BX24/BX25 question
/ BX24/BX25 question #1
GSmith4965
Can anyone help me understand the differences between the bx24 and the bx25? Is the bx25 merely a newer model?
/ BX24/BX25 question #2
If I understand correctly, the 25 has a higher capacity pump (hydraulics work at lower RPM) and the hood and fenders are plastic on the 24 and metal on the 25. Also, the 25 has been fitted with a HST guard (although rumor has it that early 25's lack this feature)
/ BX24/BX25 question #3
the bx 25 is the newer model, same hp, capacity. It has metal hood, fenders etc not plastic.
The hydraulic priority flow valve allows hydraulic functions at a lower engine speed, and the transmission is internally different due to complaints of abrupt reverse stopping.
/ BX24/BX25 question #4
You nailed it...Not much diff between the two. Seems like Bota always has issue with the hyd on these units...The old 22 was the creeping, 23/24 was the stop deal. The plastic hood and fenders has advantages (no denting), no rust etc.
/ BX24/BX25 question #5
If, by chance, you are looking at a used BX24, you might want to know that multiple versions of the fender/floorboard were sold on this unit. Kubota went to plastic on hood and floorboard when introducing this model. The first version experienced numerous cracks. There were recalls and reinforcement kits. They kept trying to fix it and later and later models had successively different versions of the fender/floorboard. You can find all the details in the archives here. If you are looking at a used one, it would be beneficial to find out which manifestation of fender/floor it has and do some reading in the archives before putting down any money. On the 25, they went back to metal; this one has been a solid performer, all bugs worked out and gone. Almost nobody complains about the BX25.
The BX24/25 have the curved backhoe boom, while the 22/23 have the straight boom. There are other small (engine, pumps, seat) differences as well.
/ BX24/BX25 question #6
For the metal body parts alone i would go for the 25. I have a 24 late model and still have had the lower cowl crack where it mounts and the headlamp module crack, the trans issue is very annoying. I got a good deal on a demo 24 but wish i waited. Also what people need to rember is that if you are unfortunate to "bump something" with a plastic hood body or have a rock hit it and crack it you are done. Metal can be welded bondo'ed to death plastic has NO place on these machines thus the change back to metal.
/ BX24/BX25 question #7
I've been totally satisfied with my BX23.
Based on my praise, a friend bought one of the first BX24 and has mixed feelings about it... it has done a good job for him, but the issues with the plastic cracking and needing reinforcing gets old.
So far the BX25 seems to have gotten it right.
/ BX24/BX25 question #9
Just one added note. The engine cowling on the BX25 is still plastic. They went back to metal for the hood itself, but the side skirts are still plastic.
/ BX24/BX25 question #10
I've bumped lots of things...no permanent damage, only scratches.:thumbsup: Bumped fender hard enough to break out taillite...twice...if had been metal, would be bent and rusty by now...:)
/ BX24/BX25 question #11
... The engine cowling on the BX25 is still plastic. They went back to metal for the hood itself, but the side skirts are still plastic...
A note of clarification on the above - It is true that the side skirts on the BX25 are made of plastic; however, it should be noted that these same parts were also made of plastic on the BX24, BX23 and BX22 as well.
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
MISC PALLET OF TRUCK PARTS (A65643)
MISC PALLET OF...
J.I. Case 2090 Tractor (A66285)
J.I. Case 2090...
2014 BMW 435i Convertible Coupe (A64557)
2014 BMW 435i...
2005 International School Bus (A64194)
2005 International...
