b2920 snowblower
/ b2920 snowblower #1
tony binkowski
green bay packer land
2011 b3000
gentelman, can a b2920 handle a 63in blower or do you have to go with 51 in. high cap. blower? one dealer said yes and the other said no. cant get a b3000 for 3 months so i was considering the b2920 with fel and blower. need some info? thanks
/ b2920 snowblower #2
I bought a B2920 with a 63" front mount 2782 blower in December. I have walked through knee high drifts with absolutely no problem. I was originally going to get the smaller 51" but the dealer sold the last one the day before I leaped.............Thank goodness. I really like the build on this larger, commercial grade blower. . . . and best of all, I paid about $300 more for the blower.
Get the big one.
Mike
/ b2920 snowblower
thanks for info, did u even get to look at the 51in.? how far does the 63in blow snow? do u have a cab?
/ b2920 snowblower #4
The 51" B2781A is just as well made as the B2782. The BX2750 is the lighter duty 50" unit. I personally think the 63" is too much for this series.
/ b2920 snowblower #5
I did not see the 51" The dealer was trying to sell the 2750 originally. I suppose if the 63" starts to bog, I'll either go slower or take a smaller cut.
So far, so good.
Mike
/ b2920 snowblower #6
Go with the 63 inch blower
I own the 51" industrial blower...great blower
The 29 hp 3 cylinder has NO trouble turning this blower
Here is why I will tell you to get the wider blower. With a 5 ft rear blade/box blade you will be cutting into/wider than the front blower and will leave spoil on any close pass
"evil weasel" I know from experience and many residential drive contracts that the b2920 has no problems ever turning the wider blower
/ b2920 snowblower #7
I would caution that it depends on the snow you will be working on.
Up here I run a 60" on a~40hp machine and sometimes it works the tractor pretty hard. But we measure snow in feet rather than inches.
If you usually have a foot or two on a short drive then I think it would be fine, but three to four feet on a long drive on a regular basis would be a workout.
Also is it very cold normally and so light and fluffy, or that mid Atlantic slush that is much harder to blow.
/ b2920 snowblower #8
I have no doubt. I had one incident of heavy snow accumulation that got rained on and it really taxed the B2620/51" combo. The 51" covers my tracks, but not by much. I find that in the really heavy snow, switching from medium to low range reduces the bogging/loss of RPMs.
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2437 (A65640)
2437 (A65640)
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
