3-point log splitter
/ 3-point log splitter #1
tractorboy5500
Gold Member
Conroe TX
Mahindra 5500 4WD, 275 FEL
I have a set of rear remotes on my Mahindra 5500 4x4, when using a log splitter I am guessing that I have to tie back the rear remote valve and use the valve on the log splitting unit. Now I have read where people having problems with an open center or closed center valve, if i buy a 3-point log splitter, which is the correct valve to have, open or closed center??? If i am thinking right it would be a closed center, but I have been wrong so many times before, maybe there is an expert here to help. Thanks Allan
/ 3-point log splitter #3
I am by no means an expert, but I believe you would want an OPEN center valve.
A closed center valve would NOT let the fluid return back to the tractor with the lever in neutral UNTIL the pressure relier valve opened. This means your tractor pump and fluid is seeing MAX pressure all the time.
Open center would simply let the fluid return back without building ressure. Until you operated the valve at the logsplitter.
Thanks guys, I just had it backwards, this will keep me out of trouble.
HARDEE 300 GALLON SPRAYER (A64278)
HARDEE 300 GALLON...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2017 JOHN DEERE 85G MINI EXCAVATOR (A67148)
2017 JOHN DEERE...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
