Transmission Flush
/ Transmission Flush #61
That's easy...same way it's been recommended and done for years. Despite the things that have been implied or suggested thus far, there's no reason to try and out-think the manufacturers. If they say to do it differently, then by all means I will.
I've asked the question several times here and elsewhere, and it never gets a straight answer:
Are manufacturers aware or unaware of the amount of fluid that gets changed when a pan is dropped? I'm going with aware. Change it at recommended intervals, using recommended procedures and recommended fluid. There's no reason whatsoever to go looking on the 'net for "transmission flushing secrets". If they want a fluid "flushed" they'll say so. I find it borderline hilarious that while some folks claim "flush" and "change" mean the same thing, they also believe that there are several types of flushes to choose from, and that some are preferable compared to the others. Where's the logic there?
At work, we came across a similar situation recently, when I noticed another tech removing an oil cooler on one of the Deutz diesels we have so he could empty the oil out of it. I inquired as to what he was doing, and he said he *needed* to remove it during the oil change "to get the dirty oil out of it".
It says right in the manuals for the equipment and the engine itself that oil will remain in the cooler, and that draining the pan at recommended intervals and using the proper grade oil is all that's required. In other words, the folks that built the engine KNOW the cooler doesn't empty when you take out the oil pan drain plug.
So while his efforts were commendable, they provided no real benefit.
I'm not *against* bucket-flushing or whatever else an owner wants to do himself or herself, but look at the multitude of conclusions a perspective DIY-er could draw from this thread:
"Flushing and changing are the same thing"
"This type of flushing is better than that type of flushing"
"I'd do the bucket flush, but not the reverse-flush"
"I read a post from a guy that worked in a lab"
"I do it this way and maybe that's why I haven't blown a tranny in 20 years"
Put all those, (and more), statements/claims/opinions in a single thread, shake them up.....and what have you got? More confusion than an unfamiliar DIY-er came into the thread with.
So can we all pat ourselves on the back and say "mission accomplished", or....would something else be more appropriate?
/ Transmission Flush #62
Broke, don't have my manual with me now (2004 silverado) but do have one for the truck I'm driving at work, a 2001 dodge ram. It says the " the fluid and filter should be changed and the bands adjusted at specified in the maintenance", bla bla etc. I could not find where it says to change only the fluid in the pan. Maybe it's assumed? Or maybe it's assumed when it says to change the fluid they mean all of it.
/ Transmission Flush #63
You guys are fighting a loosing battle here. We each have our own opinions. I am with the change as much as you can camp. After going though 2 trannys in my Dodge in 68,000 miles it was what I was told to do by the dealer, Jasper transmissions, and many trusted mechanics. Its what I do. You do as you wish.:laughing:
Chris
/ Transmission Flush #64
I have no dog in this fight as I do both "change" and "flush" depending upon the circumstances. But in reviewing the 9267 page FACTORY service manual for Dodge trucks which includes the 5 speed transmissions, the attached is the ONLY reference to servicing the transmission. Of course in order to further confuse the situation, MOPAR refers to this procedure as Fluid and Filter Replacement.
Note lines (2) a & b under the Transmission Fill paragraph. To me it suggests a standard fluid replacement is pan only.
Make you own judgement on what they are suggesting.
/ Transmission Flush #65
Chris
2x on doing as one wishes. Some vehicles have shipped with lifetime fluid 'per' the manual. :D
/ Transmission Flush #66
Gale, I did the fluid exchange that you posted on this site, which I'm sure many many people appreciate here. It was as you stated a very easy ( and clean) job.
/ Transmission Flush #67
liledgy I a glad it worked out well for you. It really makes me feel more clean knowing our transmissions are filled with clean ATF and the fluid was the only cost. :thumbsup:
When I first read about it I was saying there is no way it could be that simple based on what some charge for a total fluid change out so I was surprised at how easy it was. Then I wanted to kick myself for not having done it years ago. :D
/ Transmission Flush #68
I would like to point out that most transmission problems are not going to happen under the warranty so it's not really in the manufacturers interests to clearly spell out to the home mechanic the correct way of doing what they call of at the service intervals.
/ Transmission Flush #69
This is the point I've been trying to get across. They also don't say to "not do" a lot of things. So....do we do what they recommend, or do we do what they don't specifically either omit recommending or "don't not" recommend?
I certainly couldn't disagree with that.;) It's true that what I find from Ford says to change the fluid. It doesn't say to flush or not flush. But it also doesn't say how to change the fluid. Now I don't have a service manual; only the owner's manual and what I read on Ford's website. So you say these factory trained mechanics at the Ford dealership haven't learned how to do it right yet? I'm not sure how long this dealer has been around. The first time I was in the place was 53 years ago, and the old gentleman who owned it died last year, but both son and daughter are still in the business.
Now I'm all in favor of you and others doing whatever you want to do to your own vehicles, but personally I'll go with the factory trained folks.:laughing:
/ Transmission Flush #70
Enjoy that warm weather. You driving the new truck or flying?
Either way have a safe trip.
Chris
We're back...We flew down. 80 and sunny every day in Disney. It's like 20 here in PA now. What a rude awakening that was going to get the car...Oh well, it was a pretty nice trip.
/ Transmission Flush #71
I was *kind of* waiting for someone to say something like that. But here's the thing, you're implying that since most transmission problems are not going to occur under warranty, then the manufacturers don't care how a given vehicle is maintained. And that's ludicrous.
Why is there a maintenance schedule listed then at all?
To take it a step further, what does this mean?
so it's not really in the manufacturers interests...
Once again, you're implying that they either don't want you to, or don't care if you.....maintain the vehicle correctly. In other words, you're saying that they're saying, that "the transmission will probably make it through the warranty period with no issues anyway....so even though we go to the trouble of specifying a maintenance schedule for it....we're not going to say how we really want that maintenance done".
And to think a few posts up someone said my ship was sinking.:p
What has a fluid change meant for years? Why, if a person searches for information about this on the 'net, do their searches always lead them to a DIY-ers own "preferred version" of what a manufacturer "means" when they say "change"?
So far, (despite several invitations on my part), one person has stepped up with a scan from a service manual. Read the pages he posted and tell me this: Whose view does his service manual support? Here's a hint: Before the text detailing the recommended change procedure, it says this in plain-as-day English:
"For proper service intervals, refer to lubrication and maintenance schedules..."
So what's an owner to do? Well, you refer to the schedule....which we all *seem to* agree upon. Then we go to a service manual where it tells us how to go about doing it. And what does it tell us to do?
Do the manual pages he, (and he alone), has posted leave the recommended procedure up for whole lot of interpretation? C'mon....someone dissect the information he posted from a service manual and "interpret" what it means for me. Apply all the ol'-fashioned, down-home, folksy "common sense" you want and see if you can twist what's on the service manual pages into something that supports your point.
I've seen a whole bunch of "factory trained" mechanics do things the wrong way. Are you saying they never do? I could bore you to death with lots of examples if you want. As an aside, what <cough> factory trained <cough> mechanics often do, is what they're told to do. By all means print (at least) the last couple of pages of posts and take them to your dealer. Have him read them, and then post up exactly what he says in response. If he chooses to not comment on the topic here directly, then ask him for evidence in writing that originated from the manufacturer that details what the manufacturer says should be done at the recommended service intervals.
If he supplies you with supporting information, by all means post it up here because that's much more valuable than all of this "maybe they mean this", nonsense.
If he balks at supplying you with said evidence in writing, well.....feel free to share that as well.
/ Transmission Flush #72
Well, I'm old enough to remember when automatic transmissions had a drain plug just like the crankcase.:D Maybe you're not.
Probably he's the only one who has a service manual. I used to buy them myself, but not recently. But that's for a Dodge and I drive Fords.;):laughing: And he didn't say what year model(s) that manual is for.:D
Of course some do things the wrong way. But the whole dealership or whole service department????? In a dealership that's been there for over 50 years??? Kinda doubtful in my opinion, but I'm not saying impossible.
Now that would really be a silly waste of my time, since I'm not the one getting excited or upset because people won't do it my way.:laughing: But if you'd like to do that, I'll be glad to give you the dealer's name. In fact, it's Bill Utter Ford in Denton, TX. And I've known and trusted them a lot longer than I've known you.;) As I said before, I'm all in favor of you doing it your way on your vehicles. I just posted what the dealer (service writer) told me for anyone's information. Everyone is welcome to take it for what it's worth, believe it or not.:laughing:
/ Transmission Flush #73
The manual is specific for a 2006 Dodge truck but the post is for the RFE 545 5 speed transmission which has been in use 2001 through the current models.
/ Transmission Flush #74
Broke, since you have the manual. How much trans fluid does it tell you to change?
/ Transmission Flush #75
There are plenty of things to argue about in life...This just ain't one of them.
/ Transmission Flush #76
I could not agree more. We have Ford and Chevy fights to get back to.:D
Just joking.
As for drain plugs in the pan every truck I own has one along with my neighbors Dmax. Most new vehicles do not even have a filter anymore of if they do its external spin on like a oil filter. Heck, even my 96 and 99 GM cars had that.:thumbsup:
Chris
/ Transmission Flush #77
I could not agree more. We have Ford and Chevy fights to get back to.:DJust joking.
Chris
Oddly enough, GM and Ford fights make more sense to me than this does.
On that note...While peeking around corners at Disney, they have the biggest fleet of Chevy trucks I've ever seen:D...Sorry, couldn't help it...True though.
/ Transmission Flush #78
On a side note, I took my truck in for cooling flush because I was paranoid about putting regular tap water thru the system. I hear it can do damage to the gaskets and such. Is there a way to safely due it? I thought the manual said distiller water only.
/ Transmission Flush #79
Yeah, you can buy a few gallons of distilled water...Although I've never had tap water problems with cooling systems, even though it's supposed to be a no-no. I have well water, which is probably worse...Don't really know.
/ Transmission Flush #80
Just purchased an 03 silverado that I plan on doing some towing with. It has 100k miles and I want to change the transmission fluid. I have been told by one mechanic that a flush is the best option, I have been told by another mechanic to drop the pan and change the filter, he claims a flush isn't the answer cause you want to leave some fluid in the system. He explained that the clutch additives were helpful. (or something to that effect) Any thoughts?
I did not read the whole thing Just the beginning. That much mileage with no prior servicing you are risking just rebuilding the tranny. I know no one that would do a service on that vehicle with no prior flush OR dropping and cleaning the magnets. I would at least keep half the original fluid and reuse if you are that set on doing this because the used fluid is not as hard on it as the new would be.
Is there a reason you feel you need to do this?
Again sorry I just could not bear to read through the entire thread
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
KUBOTA RTV 900 UTV (A64280)
KUBOTA RTV 900 UTV...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
