Comparison mechanical shuttle vs hydraulic shuttle
   / mechanical shuttle vs hydraulic shuttle #1
Tdcw4
Member
Can anyone comment on the differences? Do u have to clutch either one to change direction?
   / mechanical shuttle vs hydraulic shuttle #2
The mechanical shuttle require the clutch to be engaged to change direction. The hydraulic shuttle doesn't require the clutch to change direction.
   / mechanical shuttle vs hydraulic shuttle #3
We had a Case CX80 with synchronized hydraulic shuttle and you had to use the foot clutch to go from forward to reverse. We traded it in this year for a Kubota M8540 with hydraulic shuttle with which you don't have to use the foot clutch. The hydraulic shuttle selector engages the clutch automatically when you move the lever half way through the arc.
We love the utility of the hydraulic shuttle especially when doing loader work.
I was under the impression you didnt have to clutch on either model just that engagement was quicker and smoother on the hydraulic version
   / mechanical shuttle vs hydraulic shuttle #5
Nope, we have mechanical on our back hoe and had it on our Case and you had to use the clutch to change directions.
   / mechanical shuttle vs hydraulic shuttle #6
Mechanical shuttle (non-synchronized) - You have a separate shift lever for forward-reverse shuttling. Requires use of foot clutch and must be motionless when shifting between fwd-rev. Single plate dry clutch;
Synchro-shuttle (synchronized) - You have a separate shift lever for forward-reverse shuttling. Requires use of foot clutch but do not have to be completely stopped when shifting between fwd-rev; Single plate dry clutch;
Hydraulic shuttle (power reverser) - You have a separate shift lever (usually a turn signal-like stalk) for forward-reverse shuttling. Does not require use of foot clutch since clutch is electro-hydraulically engaged with shift lever. Comes hand-in-hand with more durable multi-plate wet clutch.
Should have been more specific on a kubota 5040 ?
Standard
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
Tank Only (A59076)
Tank Only (A59076)
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
