Backhoe Which Backhoe To Buy.?
/ Which Backhoe To Buy.? #1
the fox 1940
Windsor, Nova Scotia
Kioti CK30, 2005
I have bought myself a Branson 2010-3510i and want to buy a Backhoe for it.
Anyone out there got any ideas on which one is the best one to buy ?
I have looked up the Woods BH80 and the 8620 ( Don't know who makes that one ). I have no idea who makes the Backhoe for Branson Tractors ? Do you ? There are others out there I know but I would like to have some idea and price on this stuff when I go to the Dealers. was wondering about bushings and pins as some do and some don't have bushings.What is the cost of these in the USA now.????
Thanks for any information you can send me.
The Fox
/ Which Backhoe To Buy.? #2
Not to pop your bubble Fox Man, but unless you have a regular use for it, they are kinda a pain to put on and off the tractor and have very little reach. I started with a Woods 750 and it was very handy, and a dandy subsitute for a shovel but that was before the flood of mini excavators available (rent and sale). What I learned was, that for a lot of general "backhoe" work is, that it's not how deep it will dig but how far you can reach! Reach is something that I had not considered. With the short reach comes constantly repositioning the tractor, and lastly, short reach means a short "throw" of your material coming out of your hole. If you don't have a rental place with a mimi ex nearby, go for it!!I eventually could justify an excavator, and soon discovered a few other things that I had not considered much, an excavator is repositioned in seconds (no outriggers, no seat to switch) and that you can "throw" 360 around yourself.
The woods (3pt) 'hoe had a self contained hyd. system (pump, tank, valve) and you had to throw the punp on your pto. I like this idea because the hyd. components were all "sized" to each other with no variables (your tractor only needs to supply 540 rpm pto) no worries about PSI and GPM from the tractor. But don't let me talk you out of it, just think of the items I mentioned. DIG IT!!
/ Which Backhoe To Buy.? #3
I can vouch for the Woods BH80x as a very well made BH. I presume they have a subframe that will fit your Branson and you'd certainly want one.
Regarding need for BH, the point that mini excavator rentals are cheaper and more powerful is true but if you have regular use for a BH or a project that will require intermittent but frequent use (or you live on an island like I do) then owning a BH can make perfect sense too.
Last I saw, eBay prices for BH80x was in the $5-6K range. Buying from a dealer who does all the assembly etc it might be a bit higher.
To both of you on your suggestions. They are very valid points which I will take under advisement. But from that I owned a Kioti Backhoe here last year and yes I agree. Short swing, and yes you are always having to move it.
I have about 8 Acres of land here and I could use it from time to time.. The Mechanic at the Garage said they have a Machanic here that can slide them on and of in about 10 minutes.I know if I put it on I won't be taking it on and off .... Then there is the PRICE around here they are talking about $7000.00
plus 15 % Sales Tax, so you can see this is getting rich. I thought I would phone around and ask some questions on pricing .This could make be forget it all together. But I am still interested in who sells the best one. The Kioti had soft split bushings in it and at 800 hours I was putting Pins and Bushings in it. And I thought it should go longer then that ( although I did buy this tractor second hand ) And grease was not something that was used to often. So yes maybe renting a machine might be cheaper in the long run when I need one for some dirt moving.
The Fox
They do have a subframe that comes with it. And I would not put one on without a sub frame. I have heard Woods put out a good BH80X.. Shell check that out today. One feature I liked about one unit I looked at was the Boom arm Lever could be pushed ahead into a float position so when you pull the Dipper Arm in toward the Tractor the boom will float and let the bucket slide across the ground without digging in. Great for leveling etc. Does the BH80X have that feature ??
The Fox
/ Which Backhoe To Buy.? #6
The Fox
Interesting. I own a Woods BH90x but have never "discovered" the feature you describe. I don't recall feeling any indent the way I do when putting a FEL into float position. I'd double check with Woods to confirm that feature if it is important to you (then let the rest of us know what you learned).
I got some quotes on a BH 90 Backhoe today and they want from $ 8625.00 to $9918.75 for one ( installed ) and the Branson dealer will sell me one for
$ 6200.00 or $ 6500.00 installed . So I think I know where I'll be going ..
But you know I don't know who makes the Branson Backhoe,. The Dealer tells me Branson does. I find that hard to beleive. I think there out sourced. Anyone know for sure ?
Also The Branson Backhoe Bh76 does have that feature of the Boom being able to go into a float poistion so you can drag the dipper arm up and not let it dig in. That would be a great feature for leveling ground. The Woods Dealer did not know. Branson Dealer did not know either until I went out and started the tractor up and tried it.
This is what I have learned today.
The Fox
/ Which Backhoe To Buy.? #8
How big is your tractor (sorry, I am too lazy to look it up;)). As a rule of thumb I'd say under 25hp is 6ft BH, 30 is 7ft, 35 8ft and 40+ 9ft but it depends a lot on tractor weight, size and hydraulics too. Is the Branson BH a nine footer? As you probably know the Woods comes in seven, eight and nine foot versions (70x, 80x,90x). I would not expect any manufacturer to have a good quality nine foot BH for 6K including subframe. If it is smaller then it should be compared to the similar size Woods. I'd guess the Woods will be more money but it does have the advantage that it is easily resold whereas OEM BHs are probably more difficult to sell used.
I have a Branson 3510i (35 hp ) The Backhoe that the Dealer quoted me was an 8 foot one.. I think they gave me a pretty good price since I bought the Tractor from them. I have learn't the art of Haggle. The Backhoe I looked at is very well made by the looks of it and operates very smooth. And the Mechanic told me they don't have them coming back in the shop for repairs.
The Fox
/ Which Backhoe To Buy.? #10
Amerequip and Ansung make loaders for Branson, so I would suspect that they make some of the BHs as well. This is purely speculation though. I would bet that the BHs with an X in the model # are made by Amerequip.
The Fox
You are absolutely right. Ansung (made in Korea )and Ameriquip ( USA ) make the Branson Backhoe according to the Rep I talked to yesterday. I still don't know which one is being shipped right now with the new tractors, ( I shell find out ) I want to buy one and I want to know who made it. The one I looked at, is only stamped with BH 760 . The Dealer keeps telling me Branson makes there own FEL and Backhoes, which is not so. Does anyone have any experience with ANSUNG equipment ??? I would think the Made in USA would have better steel in it and would be stronger..
The Fox
Just got an E- Mail from Branson and they tell me the BH 760 Backhoe is made in Korea and I take it that is by Ansung.
The Fox
/ Which Backhoe To Buy.? #13
I could be wrong but I believe Kioti FEL and BHs are made by Ansung. If so they are very well made. Send a note to Rick Wallace here on TBN as he would know. I'm sure the other Kioti dealers could answer the question too.
/ Which Backhoe To Buy.? #14
I have a 3510h with a 8620 bh, bought in January of '08. The plate on it says that it is made by Ameriquip. The loader is Ansung.
Mark
Mark
Yes you are right my FEL said on it "ANSUNG" made in Korea.. I am looking at the Backhoe and as near as I can tell it is made by Ansung. They make Backhoes and FEL for New Holland and Kobota and Branson, ( they say this on there Web Site ) Also Ameriquip make them as well.. It will be interesting to see which one I wind up with. They have it sitting in there yard now on another Tractor.. Both are good units I understand..
I am looking at a BH 760 model and they want $7450.00 installed..
Woods Dealer wants $ 9228.00 .So you know where I'm going. I
would think you can buy these cheaper in the USA. ?
The Fox
/ Which Backhoe To Buy.? #16
The Fox
I've gotten a little use out of the hoe. The thing is indispensible when you need it, but it does sit around alot. It has worked very well for me, almost too powerful for the weight of the tractor. Built very well, have had no trouble. Kind of like the rest of the tractor:thumbsup:
/ Which Backhoe To Buy.? #17
It is that way on my Amerequip 8600 hoe - and YES, it is a nice feature.
I am fairly sure that the 7 1/2 ft hoe is also an Amerequip OEM unit.
They have made them for many tractor "manufacturers" in matching colors, including JD green.
I don't know specifically about the 8620 hoe, it may just be a later revision of the 8600 by Amerequip.
PS "Installation" isn't worth paying any money for.
I brought mine home in a horse trailer and unloaded it with the pallet forks, then just assembled it in the front yard using the FEL a couple of times as a crane.
Simply bolt together the rear tower & seat section to the under-tractor frame.
Hook the hoses into the hydraulic system, then back over it and hook it up.
No special tools required, REALLY simple nuts and bolts assembly - DONE.
I was up to the Dealer the other day and I see that all his Backhoes and FEL are made by " Ansung of Korea ". They are stamped right on the left side of
the units. He was telling me that he only wants them shipping Fel and BH's
that are made by Ansung. as he said they are well made. so I guess I know what kind of a unit I will be getting from him. Yes I would think it is not rocket science to hook a Backhoe up just have to tee in the lines from the Hydraulic pump ....
The Fox
/ Which Backhoe To Buy.? #19
The Fox
Those are the new and current ones, right ?
The one for $6200 ...is that a new, used, or NOS (new, old stock) unit ?
I don't think you will find the Ansung to be any "better" than the Amerequip - and if it means anything to you the Amerequip IS made in USA, is OEM'd to Montana, JD & others so you may have a wider parts availability a few years from now.
Something you probably want to get right BEFORE nailing the deal down TOO tightly is bucket size.
There are MANY threads on this, but it seems to be a consensus that a narrow bucket is nice for tasks like trenching and root ripping, but won't empty easily if you have sticky clay.
A wide bucket is nice for moving lots of sandy loam around.
I got lucky with mine, they offered to throw in an extra bucket AFTER the deal was done.
Buckets are around $500 and a 24 inch one can be a curse for trenching (-:
That is a brand new one and it is a current one. The dealer I am with will only bring in Ansung as he said they are better built then the others. I have no way of proving that, as I have not seen the other ones. Woods I know make a great backhoe. But they are more money.about a thousand dollars more or at least from the Dealer I talked too.
Yes I want an 18 inch bucket as I have sandy soil here..I can get them to throw that in as they said there is only $ 64.00 difference from a 16 inch.
I don't need a 24 inch one. It might be to much for the hoe. As far as throwing and extra bucket I doubt that will happen although you never know.
The Fox
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
2016 Freightliner 108SD T/A Rolloff Truck (A64194)
2016 Freightliner...
2015 Ford F-650 Altec AP40 35ft. Bucket Truck (A64194)
2015 Ford F-650...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A64557)
2013 29ft. Larson...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
