4310 geared model won't move
/ 4310 geared model won't move #1
jkwbako
John Deere 4310
My 4310 geared model with ePowrReverser doesn't see much use anymore (RE Developer, Builder-nuff said) but the last few times it seems weak and once just stopped and wouldn't move. After sitting over night it was fine for 6 or 8 hours spread over several months now stopped again and won't move. Starts and runs fine and bucket works but won't move.
Friend said to check suction side filter and screen, I decided to change all fluid and filters. When I drained the fluid it was really dark and had a pearlesant shimmery quality to it; I suspect the fluid has never been changed (so much for my guys saying they took care of it). The tractor has 1000 hours on it. Also found the suction screen cylindrical filter with a tear in the top fine fabric covering. After new filters and fluid still won't move.
I hope the pump is not shot, how can I check it - any other ideas? I am trying to avoid taking to the dealer, we have plenty of time to work on it now!
One more thing (Rookie Alert!) I see posts about an indicator light flashing codes - where is it located? I can't find mine and don't see anything about it in the manual.
/ 4310 geared model won't move #2
So far, you've replaced your fluids (although I don't thing old hydraulic fluids would have much impact on a gear transmission tractor moving (but could result in premature wear)) which leaves electronic/electrical (the "e" in ePowr-Reverser) or mechanical. I suggest the next step is to change the air filter(s) and see if that helps (doubt it, but it's the cheapest next step).
After that, I'd guess it's time for the dealer to check it out, I'm afraid. My guess, without ever having seen this tractor, is the clutch is about done for...but you never know, it could be something electronic.
/ 4310 geared model won't move #3
air filter won't help...if its running it would at least try to move
i don't know much about them transmissions but there must be clutch packs for the shifting???
/ 4310 geared model won't move #4
Worst case with a fouled air filter is way down on power...unlikely, but possible. And, it's jkwbako's cheapest next step (before the dealer).
One more thing (for jkwbako). Try starting the tractor in a higher range, high gear (at a fairly low RPM...about 1000 RPM). A bad clutch might slip too much in a lower gear, but might get you moving in a higher gear. This would be a diagnostic test, not a work around.
Hanson1999...it was your last comment that sparked that thought...I hope it helps jkwbako (of course, it would mean a clutch replacement, most likely).
/ 4310 geared model won't move #5
As I remember the e-reverser on this series is like the current one. It requires hyd pressure to ENGAGE the drive through the clutch. There is actially two clutches one forward, one back. Do both operate the same? If so, look at the control to the clutch porportional valves. Some reports of failed wiring have happened. If not I would suggest the valve isn't getting opened. Working cold, but not hot, is one symptom of a weak solenoid. It uses a pressure port off of the steering pump, not the main hyd pump. Does it steer well? If not, look for the high pressure filter and check/ clean it. If you look back through my posts there is a schematic diagram of the 4X20 which is going to be similar.
/ 4310 geared model won't move #6
I hope you replaced the torn sump filter with a new one...
There's a clutch pack for forward and reverse - two clutch packs. Does the tractor move in reverse?
Also, does the 3pt work? (Question regarding the steering function was already asked.. does it steer OK?)
If the clutch(s) were slipping - it would be worse in C range (highest). That's why it's the best way to test for a weak clutch - use a high(er) gear - and dump the clutch. If the clutch is worn out the engine rpm's will increase and drop before stalling. Harder to detect a worn out clutch using lowest gear.
AKfish
I did replace the air and fuel filters while I was at it, so no luck there. I'll try the steering and 3 point and starting in a high gear.
I did replace the torn sump filter.
/ 4310 geared model won't move #8
Keep us posted on what you find, please.
/ 4310 geared model won't move #9
jk,
Your "shimmery" oil concerns me. You should also replace that suction screen with the hole in it. You can test the system pressure:
Attach your gauge at point "A". You should have a minimum pressure of 135 psi at idle maximum pressure of 175 psi.
/ 4310 geared model won't move #10
Roy
You've got in backwards. A clutch will slip much easier in high gear than low gear.................
/ 4310 geared model won't move #11
Roy
You're right, but that slippage won't stall the tractor (like it would in a lower gear).
When clutches were more common in street vehicles, if a guy had a clutch going south, he could slip enough in a higher gear to get the car or truck moving (to get it home or a repair shop). That's what I meant, but it wasn't well expressed in the earlier post. My apologies...
The intent is to see if jkwbako's tractor will move in gear. I'm hoping this works for him as part of the troubleshooting.
I think his 4310 is going to end up at a dealer for repair, however.
/ 4310 geared model won't move #12
I had a similar issue with mine. It would suddenly lose power and stop and when I moved the reverser from forward to reverse, nothing.
I noticed that by engaging the clutch a few times, it would move again normally. I lubricated the clutch linkages located directly above the clutch and have never had the problem again.
As I recall there are several pivot points that serve an electronic module linked to the clutch. One must have been sticking.
WD-40 took care of it.
Update:
Tried the 3point and steering and they worked fine, so I dont think it is the hydraulics. Couldn't get it to move dumping the clutch in high gear- I think it must be electrical. The tractor is now waiting on a friendly tractor mechanic to find time to "take a look". I'll let you know how it turns out - thanks for all the posts.
BTW does anyone know if this tractor has a flashing LED that puts out error codes? I don't know where it is if it does have one; I have heard from others with similar tractors that it does have one.
/ 4310 geared model won't move #14
Keep us posted on this, please. Might help somebody else.
/ 4310 geared model won't move #15
If you have the e-Hydro(not yours) or the e-PoweReverser, there is a orange light on the right control panel. If you have a gear tractor it will not have one. There is a sequence of light flashes(codes) for any problem the tractor "sees" during its self check. Post the series of long/short flashes and we will tell you where to start looking.
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2007 Blue Bird All American Bus (A61573)
2007 Blue Bird All...
Year: 2015 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 165,169 Plate: Body Type: 4 (A61573)
Year: 2015 Make...
