness of the R4's compared to the soft turfs on the 757, and the terrible seat on the 2520.
Everyday I mowed I would think about this thread where a Michigan suspension seat was adapted to the 2520:
http://www.tractorbynet.com/forums/john-deere-owning-operating/147265-2520-suspension-seat.html
Since it has been a couple years since that thread, I just wanted to ask around if anyone has installed this seat since, and if there were any other modifications made. In that thread, in post #15, he attaches a document with the dimensions for the plate needed.
The only other thing I can see to make the 2520 ride better for mowing is installing turf tires - but I use my tractor with the loader quite often, and spend a bit of time in the woods with brush hog & tooth bar where turf tires will just not do it.
Have you lowered the air pressure in the tires?
No I haven't because the rears are loaded (liquid). Plus, the R4's are so stiff I don't think it would make any difference.
And that is a good point - I remember when I first got my 757, it rode really bad - only to find that all the tires were way over inflated - brought them down to the low spec, and made a world of difference.
/ Mowing with the 2520 #5
I elected for wheel weights on my 2520..tire pressure always makes some difference, but my guess would as you said just not enough..I put a Michigan seat on my Zero Turn and love it..Simple bolt on for it..
I would guess if you did not want the 2520 seat to flip forward it might be easier to install, but I have not investigated it yet really.
I want to apologize JDdude - I discounted your idea of tire pressure too quickly without thinking about it.
When I had my 2210, even though it had turf tires, I would routinely add pressure to the front tires for loader work, and deflate for mowing - it did make a big difference.
I am going to experiment with the front tires - not sure about the rears as they are loaded - I will have to see what is in them now to see if I can go any lower without the threat of breaking the bead.
I am most likely going to do the seat also - just have to justify ~$400 for it.
I sure miss my 757 during mowing season, but I'll get the 2520 to be more comfortable with a combination of the above.
Thanks for the input folks!
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2022 EZ-GO ELITE...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
429858 (A61165)
429858 (A61165)
